Old February 23rd, 2018, 07:20   #1
charlieruu
Fuel Economy: who cares
Default What Axles to buy and transmission questions?
I have an 02 alh auto. I'm wondering what Axles are safe to buy. I don't have enough $ to go oem. Are there any other options that don't suck? Also, my transmission has been slipping every five days or so. Sometimes it slips going 1st to 2nd and sometimes in 4th. I got the P0740 code about a year ago and I haven't done anything because I just clear it and my rpms while cruising are normal. Why is it slipping on some days and then completely fine on others? Sometimes I will shut my car off when it happens and when I restart the transmission will shift properly. Is it worth it to buy new axles with a sucky transmission? Last question, will stiffer dogbone inserts make it easier for my transmission to shift? Thanks to anyone who can help answer these!
charlieruu is offline   Reply With Quote
Old February 23rd, 2018, 07:22   #2
charlieruu
P.S. I'm looking on ECS and I see 2 non OEM companies that fit mine. GSP and OP PARTS. I also looked on NAPA and they have MaxDrive axles for pretty cheap. If any of those are good at all, let me know.
Old February 23rd, 2018, 07:39   #3
jokila
jokila's Avatar
Fuel Economy: 52/45/40
If you research this site it will not take you long to find automatic transmission woes and how bad that transmission is. Many people cure it with doing a 5 speed swap.
I would think spending money on axles with some gears in the grave and others on a banana peel is going to be money poorly spent. Are the axles bad? You can rebuild the original axles inexpensively.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old February 23rd, 2018, 07:39   #4
KLXD
Ever changed the fluid and filter?
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old February 23rd, 2018, 07:42   #5
charlieruu
Yeah I'm well aware of the 01m's repuatation but I was wondering if there is a specific reason that someone might know
Old February 23rd, 2018, 07:43   #6
charlieruu
Thought of it but I have always heard that that could cause more bad than good.
Old February 23rd, 2018, 07:44   #7
jokila
jokila's Avatar
What's up with the axles? broken boots? The OEM axles are high quality and worth putting maintenance.
Old February 23rd, 2018, 07:54   #8
charlieruu
Driver side is ripped. Not horribly by any means considering there are no signs of problems yet, but I'm preparing for the worst. Also, I don't think it's worth it to put OEM in when the transmission is going out. OEM would set me back around $600+ and that's not too far away from what a 5 speed swap would cost me.
Old February 23rd, 2018, 08:25   #9
jokila
jokila's Avatar
Inner boots are easy to replace. Boot kit is $25 per side. Outers are cheaper.
https://www.idparts.com/cv-boot-kit-...to-p-2165.html
https://www.idparts.com/cv-boot-kit-...to-p-1734.html
Old February 23rd, 2018, 08:41   #10
SilverGhost
SilverGhost's Avatar
If the axles are not clicking and the grease still looks clean (not full of water and sand, etc.) then just put new CV boots on. If you need axles then check out Raxles Axles. Life time warranty and better than OEM.
But then why throw good money away if the trans is done? In my years of working on these things I have learned that by the time you notice something wrong (slipping, MIL for trans) the adaptive logic has been hiding the problem too long and the damage is done. Cost to fix, at this point, is usually always more than replace.
Jason
SilverGhost is offline   Reply With Quote
Old February 23rd, 2018, 09:32   #11
drucifer
What would you do if tomorrow the trans said I've had enough I'm not moving this car one more inch? If you have other means of transportation do the 5 speed swap now and get it over with.
Your 01m has at least 230k on it. It doesn't owe you anything but could if it leaves you stranded far from home.
drucifer is offline   Reply With Quote
Old February 23rd, 2018, 10:03   #12
charlieruu
Your 01m has at least 230k on it. It doesn't owe you anything but could if it leaves you stranded farrow home.
I should've been more clear. The transmission has around 100k on the rebuild. I bought it from a mechanic in my area who owns mk4's and he did the rebuild before I bought it. I still have him work on it and he has a full 5 speed swap at his disposal. Just need to talk pricing and labor. He said the only car he believes should get a manual swap is the alh autos.
Old February 23rd, 2018, 11:11   #13
jokila
jokila's Avatar
That's a whole lifetime for that trans.
Old February 24th, 2018, 16:43   #14
drucifer
This thread penned by coolairvw has a lot similarities to your situation.
http://forums.tdiclub.com/showthread.php?t=252885
Old February 27th, 2018, 16:58   #15
garciapiano
The 01M is a horrible, outdated transmission. I know because I drive one. However, mine has 185,000 original miles on it and still runs strong.
Lots of people are going to recommend a manual swap, which is definitely ideal, but these cars are getting so old that it's not even worth swapping them (buying a new manual car is nearly the cost if not cheaper than sourcing parts for the swap and labor). Thankfully, TDI ECUs have the option of switching over to manual mode, unlike the gassers.
So, if you have to stick with your 01m for the time being, it's not a big deal. They get a bad rap but they're not really as bad as some others. What they DEFINITELY are is temperamental when it comes to fluid and fluid level. Slipping in the trans can be caused by a worn valve body, worn clutches or too little transmission fluid. Fill level is CRITICAL in this trans for proper operation but they will run, albeit poorly, a whole quart short.
That being said, you can prevent complete failure of the trans if you take some precautions. The first step is to change the ATF and filter. This is well-documented and relatively simple procedure. You will need a few tools to do so, namely a fluid pump, torque wrench and an infrared thermometer. A proper fluid change and fluid level will likely make the trans shift better, however the change does not change ALL of the fluid in the transmission. You are replacing about 60% of it. Thus it takes several changes to get all of the bad, burnt old fluid out.
The other thing you should change is the differential oil. This is accessed on the top, back side of the trans underneath the speed sensor port.
As for your axle issues, stick with OEM axles. You don't need a new axle. Just pull off the existing axle and replace the boots on it. This is a messy job to DIY, and does require several specialized tools, so if it means taking it to a shop, so be it. But I did it myself in my garage, so you probably can too.
garciapiano is offline   Reply With Quote
Removing axles - Grease on inner joint-to-transmission mrrhtuner VW MKIV-A4 TDIs (VE and PD) 4 August 19th, 2017 09:56
Automatic Transmission Components + Axles + Extras s.pavel6 Private TDI Items for Sale/Wanted 12 June 3rd, 2011 21:54
Drive Axles - Best Place to Buy in Southern Ontario M2B Ontario 10 June 2nd, 2011 14:41
Axles and Transmission Computer for sale.. NewOwner Private TDI Items for Sale/Wanted 0 February 14th, 2011 06:00
VR6 Axles? Where to buy? sk8rdi16 VW MKIV-A4 TDIs (VE and PD) 5 January 27th, 2007 05:47
Page generated in 0.16734 seconds with 10 queries
[Output: 132.81 Kb. compressed to 111.30 Kb. by saving 21.51 Kb. (16.20%)]
