Old February 21st, 2018, 19:04   #1
fjdiesel
fjdiesel's Avatar
Default ALH FJ40 109 relay HELP
I cannot get the 109 relay to power up in my swap. If I touch ground to the blu/yel wire it will power up. But it won't shut off until I pull the relay. I kept the load reduction relay box and the 109 relay from my donor. 2002 Jetta ALH. And the power distribution box at the battery. Can anyone tell me what wire tells the computer to ground out the blu/yel wire for the 109 relay. Thanks!
fjdiesel is offline   Reply With Quote
Old February 21st, 2018, 19:25   #2
fjdiesel
fjdiesel's Avatar
A friend of mine said to check 121/37 and sure enough I have that wire being powered by the 109 relay....
Old February 21st, 2018, 19:40   #3
Alchemist
TDI(s): '04 Golf
That should be connected to the ignition switch, not the relay. Power at this point will cause the ECU to turn the relay on. By connecting it to the 109 relay, you are making the relay hold itself on.
I've learned so much from my mistakes I'm thinking of making some more.
Alchemist is offline   Reply With Quote
Old February 22nd, 2018, 10:12   #4
fjdiesel
fjdiesel's Avatar
Yes, thank you. That is exactly what happened. I moved it to an ignition source. All is well now.
Old March 1st, 2018, 15:25   #5
PickleRick
PickleRick's Avatar
Would love to see pics of your ALHJ40
What transmission are you running, tire size and are you running stock gear ratios?
My buddy lusted over my old 4bd1t/4bd2t fj60 and fj40. After seeing the power and smooth reving power band of the vw diesel i should have never messed with those 700+ lbs swaps. Im trying to talk him into a stage 2 tune BHW in his FJ60 on an H55 transmission. He's running 33 inch tires on the stock 3:73 gears. Im thining he'd be better off with 4:10 gears but should be table fo find a 40 or 62 owner wanting better mpgs on their gasser willing to do a trade. The h55 came behind both the 2H ans 3B and guys use them for the later turbo yota diesels as well with success so i don't think the gear ratios would be that bad so long as you dont have too much tire for your gearing. The 60 being only about a half ton heavier than a 40 shouldn't be that big of a deal with a BHW if an ALH pushes a 40 with ease. You probably lost what...300 lbs ditching your F?
Weddings are basically funerals with cake
PickleRick is offline   Reply With Quote
Old April 16th, 2018, 19:16   #6
fjdiesel
fjdiesel's Avatar
PickleRick, I forgot to subscribe to the thread, so I just seen your post. I am running the Coty built adapter and I am running the nv3550 from a 2004 Jeep wrangler. For tires I put on Toyo MT's 285/75r17. And I changed the r&p's to 4.56's. I did a 4BT in my 60 first. Then I went to a 4BDT2. lol. And you are right, they are nice, but HEAVY... I put the turbo from the 4bt on the 4bd and that little Isuzu could run circles around that cummins. I am thinking you are correct that the ALH is 300#'s lighter than the 2F. I have the coolers all mounted now, just finishing up the coolant lines. I will load a pic once I figure out how. Lol.
Alh crank but no start no relay 109 Humpty VW MKIV-A4 TDIs (VE and PD) 9 May 5th, 2016 20:40
ALH died while driving? Not timing belt or 109 relay Caddysmack VW MKIV-A4 TDIs (VE and PD) 7 February 13th, 2013 16:36
2000 ALH dies randomly. Not relay 109 Drnknmnky13 TDI 101 38 January 19th, 2013 21:01
where is 109 relay 2000 golf alh NOT2FAST TDI 101 3 July 10th, 2011 15:32
HELP! No start! 109 relay? buzzing relay under hood? duteman VW MKIV-A4 TDIs (VE and PD) 20 March 11th, 2002 11:45
Page generated in 0.13804 seconds with 10 queries
[Output: 75.74 Kb. compressed to 65.99 Kb. by saving 9.76 Kb. (12.88%)]
