Old February 28th, 2018, 06:03   #16
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Inner boots are not that big of deal. No specialized tools unless you mean the triple square to get the axle off the flanges.
I am still riding on original outer boots at 410K miles.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is online now   Reply With Quote
Old March 5th, 2018, 14:19   #17
Rob Mayercik
Maybe the output speed sensor (G68) is acting up, but not enough to trigger its own code?
I just had the G68 sensor (output speed) go out on my car, was out on the highway cruising and out of nowhere it seemed to drop out of overdrive into 3rd. I pulled over and shut off/restarted the engine to power-cycle the TCU, and then it wouldn't go into D until around 3200 RPMs (and harshly at that). Local roads at that point were 3 only - no lower gears. Took it easy to get it home and found the code for that and the one you have (P0740).
I parked mine until I could get the sensor changed (G68 is the one under the trans mount, and a royal pain to get to). Since both my sensors were original at 360,900 miles, I had the G38 (input speed) changed as well as insurance. I also had a fluid/filter change done (partly because it had been a year since the last change, and partly to ensure we weren't putting good sensors into a failing trans), and the fluid was clean, so the sensors were thankfully the only issue. I even think the TCC Lockup code was caused by the G68, since it meant the TCU wasn't getting good info on what speed the car was going.
(Edit) No, I'm not on the original trans in my car.
2002 Jetta GLS TDI Automatic
Baltic Green/Beige Leather
Rob Mayercik is offline   Reply With Quote
Removing axles - Grease on inner joint-to-transmission mrrhtuner VW MKIV-A4 TDIs (VE and PD) 4 August 19th, 2017 10:56
Automatic Transmission Components + Axles + Extras s.pavel6 Private TDI Items for Sale/Wanted 12 June 3rd, 2011 22:54
Drive Axles - Best Place to Buy in Southern Ontario M2B Ontario 10 June 2nd, 2011 15:41
Axles and Transmission Computer for sale.. NewOwner Private TDI Items for Sale/Wanted 0 February 14th, 2011 07:00
VR6 Axles? Where to buy? sk8rdi16 VW MKIV-A4 TDIs (VE and PD) 5 January 27th, 2007 06:47
Page generated in 0.14066 seconds with 10 queries
[Output: 55.35 Kb. compressed to 51.00 Kb. by saving 4.35 Kb. (7.86%)]
