Old March 1st, 2018, 08:18   #1
Stvgordon
TDI(s): 98 Jetta
Default Voltage regulater
Got a 98 Jetta TDI,
Voltage regulater failed. Rebuilt alternator had trouble finding a regulator so I put in aftermarket. So when car starts after about 3 seconds gages stop working, radio goes black.... Iíve checked and rechecked and rechecked everything. Before I start tearing everything out again and order parts.... whatís going on?
Stvgordon is offline   Reply With Quote
Old March 1st, 2018, 08:22   #2
My_name_is_Rob
TDI(s): 97 Vento
Fuel Economy: 46 mpg
Sounds almost like a bad ground to me. Likely somewhere from your battery if I had to guess. I just experienced voltage regulator issues on my alternator as well, but fortunately I haven't directly experienced this problem.
My_name_is_Rob is offline   Reply With Quote
Old March 1st, 2018, 14:46   #3
Mongler98
return that junk part you got and buy an OEM, or rebuild yours. trust me on this, you have a 20-25% chance of that part working for more than 80K miles.
Also you do have a bad ground for your issue.
there is a thread on rebuilding them here, do a seach
Old March 3rd, 2018, 07:02   #4
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Once you go Bosch you never go back.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old March 3rd, 2018, 07:50   #5
AndyBees
AndyBees's Avatar
Check the voltage while the engine is running ... it may be over charging. I've seen them rolling out over 18 volts causing the cluster to totally shut-down.
But, obviously, as others have said, take that thing back while hopefully it is still under warranty!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Voltage Issue, 17911 Voltage Signal tryin2vw VW MKIV-A4 TDIs (VE and PD) 4 July 24th, 2016 15:38
Voltage regulator; voltage needed and bosch quality? guillaumeber VW MKIV-A4 TDIs (VE and PD) 3 September 7th, 2013 12:33
voltage, no voltage, wait voltage! uhh no voltage wgargan TDI 101 1 December 10th, 2009 20:42
voltage regulator fyrman1 TDI 101 2 July 3rd, 2008 16:52
Replaced regulater clips. Two Small Problems? kerouacknew TDI 101 2 May 2nd, 2007 12:40
Page generated in 0.13345 seconds with 10 queries
[Output: 68.38 Kb. compressed to 60.45 Kb. by saving 7.93 Kb. (11.60%)]
