Old February 23rd, 2018, 18:38   #1
bwk9087
TDI(s): 2003 1.9 ALH
Default Jeep Wrangler JKU build
Well, it is time for me to start posting on here, after lurking, learning, studying, and gathering parts for my swap for a year. What I have is a 2007 Jeep Wrangler, that orignally had the 3.8 motor, with the nsg370 6 speed trans, and is now getting an alh out of a 2003 wrecked jetta auto I bought.
Here is another inside, ready to start
Parts I have acquired so far are, HPA trans adapter, and Crankshaft adapter. GTB1756vk turbo and manifold from X-man. Pd 150 intake. Race 520 injectors. Malone stage 5 tune with immobilizer delete. Spec stage 2 clutch. Front mount intercooler, Plus alot of other small stuff.
bwk9087 is offline   Reply With Quote
Old February 23rd, 2018, 18:42   #2
bwk9087
Default getting ready to pull the motor
Front of Jeep is off, and tagging sensors, and wires.
Old February 23rd, 2018, 18:46   #3
bwk9087
Engine, trans, and transfer case is out.
Old February 23rd, 2018, 18:48   #4
bwk9087
Engine mated to 6 speed trans
Old February 23rd, 2018, 18:51   #5
bwk9087
Engine in for first fitting.
Old February 23rd, 2018, 18:56   #6
bwk9087
Bought universal mounts from EVGuy, but HPA put starter on passenger side, so the passenger side needed to be modified in order for starter to fit. Cut half of mount off, and added a piece on front of block so far. Driver side is good.
Old February 23rd, 2018, 19:15   #7
Owain@malonetuning
Nice work! You're going to love that turbo, great size for these things.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old March 1st, 2018, 02:46   #8
bwk9087
Engine is in for final time, hopefully, as mounts are done now, and everything is bolted in. Moving on.
Old March 1st, 2018, 02:49   #9
bwk9087
Pedal is mounted in. It bolted into place of the jeep pedal, but hit the carpet hard, so I had to move it over and down.
before
after
moving on to mounting fuel filter, and running line.
Old March 1st, 2018, 06:29   #10
samuraitd
samuraitd's Avatar
Looking good! What turbo is that?
1986 Samurai AHU MTDI swapped, stretched, built
samuraitd is offline   Reply With Quote
Old March 1st, 2018, 06:57   #11
bwk9087
that is the gtb1756vk.
Old March 1st, 2018, 17:59   #12
Motohead1
Looks great! No AC?
Dodge Dakota QC Tdi
Motohead1 is offline   Reply With Quote
Old March 2nd, 2018, 06:12   #13
bwk9087
Originally Posted by Motohead1 View Post
Looks great! No AC?
I plan to have ac later. It looks to be able to fit above the power steering for a high mount. I just finished the pulley to drive it off the power steering pump. I also machined down the jeep cam gear that has the tone wheel on it to fit on that also, so I can get my guages working. I still have to mount my fix for the crank tone wheel to the front crank pulley.
Old March 2nd, 2018, 18:56   #14
Motohead1
Yea there is room up there for AC as I thought about going the route but getting the belt to get enough bite up there was gonna be a challenge.
As for your cam and crank signals I could be wrong but I think you could use a dakota digital box and not have to worry about any tone rings. My truck is similar to your jeep I believe. But maby there is a CAN buss issue I am not thinking of at the moment?
Dodge Dakota QC Tdi
Old March 2nd, 2018, 19:34   #15
bwk9087
I thought the compressor would be better with its own adjustable separate driven pulley. I still might go with the dakota box for the crank. I have a tone ring to try, already, I will call the dakota box a backup plan, for now till I try the other stuff I have already.
2008 Jeep JKU / TDI swap evguy1 TDI Conversions 50 January 5th, 2019 10:11
Diesel Jeep Wrangler Kriesel Non VW Group Diesels 0 February 11th, 2012 14:13
Jeep Wrangler Will Come in Diesel Form chewy Non VW Group Diesels 5 November 11th, 2009 04:08
Jeep Wrangler CRD? tditom Non VW Group Diesels 8 May 13th, 2009 19:00
TDI to Jeep Wrangler SpotsPhiLL TDI Conversions 3 August 3rd, 2008 16:14
Page generated in 0.19194 seconds with 10 queries
[Output: 125.13 Kb. compressed to 104.57 Kb. by saving 20.57 Kb. (16.43%)]
