Old February 21st, 2018, 06:09   #1
showfire
Default I messed up (solved)
Yesterday I made a huge mistake and connected jumper cables up to my 2003 VW Jetta TDI backwards. The car still starts and runs thankfully but now I have two error codes that have shown up.
P0672 cylinder 2 glow plug circuit/open
P0228 throttle/pedal position sensor/switch c circuit high
Any suggestions on where to start with repairing my stupid mistake?
I was going to start with checking the glow plug in cylinder 2.
showfire is offline   Reply With Quote
Old February 21st, 2018, 06:18   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Weird that it JUST did that.
The accelerator pedal assembly is one unit, with both sensors inside it. Couple fasteners hold it to the firewall.
Manual and automatic cars use different pedal assemblies, but the two different manufacturers VAG used are interchangeable.
oilhammer
www.cardocautomotive.com
Old February 21st, 2018, 06:44   #3
showfire
Thank you, that is good to know. My car is a manual, this definitely helps to know the sensors are the same.
Old February 21st, 2018, 06:46   #4
KLXD
Did they come back after clearing them?
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old February 21st, 2018, 06:54   #5
showfire
Yes they did.
Old February 21st, 2018, 11:27   #6
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Any blown fuse?
Old February 21st, 2018, 11:33   #7
Mongler98
Replace the GP Relay and fuse and check the GP's to see if there still good, replace the TPS on the peddle assembly and any relays or fuses. thats cheep and report back if not fixed. Its odd that this happened as all modern cars have a main fuse on the main input of the fuse box, usualy 100-150 amps, that would have blown first but im shocked it did damage, not the worst thing, just a few electrical parts.
Old February 21st, 2018, 15:49   #8
jettawreck
jettawreck's Avatar
Often the radio is the first to go.
2004 Cadillac SLS (wife's)
jettawreck is online now   Reply With Quote
Old February 21st, 2018, 16:51   #9
Ol'Rattler
Ol'Rattler's Avatar
Might be helpful: http://forums.tdiclub.com/showthread.php?t=79819
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old February 21st, 2018, 18:08   #10
showfire
Thank you for the suggestions, I am working through them. Most of this work will be done on weekends. There weren't any blown fuses, but one in the black box on top of the batter with the largest cable looks iffy so I plan to replace it.
I will keep everyone posted on my progress. I will keep looking at this thread so if you think of anything else I should check or replace let me know.
Old February 24th, 2018, 17:14   #11
showfire
My progress so far has been to replace the battery, I found the 150A fuse on the over battery fuse box had blown. I replaced that after hunting for a couple hours for one.
I checked all of the glow plugs, but they seem to have too low of a resistance based on the tutorial from Wingnut. I am measuring everything around 0.1 ohms, did I do something incorrect or are they bad?
The relay is delivering 11.75-12.10 V to the connectors for the glow plugs when the power is turned on for the car.
I cleared the code and started the engine, it ran smooth but a little on the rich side. I could smell diesel that had not been burned. The code did not come back, instead I am getting:
P0684 - glow plug control module to PCM communication circuit range/performance
Any suggestions about this one? I am thinking there may be a bad connection near the relay but I am not sure. Where is the relay located?
I haven't had a chance to deal with the throttle sensor yet, but I will be removing the throttle this evening and probably getting a new part from a salvage yard on Monday. This error is still the same and present.
Old February 25th, 2018, 08:36   #12
JB05
Fuel Economy: 43/41/40
On my BEW the smart relay is located at the base of the windshield, under the plastic cowl cover on the driver's side. I can see it through the vents. Don't know if your '03 has the same location, but it's worth a quick glance.
JB05 is offline   Reply With Quote
Old February 25th, 2018, 13:56   #13
showfire
I don’t see anything back there, just cables and the firewall. But, I may be looking in the wrong spot. In front of the plastic there there is a box above the master brake cylinder with 2 relays but they don’t look like the images I found of the glow plug relay. I reseated both for good measure though.
Old February 25th, 2018, 15:06   #14
jettawreck
jettawreck's Avatar
The GP relay on the '03 is under the raintray cowl at the base of the windshield where the ECU, wiper motor and hardware lives. Rectangular black box aprox 2x2x4" or a bit smaller as I recall.
Old February 25th, 2018, 15:31   #15
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
do you have vag com?
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
I messed up... Rickstdi VW MKIV-A4 TDIs (VE and PD) 3 August 23rd, 2014 11:39
i think i messed up. help! crazycode TDI 101 2 September 11th, 2009 16:19
looks like I messed up beetletx Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 18 February 5th, 2008 20:55
i think i messed up.. soupaman305 TDI 101 5 May 9th, 2006 10:50
I messed UP Roy Basch VW MKIV-A4 TDIs (VE and PD) 14 March 14th, 2001 00:58
Page generated in 0.17919 seconds with 10 queries
[Output: 124.26 Kb. compressed to 103.38 Kb. by saving 20.88 Kb. (16.80%)]
