Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old February 25th, 2018, 16:47   #1
Default Black smoke on acceleration
Changed air filter and still get black smoke. Otherwise the car runs fine with no OBD
Chris10 is offline   Reply With Quote
Old February 25th, 2018, 17:02   #2
Intercooler hose loose or popped off check all the piping especially behind the passenger side front wheel.
Tdijarhead is offline   Reply With Quote
Old February 26th, 2018, 08:02   #3
oilhammer's Avatar
Fuel Economy: fantastic
Does the car have stock software? Some tunes with certain nozzles will make for a smoky combination.
Old February 27th, 2018, 09:58   #4
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Injection timing retarded (i.e., fuel being injected late)? The injection timing should be kept up close to the advanced edge of the spec but still within spec.
The timing will retard slightly as the timing belt stretches a little bit over its life. When was the timing belt last changed and who did the work? How was the injection timing verified after the timing belt change? If the "mark and pray" method was used during a timing belt change, it's totally wrong and needs to be fixed because valve timing and injection timing are both retarded. If that's the case, get the car to one of the TDIclub gurus like oilhammer to straighten it out.
Good luck and Welcome to TDIclub.
David Sterrett, N1DAS
2014 BMW (F10) 535d XDRIVE M-Sport, 255hp & 413 lb-ft of AWD stomp 'n go fun!
2012 BMW (E70) X5 XDRIVE35d, 265hp & 425 lb-ft of AWD stomp 'n go fun!
Why DIESEL is better:
n1das is online now   Reply With Quote
Old February 27th, 2018, 11:06   #5
PB_NB's Avatar
Along with all these great suggestions, check to see if the snow screen is plugged or hosting rodent nest. Mine was crushed when an idiot backed into my driver side front fender on the Beetle.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
black smoke on acceleration lowflyer TDI Fuel Economy 18 August 17th, 2011 23:24
Recommendations? Black smoke during acceleration sashburn VW MKV-A5 Golf/Jettas 6 August 19th, 2009 20:04
Black smoke even under mild acceleration Sevenjays TDI 101 5 May 20th, 2009 00:04
black smoke at acceleration peugeot309 TDI 101 20 September 30th, 2006 11:35
Pop, Black Smoke no Acceleration. patstdi VW MKIV-A4 TDIs (VE and PD) 5 October 12th, 2001 14:52
Page generated in 0.12893 seconds with 10 queries
[Output: 69.99 Kb. compressed to 61.81 Kb. by saving 8.18 Kb. (11.68%)]
