Old February 26th, 2018, 14:21   #1
Chino
Default Extended warranty after Emissions fix
Had a CEL come on and fault codes seem to point to DPF bank 1 sensor. Would this be covered under the extended warranty VW after the fix was performed.
Chino is offline   Reply With Quote
Old February 26th, 2018, 15:00   #2
fredthe
It may be, but I've found it depends if that part is on the actual list of covered items. I had a CEL for the AdBlue heater, and the dealer said it wasn't covered but that I should call VW Customer Care. I did that, and the next day VW agreed to cover it.
best advise is to take it to a dealer, and be ready to suggest to VW that it should be covered as part of "The entire exhaust after treatment system."
fredthe is offline   Reply With Quote
Old February 26th, 2018, 15:20   #3
Chino
Thanks. I have appointment with dealer tomorrow.
Old February 27th, 2018, 21:55   #4
Lightflyer1
Lightflyer1's Avatar
Also don't forget it says all disputes should be decided in the favor of the customer. Keep that one in your back pocket just in case.
Old February 28th, 2018, 10:36   #5
joshuafail
It should be. The extended warranty specifically states sensors, valves and actuators related to the emissions system are covered. If you’ve had any part of the fix done, you’re covered. If you haven’t had fixes done yet they could require you to fix it before modifying the vehicle but since this is an emissions component that would otherwise be covered, I don’t see why they’d give you grief over it.
joshuafail is offline   Reply With Quote
Guidance on extended warranty vs extended emissions warranty - ‘14 Tourareg azdmelissa Dieselgate - VW Group Emission Scandal 4 January 29th, 2018 20:42
Extended Emissions Warranty Clarification Fastbird Dieselgate - VW Group Emission Scandal 12 November 8th, 2017 06:44
Extended emissions warranty on new cars ? 2010golf Dieselgate - VW Group Emission Scandal 16 June 7th, 2017 15:02
Gen 3 fix extended warranty nectarguru VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 25 February 15th, 2017 14:16
Extended Emissions Warranty kevincook Dieselgate - VW Group Emission Scandal 2 September 7th, 2016 11:59
Page generated in 0.15327 seconds with 10 queries
[Output: 68.18 Kb. compressed to 60.36 Kb. by saving 7.82 Kb. (11.47%)]
