Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old February 20th, 2018, 08:37   #1
MM STL
TDI(s): 2009 Jetta
Angry VW Requirements for Regeneration
I purchased my 2009 Jetta TDI brand new and it now has 49k miles. I opted for the modification as soon as it was available. At the end of November 2017, the check engine light came on with P2002 (DPF) code. The dealer didn't find any problems and forced a regen. All was well until the same situation happened this month. The dealer contacted VW as he couldn't find any problems other than a regen was needed. VW then instructed that I MUST drive "50+ miles at a time, at highway speeds, at least once per month" to create a regeneration. The dealer stated VW didn't want to cover this visit under the warranty but the dealer was going to "write it off" because they were unaware of this requirement also. Any one else had this situation? My Jetta would regen frequently before the modification. My driving habits haven't changed. I live in St. Louis where I would have to drive out of the metro area to get in 50 miles at a time!
MM STL is offline   Reply With Quote
Old February 20th, 2018, 08:48   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Unfortunately, the post-mod fuel management is going to mean the car will use more fuel, so it will make more particle matter, which means the DPF will have to work more to get the job done.
You have such low mileage for a nine year old car, especially a TDI, it makes me think you are probably not the best match for the car. DPF equipped diesels like long highway drives, just the way it is.
I would look into an OBD-compliant tune/delete if you want to continue to drive your car in the city. Or trade it off for a gasoline fueled car, electric car, or an older pre-DPF TDI.
Your driving habits may have been OK before, since the car was "cheating" it was not using as much fuel. So the passive DPF regens were probably just fine. Now it isn't enough, and a blast down the highway is what is needed.
Some folks use some sort of engine data monitor to know when a regen is needed, or is happening, and adjust their driving habits accordingly. Personally, I would not own a car that required THAT much of me. I'd modify it, or drive something else.
oilhammer
www.cardocautomotive.com
Old February 20th, 2018, 08:53   #3
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
Indeed. I drive my 2015 Golf TDI for work and often the company sends me on a job that results in a 100 plus mile trip. TDI, particularly the newer ones, need a good run on the highway. I've only had the dpf idiot light come on once, to remind me to go on the road. It was an excuse for me to travel 30 miles to a truck stop that has a really good bakery.
2015 Golf SE TDI with DSG, 61k.
2005 Passat GLS TDI - RIP, 208k miles. Many good memories and friends made with this car.
leicaman is offline   Reply With Quote
Old February 20th, 2018, 10:22   #4
MM STL
TDI(s): 2009 Jetta
Thanks for the info! I poured over each piece of information that was released by VW prior to choosing modification vs buy back and would not have chosen to keep the Jetta if I knew this was the case. I feel duped, again.
Another question: Should i wait until the CEL comes on, then take a long drive. Would that cause any long term damage? I'd hate for VW to come back and say it wasn't covered under warranty.
Old February 20th, 2018, 10:28   #5
oilhammer
oilhammer's Avatar
Well to be fair, nobody at the dealer (and likely no one at Volkswagen in this country) really could have known for sure what if any bad could come from the fix.
Although, while I am no scientist, I do understand the basics of NOx enough to know that in order to reduce it, you need to take away more free oxygen in the intake air charge, and the only way to do that is to run even more EGR, and use more fuel, and that means the DPF gets used more. So, unless they were going to retrofit SCR on to your car, there really is no other way. Bound to happen.
You can proactively drive the car down the highway once in a while, weekends or whatever (I drive 100 miles a day myself), and hope it gets the DPF happy. It most likely will. But, if you want a little better information to arm yourself with, a data monitor like a Scangauge or similar, will help out. That way at least you will KNOW when and if a trip is in order. You may also find that changing how you drive right now will help, like using a lower gear than you otherwise would for instance.
oilhammer
Old February 20th, 2018, 12:02   #6
Lightflyer1
Lightflyer1's Avatar
You have been short tripping the car since new and gotten away with it. They don't like doing this at all. With the new fix software you got caught finally. You will have to take an active role in dpf regens if you want to keep it healthy. The key to it all is knowing when a regen is coming due and making driving allowances for it. I use an app that tells me this info but it seems it is now unsupported and doesn't support your engine type. Torque another app has made some progress in this regard and may help you monitor what is happening.
http://forums.tdiclub.com/showthread.php?t=464119
Then there is the old brute force method of just taking long drives and hoping a regen happens while you are out there.
You really bought the wrong car for your driving habits. It may be better to consider another car if possible. Good luck!
Mine happen about every 250 +/- miles, so you will need a drive somewhere in that ball park to regen the dpf every time.
