Old February 27th, 2018, 13:42   #1
ecorob
Default 2003 TDI repair rescue in Louisville, KY
Hi All.
My 2003 TDI Wagon was disabled (3 weeks ago) near Louisville while I was driving home to Richmond VA. The obvious problem was a failing timing belt tensioner. I shut the car down while it was still running normally with a loose belt. I had it towed to a Louisville repair shop (that I will not name just yet). The Shop supposedly did a complete timing belt kit install and now can not get the car running. I guess I picked the wrong shop. You know my frustration since I've done successful timing belt jobs on three generations of TDIs.
I'm coming back to Louisville (by Greyhound) this Friday, March 2nd to deal with this sad situation.
Can any of you local TDI Club folks refer me to the TDI Guru(s) in Louisville OR offer garage space, driveway, whatever and a hand to get me up and running (for fare compensation)? I'll have all my timing tools and VAGCOM with me.
Please PM me you can offer a repair location or tow dolly.
Any help is appreciated.
ecorob is offline   Reply With Quote
Old February 27th, 2018, 13:52   #2
Odds are you suffered head damage. Did the shop pull the valve cover and inspect the lifters? That would tell them if there was piston to valve contact. You probably need cylinder head repair or replacement.
There's a good guru in Versailles KY (about 60 miles from Louisville) but I don't know if he's accepting this kind of work.
Old February 27th, 2018, 16:02   #3
williambill
I wouldn't rule out head damage, as IBW stated above, but for what it's worth, I helped out a local TDI Cluber a few months back change his timing belt. Once we got into it, we found the TB was very loose. Don't know if the tensioner let out completely, but the belt had a lot of slack and had been running normally for and unknown amount of time. The cam was still in time with the crank, and the lifters were perfect. Maybe this was a one in a million situation, but I'm just saying there's hope... but verify!
William Bill
-2002 Jetta TDI
-2002 ford F250 7.3L
-1984 Mazda B2200 2.2L NA Diesel
williambill is offline   Reply With Quote
Old February 27th, 2018, 16:09   #4
AndyBees
AndyBees's Avatar
Well, Louisville is over 3.5 hours from my location. Maybe Paramedick (Bruce) in Lexington could give you a reference there in Louisville.
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old February 27th, 2018, 17:13   #5
bbexotics
Fuel Economy: 51mpgs in 96 passat,41mpg in 2004 passat,42mpg in 2006 jetta
Any kind of shop would turn the engine by crank twice to make sure timing is correct, no valves hitting pistons etc. more than likely ( hopefully) they don’t know hoe to bleed injection system in order to get car started.
bbexotics is online now   Reply With Quote
Old February 28th, 2018, 10:50   #6
ecorob
As I said, car was running normally at 70mph, happen to pull into rest area and heard noise at timing belt then shut car off and towed it to a shop in Louisville. So this engine should restart.
Anyone have a contacts for the Louisville local TDI clubers??
Will pay $100 for a tow to a place I can futs with my car for a day this Friday/Sat.
Old February 28th, 2018, 10:55   #7
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Do you have AAA? They will tow you. If you don't, it's worth having.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old February 28th, 2018, 11:41   #8
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
That's kind of a tough ask.
Your diagnosis may be good, but maybe not. At this point it's hard to say if they botched the job or there is an additional issue or both.
2 biggest user groups are tdiclub.com and vwvortex.com, search those for local connections.
Google Custom Search
We have this list-
Trusted TDI Mechanics - By State
Old February 28th, 2018, 11:57   #9
Stromaluski
Stromaluski's Avatar
According to his thread, the shop is currently open.
http://forums.tdiclub.com/showpost.p...9&postcount=80
-Andrew
Stromaluski is offline   Reply With Quote
Old February 28th, 2018, 12:01   #10
I know that. But I saw Bruce in October and he said he was limiting the kind of work he was taking on. The OP should call him, but I didn't want him to count on Bruce accepting the job. It's not uncommon for gurus to have cars just get dropped off at their shops.
Old February 28th, 2018, 12:19   #11
Prairie Chicken
Ditto to that.... worth checking into as I don't recall if there was a down time from when you join and when you can make a service call. It'll pretty much pay for itself in one call. I have the "RV" package that includes a 200 mile tow for each member (which I've used twice).
I've got it for me and my boys and between turbo failure, oil feed line failure, gas in tank, hitting a raccoon the size of a bear (all in the last year) - it has more than paid for itself. Wait times vary greatly, but still worth the $$$.
good luck with the car
Prairie Chicken is offline   Reply With Quote
Old February 28th, 2018, 12:25   #12
BobnOH
not-a-mechanic
If you can't make the needed connections, you may want to tow it back to Richmond yourself.
Seems drastic I know. Seems unusual that the shop that did the TB just left you hanging.
Basic AAA comes with like 10 mile free tow, longer if you pay more.
Old February 28th, 2018, 13:05   #13
Genesis
Fuel Economy: 53/48/42
Got truck that can tow it (e.g. Suburban, etc - really any sort of mid-sized truck/suv or larger can handle it as the car's not that heavy)?
Pay for the fuel and a one-way dolly run, get it home. That's how I'd handle it (and cover a friend's expenses if I didn't have the truck, but a friend did.)
Genesis is offline   Reply With Quote
Old March 1st, 2018, 05:10   #14
fruitcakesa
Fuel Economy: 40's
I believe it is a 7 day waiting period
Originally Posted by Prairie Chicken;5385741[B
]Ditto to that.... worth checking into as I don't recall if there was a down time from when you join and when you can make a service call.[/B] It'll pretty much pay for itself in one call. I have the "RV" package that includes a 200 mile tow for each member (which I've used twice).
2004 Jetta TDI wagon 5 speed 278k+ VNT 17 Kerma tune. new heater core
fruitcakesa is offline   Reply With Quote
Old March 1st, 2018, 08:30   #15
Stromaluski
Definitely agree with that. Definitely don't recommend just showing up with the car. A preliminary phone call or contact of some sort should always be made.
-Andrew
TDI repair rescue Louisville, KY ecorob South Eastern USA 2 March 5th, 2018 19:03
FS: 2003 Jetta Wagon, 5spd, Leather, GLS, Louisville, KY Nash_TDI TDI Cars for Sale/Wanted 16 May 19th, 2015 07:41
2003 tdi gls wagon for sale- 1 hour south of louisville ky lowkey TDI Cars for Sale/Wanted 3 November 16th, 2014 10:19
FS: 2003 Jetta GLS TDI Sedan in Louisville, KY A5INKY TDI Cars for Sale/Wanted 8 December 10th, 2013 20:54
SOLD 2003 Jetta GL TDI $12,900 LOUISVILLE,KY jaclou TDI Cars for Sale/Wanted 1 March 20th, 2005 21:48
Page generated in 0.17560 seconds with 10 queries
[Output: 130.78 Kb. compressed to 109.66 Kb. by saving 21.12 Kb. (16.15%)]
