Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old February 22nd, 2018, 04:21   #1
Idaho Johnny
Fuel Economy: 41
Default Electrical issue for multiple functions
I have an intermittent electrical issue that is getting worse. It's a 2003 Volkswagen Golf TDI.
Sometimes none of these features work:
Windshield wipers
Washer fluid
Blinkers (but hazards still work)
Rear window defrost
Heated seats
Heater blower
AC button does not light, but air recirculation does.
I've narrowed it down to an area under the dash to the left where there are a bunch of relays. Usually I'll tap around relay 100 and everything will kick on while I'm tapping it. I can't be sure that it's this exact relay though since the vibration could affect anything in the surrounding area. Anybody have an idea of specifically what I'm looking for?
This is a horrible issue to have during the winter
Thank you
Idaho Johnny is offline   Reply With Quote
Old February 22nd, 2018, 04:45   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Relay 100 is the load reduction relay, it is what kills off a bunch of things during cranking, for instance.
It could be just the relay, or some connection behind it. I'd try the relay first, but if you want you can pull it out and pop the cover off and see if you see any bad contacts in there or something.
oilhammer
www.cardocautomotive.com
Old February 23rd, 2018, 03:34   #3
Idaho Johnny
Fuel Economy: 41
Update:
It was relay 100 that has gone bad. While I wait for my replacement relay to arrive, I'm able to jerry-rigg the relay so that the circuit is always closed. But anyone who does this has to remember to shut off all of the accessories when you turn off your car. Otherwise a lot of features will still work while your car is shut off, and obviously drain the battery.
Multiple intermittent electrical related trouble codes CFTDIdriver VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 33 October 5th, 2016 12:45
Multiple electrical issues wiminer VW MKV-A5 Golf/Jettas 8 October 16th, 2015 01:21
Multiple Electrical Gremlins rac VW MKV-A5 Golf/Jettas 25 August 11th, 2014 13:33
Electrical Gremlins (Multiple) durallymax VW MKIV-A4 TDIs (VE and PD) 2 October 5th, 2012 18:10
Lost all electrical accessory functions... methodikalgee TDI 101 4 March 31st, 2012 16:55
Page generated in 0.13283 seconds with 10 queries
[Output: 58.19 Kb. compressed to 52.92 Kb. by saving 5.27 Kb. (9.06%)]
