Old March 1st, 2018, 16:33   #1
Camperbob
Default Bad headgasket, need head work.
New owner of a 2002 TDI Jetta. Found a bad headgasket from a lifting head and pressurizing coolant system. I tried to contact Franko in MO but number disconnected. Who would you recommend for a trusted machine shop? I'm in NW Montana but shipping it out isn't a problem.
I've just started reading this forum, and I'm new to forums in general.
Thanks.
Camperbob is offline   Reply With Quote
Old March 1st, 2018, 17:40   #2
steve6
Frank posts here all the time, his number definitely is not disconnected
http://forums.tdiclub.com/member.php?u=31923
steve6 is online now   Reply With Quote
Old March 1st, 2018, 18:35   #3
csstevej
Yeah frank or his wife picks up the phone every time I call there.
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old March 1st, 2018, 19:22   #4
Camperbob
ok great.. I will try again.
Old March 1st, 2018, 19:52   #5
Franko6
Try again. However, I will say, I'm going to celebrate Mary putting up with my antics for 32 years... We will not be available unless you want to track us down in Kansas City trying to make a fun day of it!
Otherwise, you can call in the morning, before noon....417-232-4634
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old March 2nd, 2018, 01:41   #6
hollowhead
hollowhead's Avatar
Have a good time, frank and mary
hollowhead is offline   Reply With Quote
Old March 5th, 2018, 22:13   #7
Camperbob
Frank,
I used a level and light to check the block for a low spot. . .light can be seen under the level at the spot where the gasket failed. I have photos but don't know how to add them on here, so I will send them to your email. Let me know what I need to do next , thanks.
Old March 6th, 2018, 17:02   #8
flee
Fuel Economy: 40-ish
First, make sure you use a good straightedge and check the block in several directions.
I've read that some guys have decked the block in the car but that seems iffy at best.
So, you probably are looking at pulling the engine - not a big deal in itself.
Your title says you need head work, too.
If that is the case I would at least entertain the idea of buying a used engine.
If you have the time and budget then get your own block and head redone.
For that I can think of no better place than Franko6's shop.
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is offline   Reply With Quote
Old March 6th, 2018, 17:56   #9
Greasemunkey
I would stress flee's point about a "good" straightedge. It has to be a proper machinist's straightedge. If it was a carpenter's level you used you may be doing a lot of work unnecessarily.
BTW my profile says newbie but I used to be a certified master engine machinist. Just new to posting here.
Greasemunkey is offline   Reply With Quote
Old March 7th, 2018, 15:58   #10
Camperbob
I'll look for a machinists straight edge and bastard file.
also, what is a good price on a used engine? There are a few complete Tdi cars for sale in the Area, around $2000 seems average.
Old March 7th, 2018, 16:03   #11
Mongler98
dude, just take a normal strait edge ruller from a combo square for $10 and some 220 grit on a flat big glass mirror and hone it down flat, finish with 330 if you want but this complete with a $2 set of feeler gauges will give you all the help you need.
Old March 7th, 2018, 18:34   #12
Camperbob
I have read about what you mention Mongler and I may try it on the block. I've also been talking to Franko on details.. thanks to all who replied.
Leaking headgasket, bad waterpump or egr jacket Jesse_James Jetta/Bora/Vento TDI Picture Gallery 5 June 6th, 2007 18:44
Redo head wearables when doing headgasket change? darkscout VW MKIII-A3/B4 TDIs 22 June 1st, 2007 23:30
Re-tighten head bolts after 1000Km from headgasket change??? Satiro TDI Power Enhancements 4 February 25th, 2007 09:00
Headgasket question and Head studs? TdiRacing TDI Power Enhancements 28 January 2nd, 2005 14:16
Page generated in 0.11485 seconds with 10 queries
[Output: 102.13 Kb. compressed to 85.38 Kb. by saving 16.75 Kb. (16.40%)]
