Old February 21st, 2018, 20:34   #1
Bill Jackson
TDI(s): Jetta
Default How to get rpm Signal on TDI ALH
Im trying to figure out how and where to get rpm signal off of a ALH tdi not hooked up to the original vw transmision if anybody could help that would be great.
Bill Jackson is offline   Reply With Quote
Old February 21st, 2018, 20:59   #2
jimbote
jimbote's Avatar
rpm or speed signal? you mention the trans but the rpm signal has nothing to do with what trans you're using
Old February 21st, 2018, 21:01   #3
jimbote
jimbote's Avatar
http://forums.tdiclub.com/showpost.p...90&postcount=4
Old March 4th, 2018, 11:09   #4
Nozzleman
Nozzleman's Avatar
I successfully modified the tach signal from the ALH 4cyl signal to a 6cyl Ford Ranger tach with a Dakota Digital SGI-5E speedometer box using the L-L setting and outputting an AC signal.
2003 Jetta (wifes)
2002 Ford Ranger ALH. IT'S ALIIIIVE!
1978 Ford F250 4x4 Supercab 6bta, NV4500, Dana70/60.
Nozzleman is offline   Reply With Quote
Old March 4th, 2018, 17:22   #5
AndyBees
AndyBees's Avatar
Wow! So you were able to tweak the DD SGI-5E speedometer box to operate the Tach. Hmm!
Isn't a Dakota Digital interface for the Tach much cheaper? Such as the Dakota Digital Universal Diesel Tach Adapter Alternator Interface Unit DSL-1E
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old March 5th, 2018, 11:20   #6
Hasenwerk
Hasenwerk's Avatar
You can make an early 2000s Ranger tachometer 4, 6 or 8 cylinders depending on which ground wire is used.
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
Old March 7th, 2018, 20:33   #7
Nozzleman
Nozzleman's Avatar
To make a long story short, in my efforts to get a speedometer signal from this Ranger conversion I ended up buying a Dakota Digital SGI-5E. I am using a Jeep NV3550 with 16 pulse 3 wire sender to go to the Ranger which expects 12 pulse from a 2 wire sender.
I had been trying to get the tach to work unsuccessfully also.
The SGI-5E successfully mated the speedo and I thought "gee I wonder," so I put a two wire sender on the DD box and hooked it to the tach and it worked. hmmm
I called Dakota Digital and they suggested that since I had an unused stator (same as F) terminal (original Ford alternator), I should be able to use the DSL-1E. Apparently the signal is on the wrong side of the rectifier or something and it didn't work.
It was then recommended to run the SGI-8E but it wouldn't read the VW ECM signal. It would output a test signal to the tach.
Thanks to Alchemist and David for letting me know about the ground wires. I have a Ford dealer subscription service manual CD and have gone back and searched it and have yet to find the bit about the grounds for cylinder selection, but I did drop the one I had found that was pinned but not terminated on ground that I hooked up in the effort to get tach to work and now read correct.
And thanks to Summit Racing for letting me exchange the ones that would not work for my application. I kept the second SGI-5E for use on a later project.
Truck is running, driving and inspected. I am still working a few bugs out and need to time the pump before I drive it much. Then take care of some details as time allows.
2003 Jetta (wifes)
Old March 8th, 2018, 11:20   #8
Hasenwerk
Hasenwerk's Avatar
Your 2002 Ranger's tachometer will work just fine with the ALH's tach output signal. The "C3" plug on the back of your speedometer, position 8 which should be BK/Y, if this is ground it's 6 cylinder tachometer operation and open it is 4 cylinder. That signal is 12V square wave.
To get the speedometer running, you need a three wire VSS and something to calibrate that. It's about 140Hz = 100km/h. This signal is also a 12V square wave. I used my Universal VSS ($60 USD) that reads the bolts on my drive shaft and a Hasenwerk VSS Korrekt ($90 USD) to calibrate the signal. The output of the VSS Korrekt is "strong" enough to drive both the VSS-in on the ECU and the Speedometer, however, the ECU will read about 40% high as it wants 100Hz at 100km/h for it's signal. For cruise control use it's not an issue, if you want 100% accuracy for OBD monitoring, a 2nd Signal signal processor would be needed.
David Marshall
RPM signal frogrm7 VW B5 Passat TDIs 2 April 1st, 2013 18:27
rpm signal alh motor hvacr9e TDI 101 2 December 30th, 2010 22:20
RPM signal Golf 2006 fleet tech VW MKV-A5 Golf/Jettas 0 May 7th, 2006 21:39
Help with Dynojet RPM Signal Ironman24 TDI Power Enhancements 3 April 27th, 2006 19:48
Dynojet, where to get rpm signal? AudiLikeA4 TDI Power Enhancements 3 August 1st, 2005 20:25
Page generated in 0.15468 seconds with 10 queries
[Output: 89.36 Kb. compressed to 76.88 Kb. by saving 12.47 Kb. (13.96%)]
