Old February 21st, 2018, 22:35   #1
yabay
Default excessive Fuel consumption
Hi, I have a 2005 Caddy 1.9 TDI BJB 2005, My car comsumes excessive fuel. I have done several things but no chance
What have done:
No faulty sensor
No fault code
torsion is +0.5 (also tested -3 , 0.00 etc now testing +2.0)
2 times i'adjusted the injectors top end to stabilize the idle.
Injectors are in good condition. We serviced them 2 times nozzles,leak and checked then ultrasound cleaned etc.
Turbo is new , No leakage, no limp mode, vanes moves freely
No vacuum leak
Tandem works well
no cam wear,
Compression is good,
starts in the first crank hot or cold.
All filters oil change periodicly,
Maf reads in specs,
Map read in specs (also replaced them to check)
İn 5-10 minutes coolant hits 90c car heats up well.
Today i will take screenshots and show the measuring blocks.
(I have Delphi DS150E and VCDS )
Any idea will accepted. Thank you guys...
yabay is offline   Reply With Quote
Old February 22nd, 2018, 04:01   #2
scooperhsd
First - define Excess fuel consumption , in terms of MPG or L/KM, so we can tell you if it's inline or not.
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old February 22nd, 2018, 05:43   #3
Mongler98
yeaa, What ^^^^^^ Said
we need more information, what you did before, any emissions fix things, and so forth and what your old milage was, and is now, LPM or GPH at ilde, and at certain rpm on each gear and so forth. This can all be logged with VCDS or visible from a scangauge II, sounds like your on it, report back with more details please.
Old February 22nd, 2018, 07:26   #4
yabay
My cons. is 10 liters / 100km
Old February 22nd, 2018, 10:21   #5
Carlos_TJ
Hello
Is the BJB engine Unit Injector (PD) or CR?
Your injector deviation is not the best.
While range is +/- 2.99 in practice anything above 0.50 should be investigated and anything over +/- 1.00 usually means something is likely wrong.
Also, on a normal engine, the values along each injector should be numerically close.
In the case of PD engines could mean
- worn out cam lobes
- defective injector (clogged, deffective pattern etc)
- wrong backlash
In the case of PD engines, the Injector deviation directly reflects the electrical signal (amperage? PWM duty cycle?) to each injector in order to mantain the angular speed of the crankshaft.
That is why there a several possible causes to those numbers.
Hope this helps
Carlos_TJ is offline   Reply With Quote
Old February 22nd, 2018, 10:27   #6
yabay
Carlos,i think you can help me,
My BJB is pue Pump Duse
Cams or lobes are ok.
Injectors took out by my self and serviced with a pro. he've said that worn out cam lobes can couse to this problem. these 2 parts are all in good condition.
-Wrong backlash? ( do you mean about injector top end adj.?) i've tried 4-5 times adjusment, nothing changed.
Old February 22nd, 2018, 10:31   #7
yabay
let make it clear .
Old February 22nd, 2018, 10:39   #8
Carlos_TJ
There is no direct feedback of fuel injected back to the ECU.
The ECU monitors the angular speed of the crank. It is so precise and high resolution that the ECU can measure the effect of each cylinder/injector to the engine speed. If the contribution of a given piston/injector does not match the specified speed, the ECU will try to compensate by changing the signal to that specific injector. It may even change the setting for the adjacent injector in order to normalize the engine speed.
Does your car produce black smoke when accelerating?
Does it produce heavy pinging sound when accelerating?
Old February 22nd, 2018, 10:46   #9
Carlos_TJ
I also should mention that PD injector install is a delicate job where they are easy to damage if not careful when seating the injector.
You dont mention your mechanical skill. Did you follow VW spec? Did you use their tool?
Also, we are asuming you have a healthy enginw block
---> cylinder compression inside specification
Old February 22nd, 2018, 10:55   #10
yabay
I'll record the all situation of my car asap.
Old February 22nd, 2018, 11:04   #11
yabay
we seat the pd injectors precise when installing to the engine.
Old February 28th, 2018, 06:04   #12
yabay
Any one have a different idea?
Excessive fuel consumption from 11mm pump Mikkijayne TDI Power Enhancements 34 February 24th, 2013 12:39
excessive fuel consumption Monkey1 TDI Fuel Economy 7 April 22nd, 2006 23:36
Excessive fuel consumption with 04 Jetta PD donsdiesels TDI Fuel Economy 15 October 11th, 2005 19:13
Excessive fuel consumption.....DUH PumpeDuse VW MKIV-A4 TDIs (VE and PD) 18 June 28th, 2000 21:57
Excessive fuel consumption.....DUH PumpeDuse TDI Fuel Economy 7 June 27th, 2000 16:22
Page generated in 0.13963 seconds with 10 queries
[Output: 104.96 Kb. compressed to 87.97 Kb. by saving 16.99 Kb. (16.19%)]
