Old February 22nd, 2018, 12:48   #1
larboc
TDI(s): 1998 Jetta
Default Swapping TDI from rusted jetta into gas jetta?
I have a rusted out TDI 1998 jetta with 350k on it that runs/shifts great but the body is falling apart. I see clean low mile MK3 jettas with snapped timing belt gas engines showing up on CL all the time for well under $500. In my mind I should be able to just unbolt and swap the subframe, cooling system, and ECU and be on my way? I'm guessing it isn't that simple, but I'd guess someone has attempted it before. All the tdi cars seem to either be expensive or ragged out.
As long as I stay in the same 97-99 body style, are there any pitfalls to watch out for? I'm tempted to look at VR6's for the bigger brakes but fear that that might overcomplicate things at the front when it comes to using the VR6 5 lug hubs/brakes on the subframe. A vr6 in my rusted out tdi's body would make an awesome bump-n-run car too!
larboc is offline   Reply With Quote
Old February 22nd, 2018, 14:10   #2
Mongler98
that and a fuel tank and wire harness, yea, not much more to swap to make it a TDI, plenty of threads where people do this. do a search.
Old February 22nd, 2018, 18:53   #3
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
I'm not convinced that any mk 3 north of Tennessee is "clean".... I would look closer at the floor pan. Lol.
Considering you have a full donor car, any pre1999.5 Jetta, golf or even up to a b5 Passat is a straight forward swap. No serious pitfalls to watch out for.
2003 Jetta TDI - 11mm IP, “stage 1ish” DIY tune.
1996 Passat TDI - "Red Death" RETIRED but still owned. Had a Malone stg 1 tune, 11mm pump, R520, GT15/17 hybrid and more
1997 Passat TDI wagon - Im not really sure why i bought this... anyone want a running donor car??? body is rough.
ketchupshirt88 is offline   Reply With Quote
Old February 23rd, 2018, 09:27   #4
Steve Addy
TDI(s): 97 Mk3
It's not a tough swap but it's more complicated than you think, you will have to swap over wiring, fuel tank and lines, exhaust system (or some parts) etc. You will have to work under the dash some with the electrical stuff.
It's the most straight forward exchange though, the B5 Passat is much more difficult, the electrical system is vastly different and the transmission you want isn't even in the US, it will have to come from Europe somewhere.
Best candidates for your Mk3 in order of ease:
Mk3 (Golf or Jetta)
B3 or B4 Passat
Mk2 (Golf or Jetta) late model with CE2 electrics
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Old March 1st, 2018, 20:25   #5
Houpty GT
Houpty GT's Avatar
TDI(s): Corrado
Fuel Economy: 56 avg.
I had a rusted out Jetta and I figured why fix it when you can get a good southern body for $500. Then I figured why do all that work and end up with just a Jetta. Start reading the in the conversion forum.
MK3 delete
Houpty GT is offline   Reply With Quote
Old March 11th, 2018, 16:49   #6
quartersaw
Fuel Economy: Passat:44mpg Golf 52MPG
Gearing is not the same. Include the tranny in that swap..
quartersaw is offline   Reply With Quote
Old March 13th, 2018, 20:45   #7
ToxicDoc
TDI(s): 2001 Jetta
The least complicated swap is another TDI with a dead engine. See if you can find one of those.
ToxicDoc is offline   Reply With Quote
Swapping parts from 2001 Passat gas to 2005 TDI? rw3iss TDI 101 0 July 4th, 2015 09:42
Help Jetta TDI Rusted Lines in Engine Bay lucaslepore VW MKIII-A3/B4 TDIs 4 April 18th, 2014 19:36
Swapping seats - 2000 Jetta VR6 Leather into 2001 Jetta TDI Cloth -plug ins different euphoria18_79 Upgrades (non TDI Engine related) 8 June 22nd, 2011 13:08
Swapping parts between 00 Jetta VR6 and 01 Jetta TDI euphoria18_79 General VW Discussion 3 April 26th, 2011 18:50
Swapping gas engine w/ TDI... practical? svocar TDI Conversions 14 March 24th, 2011 23:05
Page generated in 0.13711 seconds with 10 queries
[Output: 79.78 Kb. compressed to 69.45 Kb. by saving 10.33 Kb. (12.95%)]
