Old March 2nd, 2018, 10:29   #16
dlai
dlai's Avatar
Fuel Economy: Up There
There is no snap test. I just had my smog done last week on my BHW with no issues. Do you have any Propel synthetic diesel stations near you? You can try to run two tanks of that first and then do the smog test again. I do that with my Golf since it's highly modded and it reduces the black smoke quite a bit.
2002 Golf, 2005 Passat Wagon Stonehenge Gray
Chainless Since 4/22/09
dlai is offline   Reply With Quote
Old March 2nd, 2018, 12:07   #17
KLXD
I didn't think so. Maybe the tester was doing his own thing. If so the OP needs to be raising ell, getting a refund and complaining to the ARB.
My AHU should be coming up again in a few months so I guess I'll find out. My Dodge too if I decide to start driving it again.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old March 2nd, 2018, 12:51   #18
torman
TDI(s): Golf TDI
Take it to another inspection station. Most just check for no check engine lights.
If you mean CAT was removed (and not actual mufflers), that is a whole other issues, as many inspection stations look for CAT as a proxy for seeing if any emissions items have been removed. A lot of diesel trucks went straight pipe years back (before CA ramped up inspections on them) and shops have been instructed to inspect exhaust system for mods.
torman is offline   Reply With Quote
Old March 2nd, 2018, 13:09   #19
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
We used to have emissions testing here in British Columbia. Because of the way the system works, I didn't have to take my car in until it was six years old.
Well, upon my first visit to the inspection station, I noticed that my vehicle registration documents had the fuel type listed as "Gasoline!"
I pointed this out to the inspector, and he was able to change the fuel type to diesel in the vehicle registration system.
Had I not brought it to their attention, I guess they would have been testing my vehicle using whatever procedure they use for a gasoline engine car. Maybe it would have failed?
Do your registration documents in California mention anything about fuel type? Make sure it's correct!
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
Old March 5th, 2018, 13:32   #20
Rob Mayercik
Dirty air filter reducing engine's ability to breathe?
2002 Jetta GLS TDI Automatic
Baltic Green/Beige Leather
Rob Mayercik is offline   Reply With Quote
Old March 5th, 2018, 14:38   #21
narongc73
As a few said before use biodiesel. I put a bottle of crisco in the UK and it worked. I had failed the day before.
narongc73 is offline   Reply With Quote
Old March 5th, 2018, 17:21   #22
flee
Fuel Economy: 40-ish
Where exactly is the TDI's UK located?
Please don't do this. A tank or two of biodiesel can't hurt, though.
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is offline   Reply With Quote
Old March 5th, 2018, 18:30   #23
narongc73
? United Kingdom. You don't need a tank, just some to dilute.
Old March 6th, 2018, 08:05   #24
KLXD
The point is the OP, who's disappeared, got ripped off based on dlai's recent experience.
If he just goes to another tester he's out money. Also, the original clown may have put some notes in the system about it failing which could cause him problems.
Missing mufflers are probably grounds for a fail but that's not what got him.
Old March 6th, 2018, 17:08   #25
flee
I guess I aimed too high with that one.
How was your California SMOG test? tothemax TDI (Diesel) Emissions 307 May 13th, 2016 11:04
So... will the TDI's pass a smog test in Ca? Sfkjeld VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 September 22nd, 2015 08:10
California Diesel Smog Test Frequency? latinvw TDI 101 7 January 28th, 2013 22:24
California smog test raila@pacbell.net TDI (Diesel) Emissions 12 September 14th, 2008 13:40
Smog Test in Southern California cheuk2004 TDI (Diesel) Emissions 17 December 11th, 2004 21:22
Page generated in 0.15951 seconds with 10 queries
[Output: 98.10 Kb. compressed to 83.41 Kb. by saving 14.69 Kb. (14.97%)]