2015 Beetle TDI.
Old February 21st, 2018, 15:55   #7
STLTDI
I'm somewhat in the same boat. About 16 days of the month my TDI takes a short 10 mile round trip on side roads. 8-10 days it stays garaged. I make it a point to take at least a 50 mile round trip on the hwy twice a month if it doesn't happen in my normal travels. Drive out to Hermann and get some sausages!
I know a gasoline car might be better, but I take 2-3 1800 mile round trips per year where the cruising range is my priority ...and... I just love diesels.
STLTDI is offline   Reply With Quote
Old February 22nd, 2018, 13:58   #8
jesus_man
We've learned this with another brand of German car, new enough to need DEF. We (my wife) was babying the car, trying to eek out all the MPG's. In the end, this backfired with strange emissions related issues. So after talking to some enthusiasts, we changed our driving habits and the car has been great since. I've also added in a fuel treatment regime and we're enjoying the best fuel mileage we've ever gotten. We don't perform the "Italian tuneup" every day, but I tell her that at least once a week, after the engine is warmed up drop it into sport mode and do a couple 0-60 dashes. And when I get the chance to drive it, I drive it pretty hard.
Gassers are more lenient for short commutes, but they will still gum up just the same.
Just make it a point to take the car outside the city somewhere. Do some site seeing once or twice a month. It'll be nice for you and the car!
2010 JSW TDI DSG in gray with black interior
2009 JSW TDI DSG - sold back to VW
2002 VW Passat Wagon, 6spd, silver Family hauler! - Euro Spec
2006 Jetta TDI Bought 6/25/06 (traded in 10/2009 @ 43mpg
jesus_man is offline   Reply With Quote
Old February 23rd, 2018, 03:31   #9
oilhammer
oilhammer's Avatar
I am local to some of you guys, if you need someone who likes caring for these cars for general service please feel free to contact me.
Some folks come from much further.... like Wisconsin even
oilhammer
Old February 23rd, 2018, 09:40   #10
leicaman
leicaman's Avatar
Yes Brian, you are on my short list. You will be doing my timing belt on my Golf when the time arrives.
Old February 23rd, 2018, 12:23   #11
STLTDI
Same. My GSW only has 7500 miles on it, but after its first included maintenance, you’ll have my business.
Old February 27th, 2018, 14:20   #12
MM STL
TDI(s): 2009 Jetta
Well, everyone, this changes things. I decided to drive to Waterloo, IL- about 25 miles from my home. I was passing a semi at 70 mph when the CEL came on! Now it's only been 120 miles and 12 days since I was last at the dealer (see first message). It was the P2002 code again. Another contact with VW corporate tech ensued and I have an appointment to change out the converter, under warranty. Obviously, it's not JUST my driving habits.
Old February 28th, 2018, 10:12   #13
SilverGhost
SilverGhost's Avatar
P2002 Particulate Trap Bank 1 Efficiency Below Threshold. That looks to me like all you short trips from before the modification have come back to bite you. It's not asking for a regen, its saying the regen is not effective. I would hazard a guess if you looked inside the substrate is cracked.
Jason
SilverGhost is online now   Reply With Quote
Old February 28th, 2018, 11:39   #14
fastalan
Jason
Remember the OP has the 2009 model year so his car also received a brand new DPF. All his short trips before fix on the original DPF didn't cause any CEL.
It is probably that the OP continues to drive in a manner that is unsuitable for the new DPF/software, thus triggering multiple P2002 CEL OR he simply received a bad set of DPF/EGR filter.
2k10 Golf TDI Wagon 6-sp manual
2k06 Mini Cooper CVT
1994 Aerostar cargo
fastalan is offline   Reply With Quote
Old March 2nd, 2018, 08:13   #15
Steve Addy
TDI(s): 97 Mk3
Jason
Looks to me like we have a bot here...
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
DPF regeneration - why OEMs (VW) does it every 200-300 miles SilverGhost TDI (Diesel) Emissions 5 December 16th, 2015 16:50
Maintenance Requirements for the 2002 VW Golf TDI. larrymcfall TDI 101 3 September 9th, 2006 21:07
VW violates Magnuson Moss with PD oil requirements Chris B Fuels & Lubricants 21 March 4th, 2004 11:34
CURRENT 2001 VW TDI OIL REQUIREMENTS SkyPup Fuels & Lubricants 62 August 21st, 2001 00:58
VW dealer oil requirements clacker VW MKIV-A4 TDIs (VE and PD) 8 March 30th, 2000 06:24
Page generated in 0.16176 seconds with 10 queries
[Output: 134.92 Kb. compressed to 113.13 Kb. by saving 21.79 Kb. (16.15%)]
