Old March 1st, 2018, 09:52   #1
Dsmart
Default Can the TDI fry its own ecu? 2004 BEW scan attached
I was out running errands and the car failed to start (usually fires right up) it started second attempt but cranked much longer before doing so. Engine light came on and car is way down on power. Did a scan when i got home and its not looking good. The ecu is has a rocketchip 1.5 and has been flawless for the last 7 years. Everything else is stock. Car still runs but im not driving it as the likelihood of getting stranded seems high. Any insight??
Wednesday,28,February,2018,19:42:02:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 9M - VW Jetta IV
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: WVWSR21J74W165211 Mileage: 352370km/218952miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 997 016 R HW: 028 101 114 6
Component: RC s01G EDC G000AG 0282
Revision: 12345678 Serial number: XXXXXXXXXXXXXX
Coding: 0150034
Shop #: WSC 00000 028 00001
VCID: 2D5B176DB70A1F1
7 Faults Found:
16725 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal
Freeze Frame:
RPM: 882 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00001100
Idle Stabilization: 0.0KW
(no units): 48.0
19829 - Intake Manifold Change-Over Valve
P3373 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 882 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00001100
Mass Air / Rev.: 450.0 mg/str
Absolute Pres.: 948.6 mbar
16629 - Solenoid Valve for Boost Pressure Control (N75)
P0245 - 000 - Short to Ground
Freeze Frame:
RPM: 882 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00001100
Absolute Pres.: 1030.2 mbar
19794 - Control Circuit for Glow Plug Controller 1
P3338 - 000 - Electrical Malfunction
Freeze Frame:
RPM: 882 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00001100
Temperature: 41.4C
Bin. Bits: 11111111
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 882 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00001100
Torque: 166.0 Nm
Torque: 0.0 Nm
19559 - Motor for Intake Manifold Flap (V157)
P3103 - 000 - Malfunction
Freeze Frame:
RPM: 882 /min
Torque: 38.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00001100
Torque: 148.0 Nm
Torque: 0.0 Nm
16705 - Engine Speed Sensor (G28)
P0321 - 000 - Implausible Signal
Freeze Frame:
RPM: 0 /min
Torque: 24.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00001100
RPM: 504 /min
Readiness: 1 5 1 1 1
Address 02: Auto Trans Labels: 09A-927-750.lbl
Part No: 09A 927 750 AM
Component: AG5 Getriebe 09A 0251
VCID: 76E9F80152DC1C9
2 Faults Found:
00529 - Engine Speed Signal Missing
03-00 - No Signal
01166 - Engine Torque Signal
03-00 - No Signal
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001025
Shop #: WSC 01266 785 00200
VCID: 336F0115512E491
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Part No: 1C0 909 605 A
Component: 0G AIRBAG VW51 02 0008
Coding: 12359
Shop #: WSC 01266
VCID: 2241F451AED4D09
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 01266
VCID: 2F670D65ED066D1
No fault code found.
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 806 R
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 15334
Shop #: WSC 00000
VCID: 3B7F2935297E811
WVWSR21J74W165211 VWZ7Z0C8827542
1 Fault Found:
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 01266
VCID: F0E54E19B0B8B29
Dsmart is offline   Reply With Quote
Old March 1st, 2018, 09:55   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Well certainly anything is possible, but since you can still communicate with it I would suggest checking all the fuses and all the grounds first, as well as checking the connection to the ECU itself, as a lot of times if the cowl cover is damaged water can get in there and cause all sorts of problems. So can critters.
You may also take a look over the engine management wiring diagram and see if there are any common power or ground feeds to the various things listed.
And as always, check the power and grounds from the battery.
oilhammer
www.cardocautomotive.com
Old March 1st, 2018, 10:00   #3
mjydrafter
mjydrafter's Avatar
Besides oilhammer's suggestions, how old is the battery?
With that number of codes I would check for a bad battery 1st, just because it's easy to check/get checked.
