Old March 3rd, 2018, 19:10   #16
showfire
I have an OBDII reader that connects to my laptop via bluetooth, not sure if this is the same as a VAG-COM. Anyways, I found the box you are talking about; it took a trip to the salvage yard to see where the box was.
My current situation is much better. I replaced the suspect fuse and the battery. I then cleared the codes but they both came back. I looked some up some information about replacing the Throttle position sensor and saw that part of the install was to push the throttle to the floor for 5 seconds in the ACC position. Since I would have to order the TPS anyways I decided to try this installation step after clearing the codes. This seems to have resolved both issues.
After the last clearing of the trouble codes and this "reset" of the TPS the problems seem to be resolved. I will keep you posted over the next week in case the codes come back.
showfire is offline   Reply With Quote
Old March 9th, 2018, 06:32   #17
showfire
After driving to and from work for a week, there are no errors coming back and it is performing great. Thank you for the suggestions and the help.
Old March 9th, 2018, 07:13   #18
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Surprised the diodes in the alternator did not blow - you got off lucky.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
I messed up... Rickstdi VW MKIV-A4 TDIs (VE and PD) 3 August 23rd, 2014 11:39
i think i messed up. help! crazycode TDI 101 2 September 11th, 2009 16:19
looks like I messed up beetletx Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 18 February 5th, 2008 20:55
i think i messed up.. soupaman305 TDI 101 5 May 9th, 2006 10:50
I messed UP Roy Basch VW MKIV-A4 TDIs (VE and PD) 14 March 14th, 2001 00:58
Page generated in 0.12335 seconds with 10 queries
[Output: 58.54 Kb. compressed to 53.23 Kb. by saving 5.31 Kb. (9.07%)]
