Old February 26th, 2018, 00:06   #1
Hunter489
TDI(s): 2000 ALH
Default Loose Vacuum/Brake Booster Hose
My hose that runs from the brake booster to the Vacuum pump on my 2000 1.9 alh is loose and wiggly. I was told that is no good. It is loose at the Vacuum side. Here are some pictures. Where could I find the parts to fix this? Also. In the second picture is this black zip tie factory??
Hunter489 is offline   Reply With Quote
Old February 26th, 2018, 00:08   #2
Hunter489
TDI(s): 2000 ALH
shniiikks... Is this it?? looks like it.
https://www.idparts.com/vacuum-pump-...alh-p-785.html
Old February 26th, 2018, 09:01   #3
Steve Addy
TDI(s): 97 Mk3
Yes, that's the correct part. You might have some luck finding a good replacement if you look in the FS section or post your issue in the Mk4 forum. This forum is for Mk3 and B4 cars, the generation before yours.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is online now   Reply With Quote
Old February 26th, 2018, 09:45   #4
JETaah
Fuel Economy: 53 max, 42 min, average 46
If it is the pump nipple that is loose, there are a few ways to deal with this without buying a new vacuum pump.
Here is a tried and true way that I found that is a lasting repair:
http://forums.tdiclub.com/showthread...=LOOSE+NIPPLES
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is offline   Reply With Quote
Old February 26th, 2018, 09:57   #5
JETaah
And, no, the zip-tie is not factory.
On some cars (Golfs?), that tube came covered with the rubber hose over the barbed fitting joints because the hard plastic vacuum tube tends to crack in those areas. It would not hurt to check under the cover hose for cracks. It is very common.
Old February 26th, 2018, 12:26   #6
hey_allen
From the factory, the hard plastic would have gone all the way onto the elbow that is pressed into the grommet in the Vacuum Booster.
I was a cheapskate and made a replacement hose for mine, with a length of air brake hose from a local auto parts store, but they're not that expensive to buy the whole assembly, as long as you don't mind waiting for shipping.
I would strongly recommend taking care of it, one way or another!
This caused a couple of nearly panic inducing moments when I lost brake assistance on an offramp, prior to fixing it.
hey_allen is online now   Reply With Quote
Old February 26th, 2018, 16:11   #7
Abacus
That helpful B4 guy
Abacus's Avatar
I'll move the thread.
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Replacment of Brake Booster Vacuum Hose PDJetta VW MKIV-A4 TDIs (VE and PD) 32 August 13th, 2016 16:30
Brake Booster vacuum hose now p0299 code slim83 VW MKIV-A4 TDIs (VE and PD) 3 September 1st, 2015 03:59
brake booster vacuum hose WillyGee VW MKIV-A4 TDIs (VE and PD) 4 October 11th, 2013 07:04
Multiple DTC's / Check the Vacuum hose going to the brake booster terrydtdi TDI 101 0 November 7th, 2010 18:50
Brake booster vacuum hose Sc0 TDI Power Enhancements 4 August 23rd, 2003 11:54
Page generated in 0.16773 seconds with 10 queries
[Output: 80.91 Kb. compressed to 70.29 Kb. by saving 10.63 Kb. (13.13%)]
