Old March 1st, 2018, 13:34   #1
SeanDieselB
TDI(s): 82 pick-up
Fuel Economy: 43
Default Does anyone have a flywheel sitting in the open?
So I need help, I machined down my flywheel before I replace the clutch and it turned out well... I think.
The issue is that I didn't realize you need to machine the top where the pressure plate bolts down as well?
I didn't check what the difference in height was between the two before I started so now I don't know how much material I removed from the face of the flywheel. Does anyone have access to a good flywheel that can measure the height of the step?
in 1,000s of an inch please!
SeanDieselB is offline   Reply With Quote
Old March 1st, 2018, 14:26   #2
jimbote
jimbote's Avatar
13mm ... but double check before cutting
Old March 1st, 2018, 17:52   #3
Steve Addy
TDI(s): 97 Mk3
I have one, I'll see if I can't get over there to measure tonight.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Old March 2nd, 2018, 12:41   #4
SeanDieselB
TDI(s): 82 pick-up
Fuel Economy: 43
A quick check gave me around 505 thousandths on the machined one, which is very close to the 512 that 13mm equals. however it should be over 512 not under? So yeah, a couple more measurements from the hive mind would be great.
You guys are the best, I thought I was royally screwed after this.
Old March 3rd, 2018, 01:21   #5
Abacus
That helpful B4 guy
Abacus's Avatar
I've got a few kicking around I'll measure when the sun comes up, including a brand new lighter one I never installed.
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Old March 3rd, 2018, 13:14   #6
SeanDieselB
TDI(s): 82 pick-up
Fuel Economy: 43
That would be awesome, let me know.
Old March 3rd, 2018, 20:35   #7
Abacus
That helpful B4 guy
Abacus's Avatar
I have 2 used stock ones and one new light one (17lb) in the garage.
Used flywheel #1: 484 thousandths (0.484")
Used flywheel #2: 491 thousandths (0.491")
New flywheel: 504 thousandths (0.504")
Old March 8th, 2018, 23:06   #8
Steve Addy
TDI(s): 97 Mk3
I finally remembered to do this. The one I have measured out at 1/2".
Steve
Using old pressure plate as a flywheel puller and other flywheel questions Joester TDI 101 7 October 15th, 2012 07:37
dual mass flywheel to single flywheel conversion vdubdezl TDI 101 16 December 23rd, 2010 05:27
Is a passat 16v Flywheel (037105273c) the right flywheel for a vr6 clutch conversion? dieselmacht VW MKIV-A4 TDIs (VE and PD) 2 December 25th, 2009 06:14
G60 Flywheel & Mk3 TDI Flywheel G60ING Private TDI Items for Sale/Wanted 7 July 22nd, 2009 09:38
2006 DSG flywheel cut open Crosley VW MKV-A5 Golf/Jettas 2 October 29th, 2008 06:11
Page generated in 0.14442 seconds with 10 queries
[Output: 86.58 Kb. compressed to 74.56 Kb. by saving 12.02 Kb. (13.89%)]
