Old February 22nd, 2018, 20:43   #1
Houpty GT
Houpty GT's Avatar
TDI(s): Corrado
Fuel Economy: 56 avg.
Default How injector flow quantity is adjusted and pilot injection delete
This was the only thread I found about staged flow settings that certain vendors are selling.
http://forums.tdiclub.com/showthread...e+flow+setting
Originally Posted by Wankel7 View Post
The Kerma description of the stages are a little different ....
STAGE 1- LOW SMOKE FOR CLEANEST OPERATION [ IDEAL FOR STOCK OR LIGHTLY MODIFIED VEHICLES, OR FOR MODIFIED VEHICLES SEEKING BEST FUEL ECONOMY ]
STAGE 2 - LOW SMOKE FOR TUNED VEHICLES
PLEASE NOTE: STAGE 1 IS THE MOST POPULAR SETTING AND WE CAN ALWAYS RECALIBRATE
STAGE 3- FOR VEHICLES WITH TURBO, TUNE, CLUTCH AND ALSO EXHAUST, CAMSHAFT, AND INTERCOOLER UPGRADES
STAGE 4 - FOR VEHICLES WITH ALL OF THE ABOVE AND FULL UPGRADES INCLUDING CAMSHAFT, EXHAUST, INTAKES AND CYLINDER HEAD WORK HIGHER SMOKE, REDUCED MPG'S AND NOT FOR DAILY DRIVERS
STAGE 5 - EXTREME CUSTOM SETTINGS FOR VERY HIGHLY MODIFIED VEHICLES
So what changes are these flow settings? Since they make no changes to the nozzles and they can not control the pump, that leaves them with
1. shims controlling spring preloads. Reducing the cracking pressure for the main injection so it opens sooner and closes later. This makes sense since they say, "fuel delivery will occur over a slightly longer period of time."
2. spring stiffness. Changing to a different spring so that the needle will lift higher and longer but not sooner.
Would be the same deal with the increased pilot injection?
Has anyone eliminated their pilot injection for more power or economy? I recall it was worth 3 or 5% in some scientific journal.
See this thread on information on diesel injector function and some discussion on removing the pilot injection: http://forums.tdiclub.com/showthread.php?t=352275
MK3 delete
Houpty GT is offline   Reply With Quote
Old February 23rd, 2018, 05:28   #2
Mongler98
i have no freaking idea, but i do know that when i send money to kerma, i get more fun vroom vroom and get to roll more coal on the hippies and Porsches, loving my PP764 staged 4
Old February 23rd, 2018, 06:25   #3
jimbote
jimbote's Avatar
isn't this how Frank was setting main event pressures at Dan's gtg ? by replacing the pilot spring with a solid pellet? ... go for it ! i'm interested to see the results in economy/power as well as sound ... i'm sure it'll have mas clatter
jimbote is online now   Reply With Quote
Old February 23rd, 2018, 10:24   #4
Exenos
TDI(s): 02 Golf
Would It make more sense that he would be shimming the pilot spring with that pellet? It looks like the pilot still needs to be able to move.
Exenos is offline   Reply With Quote
Old February 23rd, 2018, 11:30   #5
jimbote
jimbote's Avatar
could be, i waa watching the procedure but not terribly close
Old February 23rd, 2018, 14:19   #6
Houpty GT
Houpty GT's Avatar
TDI(s): Corrado
Jimbo, I don't remember any of that. With no pilot, I think it would need a degree or 2 less advance since the power stroke would come on quicker than it normally expects.
MK3 delete
Old February 23rd, 2018, 15:49   #7
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
More emissions, PCP and diesel clatter are not desirable trade-offs to me for an unnoticeable difference in real world FE when similar magnitudes can be achieved with less compromising measures elsewhere. Three steps backward and (barely) 1 forward...
Old February 24th, 2018, 16:32   #8
[486]
TDI(s): 02 golf ALH
If you've got a surface grinder it's pretty easy to jig up the pintles to take a few thousandths off the spring end of them and get more lift, it also increases the amount of fuel delivered on the first stage of operation, which I've seen as an additional touted 'benefit' of the same people. Retains the two stage operation as the central rod for the first stage spring will still reach down into the nozzle body to push on the shorter pintle.
on mine I just cut the shelf off the top hat shaped bit, then took it down another .004"
single stage operation (able to set up with a simple pop tester) and similar 'more lift' without needing to grind on the nozzle components
ETA:simple little MS paint drawing on how the single stage conversion works
[486] is online now   Reply With Quote
Injection Quantity (IQ) Nozzle Size - Quantity Adjuster (QA) relationship mnorton TDI Power Enhancements 34 May 1st, 2018 07:30
adjusted injection pump manually GotEuroCorrado VW MKIII-A3/B4 TDIs 13 March 18th, 2005 09:24
has anybody adjusted the injector flow rate? 03_01_TDI TDI Fuel Economy 3 June 20th, 2004 11:38
I am having my injector pressure adjusted how high should I go? Drivbiwire VW MKIV-A4 TDIs (VE and PD) 9 June 28th, 2001 10:34
Adjusted my injection timing Drivbiwire VW MKIV-A4 TDIs (VE and PD) 16 August 3rd, 2000 22:02
Page generated in 0.13977 seconds with 10 queries
[Output: 91.42 Kb. compressed to 78.92 Kb. by saving 12.50 Kb. (13.67%)]
