Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old March 1st, 2018, 16:18   #1
FordManMT
Exclamation My Cummins into Ford Swap video log
Everyone here most likely love diesels so I figured why not?
You will have to be patient video 1 and 3 are kind of boring but number 2 and 4 have some decent content.
This is a in progress build so I should be posting a video every week.
Thanks!
one: https://youtu.be/1fLvfuF7VNg
two: https://youtu.be/VKmWq7ouens
three: https://youtu.be/bBGDLpKrQVU
four: https://youtu.be/lOfjJLwBlP0
FordManMT is offline   Reply With Quote
Old March 3rd, 2018, 11:33   #2
greenskeeper
greenskeeper's Avatar
Fuel Economy: 53mpg
how many miles were on the 7.3 IDI ?
Gunga galunga...gunga -- gunga galunga.
98 JETTA TDI (SOLD) PP764s, RC3, 5deg advanced, 0.68 5th
97 F-250 Crew Cab 4x4 7.3L PSD E4OD (stock)
99 F-250 Crew Cab 4x4 7.3L PSD ZF-6 (4" turbo back, Hydra chip)
greenskeeper is offline   Reply With Quote
Old March 5th, 2018, 06:41   #3
Oberkanone
Thank you for sharing. Will be interesting and educational to follow your build.
I like the 7.3L and from the little I know it is reliable. Not as good as the Cummins, I know.
Oberkanone is offline   Reply With Quote
Old March 5th, 2018, 11:50   #4
greenskeeper
Fuel Economy: 53mpg
Originally Posted by Oberkanone View Post
T
both are medium duty OTR truck engines and will last as long as you maintain them. The advantage the 7.3 has is that it isn't wrapped in a dodge truck.
Old March 6th, 2018, 08:32   #5
FordManMT
Around 220k. I either had cylinder 8 fail or possibly a turbo failure after hauling close to 20,000lbs. After mileage was cut in half and turbo would only spool to about 3psi. I was looking for an excuse to put a cummins in it anyways.
Old March 6th, 2018, 08:41   #6
FordManMT
In my opinion the 5.9 cummins is better than the 7.3L IDI for many reasons.
The 7.3 was a bored out 6.9 diesel from the factory, it had a different injection pump and larger head bolts but largely the same. Still mechanically injected. They run very well of bio diesel, including mixutures of Diesel, atf, and waste oil. They had a high compression ratio of I think 21.5:1. They were designed to run N/A but for about a year and a half they came with a turbo to keep up with dodge until the 7.3PSD came out.
The 5.9 being an in-line Engine naturally developes more torque just because of the engine layout. With the P7100 inline injection pump tuning is done by retiming the pump (easy) and changing fuel plates, governed springs ect. A factory engine can easily double its power and run 40psi with no major modifications.
The 6BT was used everywhere, from wood chippers, to boats, medium and light duty trucks, to stationary generators.
Greenskeeper is right though, the cummins is a million mile Engine in a 100k mile truck. Haha.
I should have another update in the next few days or this weekend. Thanks for commenting. More to come
Interesting Video on Ford assembly plant in Brazil pruzink General Automotive 8 December 26th, 2008 07:29
Dynos/log File/video buckweat diesel TDI Power Enhancements 22 December 27th, 2007 11:18
Video: 5500# Cummins p/u runs a 10.32 second 1/4 TooMuchBoost General Automotive 2 October 17th, 2005 12:31
Common rail in Cummins 5.9, Ford 6.0 and Duramax donsdiesels Non VW Group Diesels 12 December 10th, 2004 17:55
A Cummins badge on a VW on a Ford lot logic_poet Mid-west USA 1 May 22nd, 2003 07:03
Page generated in 0.12309 seconds with 10 queries
[Output: 74.94 Kb. compressed to 65.79 Kb. by saving 9.14 Kb. (12.20%)]
