Old February 27th, 2018, 13:00   #1
Chris_TDI_98
Fuel Economy: 35 mpg with leaking injection pump
Lightbulb Double DIN radio in a mk3 dash ??
I'm starting to explore the possibility of what it would take to modify the dash in a mk3 TDI to install a cheap Double DIN radio (android 8.1 7inch touchscreen 4GB RAM 32GB storage, GPS, 4G LTE, digital radio, digital TV).
* Has anyone installed a Double DIN "2DIN" radio in a mk3 dash??
* What did you cut out / remove / relocate?
* Share your before/during/after pics and videos of your modification!!
Chris_TDI_98 is offline   Reply With Quote
Old February 27th, 2018, 13:17   #2
Mongler98
*yes, plenty of us
*cut out top vents and plug off and remove some of the duct behind them, some plastic welding and bondo and paint.
Do a search here and on VWVORTEX. plenty of pictures and there should be a DIY somewhere.
Old February 27th, 2018, 17:16   #3
Chris_TDI_98
Would this be a good time to fix blend door issues, since my heat is blowing rather lukewarm tepid warm, about a 2 out of 10 in warmth, in other words, is the heat system (blower + heater core + ducts) going to become all sealed away and much more difficult to get to and fix AFTER doing this Double DIN android head unit mod??
Old February 28th, 2018, 05:34   #4
Mongler98
no, you can do all the work for a 2xdin with out removing the dash, you must remove the dash to do the core. its a big job, not hard, just a lot of work. Check out some of the others who turned that unless space next to the cup holders into a 2xdin area with a tiny bit of work and there is a gauge pod that can replace the single up top.
Old February 28th, 2018, 15:21   #5
Chris_TDI_98
Thanks Mongler98. I found many 2DIN mk3 threads on vwvortex, but all the pics are expired photobucket error messages "remote image hosting disabled"... so annoying!! How on earth are we supposed to see how they did it. I hate photobucket.
Old February 28th, 2018, 18:54   #6
Mongler98
message the user and ask for pictures. Honestly, you can do it, just practice some plastic welding and bondo work, the rest is kinda, make it fit and delete the top 2 vents, im sure you can find a few pictures of the finished results. But those were done back before single din pop up ones, id just get a single that has the touch screen pop out and be done with it.
Radio Pinouts - Premium VI Radio (Double-DIN unit) Michael Moore General VW Discussion 2 March 1st, 2017 08:41
Pioneer P4200DVD Double Din IN-DASH DVD / TV / iPod / HD Radio - EVERYTHING INCLUDED! TDI-JAY Private TDI Items for Sale/Wanted 6 March 21st, 2013 14:52
Installing single-DIN radio in place of double-DIN Premium 6 nukefission Upgrades (non TDI Engine related) 3 February 9th, 2009 09:19
conversion from single din to double din radio/cd. silverbeast Upgrades (non TDI Engine related) 7 June 25th, 2005 11:41
conversion from single din to double din radio/cd. silverbeast VW MKIV-A4 TDIs (VE and PD) 0 May 26th, 2005 14:18
Page generated in 0.15224 seconds with 10 queries
[Output: 73.36 Kb. compressed to 64.56 Kb. by saving 8.81 Kb. (12.00%)]
