Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old March 2nd, 2018, 10:14   #16
Good Ol' Boy
VeeDubTDI's Avatar
Got him! Thanks for the report.
Old March 3rd, 2018, 16:29   #17
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Originally Posted by fastalan View Post
Remember the OP has the 2009 model year so his car also received a brand new DPF...
Phase 1 of the "fix" is a software reflash only. DPF and CAT replacement are part of Phase 2.
-George Bernard Shaw
Old March 3rd, 2018, 20:28   #18
MonkeyWrench
TDI(s): 2012 JSW TDi
Wow, glad I signed in and read this thread today. I was seriously thinking about buying an 09 sportwagen for sale here in Denver. I test drove the car a month ago, it had a CEL, I pulled the code - I don't remember now what the code was, but I read through these pages and thought it seemed like the dpf. The car is still for sale... really cheap... so I keep thinking maybe I should go buy it... now I'm thinking that's a really bad idea. http://www.thesharpestrides.com/vehi...lkswagen-Jetta
MonkeyWrench is offline   Reply With Quote
Old March 5th, 2018, 08:09   #19
jesus_man
That car came up in my searches as well. I couldn't get past the well worn interior. The price has dropped a lot since I was looking just a month ago!
Is there an easy way to tell what phase has been completed? I'll start a new thread for my new car, but have some questions.
2010 JSW TDI DSG in gray with black interior
2009 JSW TDI DSG - sold back to VW
2002 VW Passat Wagon, 6spd, silver Family hauler! - Euro Spec
2006 Jetta TDI Bought 6/25/06 (traded in 10/2009 @ 43mpg
jesus_man is offline   Reply With Quote
Old March 6th, 2018, 09:06   #20
SilverGhost
SilverGhost's Avatar
Sorry, I screwed up in my original post. OP has 2009 so the replacement DPF is setting that DTC.
2009 gets a new DPF because NOX cat has to be cut off to be replaced. 2010 up to 2014 the NOX cat unbolts to be replaced so does NOT get a DPF.
2015 have new engine and Phase 1 get flash only, Phase 2 is parts replacement.
Jason
SilverGhost is offline   Reply With Quote
Old March 13th, 2018, 13:38   #21
andreigbs
Originally Posted by oilhammer View Post
I am local to some of you guys, if you need someone who likes caring for these cars for general service please feel free to contact me.
Some folks come from much further.... like Wisconsin even
Oilhammer, is it safe to assume you are equally comfortable working on Merc BlueTecs? I have a 2014 GLK that won't be in warranty for much longer. I have a trusted shop here for stuff like brakes and oil changes, but anything more important (like DPF) I'd like to have a real Pro take care of when needed.
2014 Jetta TDI // 18xxx miles // 41 MPG
2014 GLK 250 // 81xxx miles // 36 MPG
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed!
2004 Bora TDI // 146xxx miles // 42 MPG - sold!
1997 Jetta TDI // 317xxx miles // 44 MPG - sold!
andreigbs is offline   Reply With Quote
Old March 13th, 2018, 14:18   #22
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I won't consider myself an MB expert by any stretch, but I am not afraid of them and do my best. Learning more all the time, especially since I bought a Sprinter last year.
oilhammer
www.cardocautomotive.com
Old March 13th, 2018, 14:33   #23
andreigbs
Good to know, thanks. Didn't mean to hijack this thread. I'll contact you guys when the time comes.
Old April 23rd, 2018, 12:48   #24
MM STL
TDI(s): 2009 Jetta
Default Still happening.
on 3/6/18 the dealer found the wrong gaskets were used by the technician during the modification. We all thought replacement would solve the problem. I'd noticed regens happening shortly thereafter and all was well. I've been driving the car "as recommended" on some longer trips (50+ miles) and two days ago I was driving to hike in a state park when the CEL came back on! It's only been 550 miles on the odometer. I've noticed the CEL has come on when I do a hard acceleration, like when passing or accelerate on a steep hill.
So, it's no longer my driving habits.
MM STL is offline   Reply With Quote
Old April 24th, 2018, 08:21   #25
SilverGhost
I dug a little more into the cars we have come in with codes like that. More often than not there is an air leak or vacuum hose connection that is causing a marginal condition. ANYTHING that screws up the ECM's control over air flow will cause DPF regen problems.
Jason
Old April 24th, 2018, 09:40   #26
jesus_man
I'm hoping Jason is on the mark, but unfortunately, undoing the build-up of gunk caused from not running the car for long periods is going to take some time. And in actuality, not completely possible without tearing down the engine and cleaning it all out. But driving it for longer periods of time and perhaps some proven additives to both fuel and oil might help the process.
German tune-ups, although not as popular as the version from the Italians, is still a good way to keep things cleaned up on the interior of a healthy motor.
Old April 26th, 2018, 13:42   #27
MM STL
TDI(s): 2009 Jetta
Thanks Jason, that's something to consider. All the tests that the VW tech line advised the dealership to do today came out perfectly fine (as they have each time). My case has been elevated to a "level 2" and a field technician will be coming to St. Louis on Tuesday 5/1 to review the case and test my car. They're performing a regen today so I can drive the car over the weekend.
Old April 26th, 2018, 14:07   #28
KITEWAGON
KITEWAGON's Avatar
I assume that regens can be triggered with VCDS (if necessary) to avoid trips to the dealer....yes?
2014 Touareg TDI Executive, Canyon Grey, 130k
2014 JSW TDI, Platinum Grey, 43k
2005 Toyota Tundra Double Cab SR5 TRD 4x4, Silver, 165k
KITEWAGON is offline   Reply With Quote
Old April 27th, 2018, 07:23   #29
SilverGhost
Another problem is the ECM will set DTC called "Regeneration frequency" that basically says its doing regens TOO MUCH.
Jason
Old April 27th, 2018, 07:26   #30
SilverGhost
A cracked charge air pipe or kinked vacuum hose would be an easy find. But there could be a much harder to find issue like a rolled or damaged seal in one of the many connections, some debris or other reason a leak is happening INTERNALLY, or a sensor sending faulty info that is still trusted by ECM as correct.
Jason
DPF regeneration - why OEMs (VW) does it every 200-300 miles SilverGhost TDI (Diesel) Emissions 5 December 16th, 2015 17:50
Maintenance Requirements for the 2002 VW Golf TDI. larrymcfall TDI 101 3 September 9th, 2006 22:07
VW violates Magnuson Moss with PD oil requirements Chris B Fuels & Lubricants 21 March 4th, 2004 12:34
CURRENT 2001 VW TDI OIL REQUIREMENTS SkyPup Fuels & Lubricants 62 August 21st, 2001 01:58
VW dealer oil requirements clacker VW MKIV-A4 TDIs (VE and PD) 8 March 30th, 2000 07:24
Page generated in 0.22665 seconds with 10 queries
[Output: 128.12 Kb. compressed to 107.01 Kb. by saving 21.12 Kb. (16.48%)]
