Old February 24th, 2018, 16:53   #1
Hunter489
TDI(s): 2000 ALH
Default TDI chugging/Choppy Idle
My 2000 TDI ALH seems to chug or idle choppy when I am braking with the clutch in and coming to a stop or sometimes just at idle. The piece I'm pointing to in the picture is loose and wiggly. Also in the other picture is a black zip tie and I'm not sure if that is factory or was put there. So question is where can I find the piece and should I get the whole piece from the brake drum to the Engine.
Also what is the correct battery for our cars?
http://http://i1151.photobucket.com/...psw7ymg7pc.jpg
Hunter489 is offline   Reply With Quote
Old February 24th, 2018, 17:53   #2
UhOh
UhOh's Avatar
Photobucket doesn't work (unless folks PAY for it), so, for most we're still blind here... Upload to this site's Photo section or some site that provides free hosting.
Old February 24th, 2018, 19:04   #3
Jesus Is Lord
Fuel Economy: 34 Towing 42 Average 53 Highway
I couldn't see the pictures. But besides that, it sounds like it could be the injection quantity adjusted too rich. It could easily be checked with VCDS.
"True humility is not thinking less of yourself; it is thinking of yourself less". C.S. Lewis
Jesus Is Lord is offline   Reply With Quote
Old February 24th, 2018, 19:56   #4
PB_NB
PB_NB's Avatar
I had the same thing with my ALH when I first got it. It would idle rough when slowing and as soon as I came to a stop, it would smooth out. Eventually I found this forum and found out about the IQ adjustment. Adjusted the IQ and the problem was fixed.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old March 2nd, 2018, 05:28   #5
Powder Hound
Powder Hound's Avatar
So you're gonna need to find someone with a VCDS that is willing to plug into your car and find out what the IQ is currently reading. From there, after reading up on it here on this site, you will be able to adjust the IQ using the hammer mod technique. Oh, and you'll need the correct torx bit as well as the magic triangle security bit/socket for the security bolt on the top of the injection pump. Without that, you'll just break stuff, and broken injection pumps are pricey to fix.
That is assuming that it in fact is the injection pump IQ that needs an adjustment. So what is the problem with the zip-tied item? Like above, until we can see it, we can't hope to help. Please, look at posting photos on this site.
Cheers,
PH
Old March 2nd, 2018, 05:29   #6
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Search for "slow down shudder".
oilhammer
www.cardocautomotive.com
Mk4 golf tdi rough idle, chugging, and white/blue smoke SilversJ VW MKIV-A4 TDIs (VE and PD) 3 January 5th, 2016 10:42
smokey and choppy cold starts AmIdYfReAk VW MKIV-A4 TDIs (VE and PD) 13 October 2nd, 2014 19:43
Bad idle and chugging! Savageman69 VW MKVI-A6 Jetta Sedan (~ 2011+) 1 May 1st, 2011 18:18
Golf runs 'choppy' when started? bruzer_boy VW MKIV-A4 TDIs (VE and PD) 8 May 16th, 2010 06:17
Choppy front tires ralphy6177 TDI 101 12 October 2nd, 2009 04:54
Page generated in 0.14494 seconds with 10 queries
[Output: 75.83 Kb. compressed to 66.38 Kb. by saving 9.44 Kb. (12.46%)]