If that isn't it, I would suggest digging into the wire harness down by the battery. This could also be one of the wire chaffing problems.
mjydrafter is offline   Reply With Quote
Old March 1st, 2018, 10:23   #4
Dsmart
The battery is a fairly new AGM and seems pretty good but the car has been put on light duty as we have 2 others vehicles that fit the car seats better so it does sit for a week at a time with no use. It has been pretty slushy here so its possible that there is moisture in the ecu connector. Also possible that a ground had rusted off but how would it still run with either blown fuses related to those circuits or no ground? Its almost like the parameters that were adjusted for the tune are scrambled based on the faults. Anyways thanks for the insight. ill report my findings as I dig deeper
Old March 1st, 2018, 10:58   #5
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Start with the assumption that the ECU is fine, they rarely "fry". Seems the battery is good. Weak batteries can cause odd issues.
Go with this- #2
Old March 1st, 2018, 11:12   #6
Dsmart
I have another untuned ecu that I can plug in to see if the faults remain or go away. The only thing is that it doesnt have an immo delete. For the purpose of testing though the immo might not matter.
Old March 1st, 2018, 11:26   #7
arniewallace
arniewallace's Avatar
TDI(s): 99GT TDi
Fuse blown, too many faults to do with solenoids, check fuse 34. All those items are fed from that fuse, and the reason it turning over so much to start is that its getting no signal from the camshaft sensor. Probably a cable worn through at the rear of the intake for anti shudder valve.
arniewallace is offline   Reply With Quote
Old March 1st, 2018, 12:06   #8
Dsmart
Bingo! fuse 34 was blown. Just came inside to report that and saw your post...replaced and all is well. Ill have to check the harness you indicated to see if its rubbed through. Thanks to everyone for the help.
Old March 1st, 2018, 19:37   #9
wonneber
Glad you found the problem.
It might be worth the time to clean the ground wire from the battery to under the battery tray, to the trans.
The one under the battery tray has been mentioned numerous times.
All the devices in the car that ground to the body rely on that one to complete the circuit back to the battery.
Old March 7th, 2018, 19:37   #10
jsrmonster
Veteran Member - TDIClub Enthusiast
jsrmonster's Avatar
RC still running strong after 7 years!
Recently had RC (s01G) 7v gp fix / upgrade.
Happy motoring.
15 Golf SW DSG, 00Jetta 6spd race, 99.5Jetta Rocket ARL-PD150 6spd 2260, 2003.5 5.9L Cummins QCLB 4x4 Blue Monster, 00Passat1.8T, other tdi's: 97J, 98J, 99.5J2x, 00-C5 6spd - EFILive, HPTuner, Diablo Sport!
Never argue with an idiot.They will just bring you down to their level and beat you with experience.
The beatings will continue until the morale improves!
Good judgement comes from experience, and experience comes from bad judgement !
"DIESEL TUNING PROFESSIONAL" 1-5-3-6-2-4=;-)
jsrmonster is offline   Reply With Quote
Continuing Battery Drain issues: VCDS Scan Attached lmoretti VW MKV-A5 Golf/Jettas 5 February 22nd, 2016 19:35
2005 Bew ECU in 2004 BEW Dsmart TDI Power Enhancements 4 April 14th, 2011 18:32
2004 Jetta BEW TDI pd ENGINE 86k for sale VNT Turbo ECU Wiring etc$2000 Veloseller1 Private TDI Items for Sale/Wanted 0 April 1st, 2010 16:47
FS: 2004 Jetta TDI ECU (BEW) jettafock Private TDI Items for Sale/Wanted 7 June 17th, 2005 08:23
WTB: BEW ECU for 2004 TDI vanagontdi Private TDI Items for Sale/Wanted 4 May 10th, 2005 12:41
Page generated in 0.14003 seconds with 10 queries
[Output: 102.59 Kb. compressed to 88.37 Kb. by saving 14.22 Kb. (13.86%)]
