Old February 27th, 2018, 10:30   #1
Aato
Default Passat B6 Coilover questions
Hey guys, I'm thinking about picking up a set of coilovers for my passat B6 next week. Can anyone walk me through the procedure and also if possible tell me the torque specs on all the bolts when I'm putting them back in. I've installed coilovers before so I have a brief idea what I'm doing but I want someone elses input just incase I'm forgetting something!
Aato is offline   Reply With Quote
Old February 27th, 2018, 10:44   #2
PB_NB
PB_NB's Avatar
When working on our B5, we had of make sure that the weight of the car was on the suspension and all those little steering linkages before the final tighten. We discovered this after changing a bunch of the parts. Everything was torqued down while that car was suspended in the air. Then when we put it on the ground the new parts wore out quickly. So we had to do it again.
I am not too sure what the B6 looks like but if it is similar to the B5, I would consider that when doing any suspension work.
My MK4 (Beetle) is more forgiving when working on the suspension etc...
Should be nice once it is done!
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old February 27th, 2018, 11:34   #3
Aato
Thats interesting, thanks for the advice. My start a little project thread soon and upload some pics!
Old February 27th, 2018, 12:38   #4
20IndigoBlue02
20IndigoBlue02's Avatar
A b6 is just like a MKV Golf/Jetta.
http://www.myturbodiesel.com/wiki/st...i-and-audi-a3/
2016 Tiguan SE 4Motion
20IndigoBlue02 is offline   Reply With Quote
Old February 27th, 2018, 13:06   #5
Aato
That's a really helpful write up thanks for the link! Has all the torque specs too. As for the counterholder tool I assume the spark plug socket with allen key down through the middle will do the same thing? I dont have the strut spreader bit either I usually just used to spray around the bottom of the strut and loosen it by hitting with a rubber hammer but I might pick up the spreader to make life easier!
Old February 27th, 2018, 13:10   #6
20IndigoBlue02
A gear ratchet pass-through set will be easier.
https://www.amazon.com/GearWrench-89.../dp/B0002U2ODO
You can hold the allen key and wrench the nut off with the other hand.
If you have an air-powered impact wrench, you don't really need to counterhold it. It just zips it off.
Old February 27th, 2018, 13:46   #7
RexNICO
TDI(s): None
Originally Posted by PB_NB View Post
When working on our B5, we had of make sure that the weight of the car was on the suspension and all those little steering linkages before the final tighten. We discovered this after changing a bunch of the parts. Everything was torqued down while that car was suspended in the air. Then when we put it on the ground the new parts wore out quickly. So we had to do it again. ...
That should have been due to the pinch bolt/upper control arm & top hat configuration. In that case the upper control arms need to be installed/tightened into the top hat at the angle they would be when on the car, on the ground at rest. If tightened at any other angle, the bushings in the upper control arms are under a constant "twist".
Long story short, I don't think the Passat B6 chassis uses the same type of UCA, thus shouldn't have this same issue.
Recently relocated from OH to GA, let the warm weather begin!
VW/Audi Auto-dim Rear view mirror FS
B5/5.5 Wagon Cargo Covers
RexNICO is offline   Reply With Quote
Old March 1st, 2018, 08:00   #8
Aato
Do you guys recommend I get adjustable drop links also or are they needed?
B6 Passat? 1854sailor TDI Conversions 13 October 29th, 2015 11:34
TDI ALH on a B6 Audi, ESP questions A4-TDI TDI Conversions 2 October 25th, 2015 14:39
FS: Passat CC TDI cluster - White display - to fit Passat B6 Jarek Private TDI Items for Sale/Wanted 2 December 28th, 2011 12:08
Another B5.5 Passat or RISK waiting for B6 Passat tdireader VW B5 Passat TDIs 19 March 15th, 2005 19:19
New B6 Passat TDI Questions/Comments whitelite777 VW B5 Passat TDIs 16 December 17th, 2004 14:19
Page generated in 0.14676 seconds with 10 queries
[Output: 86.50 Kb. compressed to 74.50 Kb. by saving 12.00 Kb. (13.87%)]
