Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old February 24th, 2018, 07:56   #1
Default Ideas to solve ckp sensor
Hi all. I own 2.5 tdi afb engine that was tiptronic 5 speed hp19 quattro and I put gearbox fwd 6 speed mt from same car model engine but manual. The problem was timing jumping all over the place after conversion. When i disconnect ckp sensor all readings get better so my guess is the location off sensor on tiptronic that is way far down but i trought the dual mass flywheel would conpensate for that but i guess i was wrong. Do you know if crankshaft automatic to manual are difrent? Any idea to solve ckp sensor? Maybe simulator? Tks in advance.
Car audi a6 2.5 tdi afb quattro 1999 converted to 6 speed mt fwd
Ningush is offline   Reply With Quote
Solve an arguement for me...Please psaboic Fuels & Lubricants 18 December 4th, 2012 08:48
CKP Sensor goober4321 VW MKIV-A4 TDIs (VE and PD) 2 May 25th, 2012 08:29
Please help solve a mystery. spoilsport VW MKIV-A4 TDIs (VE and PD) 4 January 16th, 2010 17:32
Any ideas why Engine Coolant Temp. Sensor (G62)? Santa_Fe VW MKIV-A4 TDIs (VE and PD) 4 August 20th, 2005 21:01
Where's the squeak? and how to solve? cody VW MKIV-A4 TDIs (VE and PD) 4 April 7th, 2003 08:38
Page generated in 0.09971 seconds with 10 queries
[Output: 46.12 Kb. compressed to 43.45 Kb. by saving 2.67 Kb. (5.79%)]
