Old February 23rd, 2018, 18:00   #16
[486]
TDI(s): 02 golf ALH
Originally Posted by WrEkkED View Post
I'm really easy on the car for the most part, but one run from 30-70 and I'm done for.
side mount will do fine
whenever you aren't making boost, the air out of the turbo is pretty much outside air temp
meaning, if you're just doing infrequent pulls it will have time to cool between them.
[486] is offline   Reply With Quote
Old March 14th, 2018, 21:18   #17
3L3M3NT
3L3M3NT's Avatar
IMO he could probably get away with an upgraded SMIC if he was running a stock or even a VNT-17 that's tuned, but when running a turbo that's a 17/22 or bigger than I would recommend going with a FMIC.
I know that running a larger turbo isn't going to have as high of EGTs, but it's better to have a larger intercooler on a car that is going to be making 220 hp. There's a reason why certain size ICs have a hp rating...meaning it can only flow a certain amount of air and cool it as it goes through.
If you haven't made your decision yet, then either piece together a FMIC or bite the bullet and buy one, because what was the point in spending all that money on a larger turbo, bigger injectors, and a tune to let the ECU control all the new upgrades.
Otherwise everytime you wanna push your car you're going to have to worry about heat soak
Sturgeon Bay, WI Cruise/GTG October 20th, 2018
Fix if you're using Chrome: Chrome fix
Firefox fix
RTDI Build Thread
3L3M3NT is offline   Reply With Quote
Old March 14th, 2018, 21:44   #18
[486]
TDI(s): 02 golf ALH
Eh, I was running a stock side mount as the low pressure IC with a 46/58 compressor and 52/46 turbine feeding it only 16 PSI, the HP turbo did surge a bit earlier than it should've, so maybe it was a significant enough restriction to bump that down a couple PSI.
You'd see a lot better flow through the intercooler with it seeing full intake manifold pressure though.
Current setup's going together with a 60/86 compressor feeding the same junk stock side mount, but I won't claim it's a good idea.
Old March 20th, 2018, 02:27   #19
MAXRPM
MAXRPM's Avatar
Fuel Economy: 57 mpg driving like a granny on HWY-5 from LA to SF
suscribed
1/4 mile run----13.98 sec. @ 105.37 mph 8 years ago
I dynoed at 275HP at LCD back then, now 2.0 TDI with the real bolt ons, HP and TQ who knows???
MAXRPM is offline   Reply With Quote
Old March 20th, 2018, 15:25   #20
Muskrat619
Not trying to hijack a thread Iím new canít figure out how to start another one yet just a quick question I bought golf all intercooler piping will it work on my all jetta?
Muskrat619 is offline   Reply With Quote
Old March 21st, 2018, 04:13   #21
Geobmx4life
Geobmx4life's Avatar
Fuel Economy: 2005Golf TDI 50mpg...best 60
Mkiv golf and Jetta are extremely close, so yes it should.
2005 Golf TDI, VNT 17, Malone tuned, Spec stage 2 clutch, .658 5th gear, Darkside SMIC, Ventectomy, NewSouth gauges, BuzzKen 2.5 turbo back exhaust, Evolution Skidplate, Helix OEM Reps retrofitted with Morimoto Bixenon mini's, ST coils, 18in Huffs. Frostheater
Geobmx4life is offline   Reply With Quote
Old March 21st, 2018, 09:21   #22
Yourbuddysatin
At the top of all the threads you found this thread on. Left top corner is the tab to make a new thread. I my experience mk4 golf and Jetta are about 95% the same. Most differences are body and interior pieces. For that matter there are a ton of Audi TT components that will interchange also. They might not be the same but will bolt onto one another. Little research and you wonít believe the compatablilty of those cars.
Yourbuddysatin is online now   Reply With Quote
Old March 21st, 2018, 18:48   #23
Muskrat619
Thank you guys so much
Old April 15th, 2018, 06:33   #24
WrEkkED
WrEkkED's Avatar
I havn't done one yet. But I think I will use the kit above on ebay. Seems everyone sells the same intercooler anyways. I would really prefer same side in and out and thats what im holding back on for now. I cant make up my mind.
2004 Jetta TDI Sport Edition
WrEkkED is offline   Reply With Quote
Old April 15th, 2018, 19:21   #25
3L3M3NT
3L3M3NT's Avatar
Same side in and out is the only way to go IMO. It makes plumbing for that intercooler sooo much easier that going with an intercooler with opposite sides for in and out.
Good luck and keep us posted on how it goes with the install.
Firefox fix
RTDI Build Thread
Old April 25th, 2018, 16:51   #26
WrEkkED
WrEkkED's Avatar
Awesome! Will do. I jus dont feel like buying a pd150 intake to make it work. I will probay make a decision this week with temps getting warmer and ill update with some pics and how much of a pain it is.
Old April 25th, 2018, 17:22   #27
3L3M3NT
3L3M3NT's Avatar
Your stock BEW intake manifold will work. You just need to buy a race pipe to connect the silicon elbow to.
Like so: https://www.darksidedevelopments.co....pipe-51mm.html
You could always keep your factory setup and just delete the EGR with these parts.
https://www.darksidedevelopments.co....-manifold.html
https://www.darksidedevelopments.co....lete-pipe.html
Good Luck
Firefox fix
RTDI Build Thread
FMIC question for new beetle alh speedy223 VW MKIV-A4 TDIs (VE and PD) 7 January 18th, 2018 16:03
FMIC Fitment question - help Vee-Dubb VW MKIV-A4 TDIs (VE and PD) 1 March 7th, 2014 05:30
FMIC question phucking-low VW MKIV-A4 TDIs (VE and PD) 3 November 21st, 2012 06:03
Fmic piping question the wrecker TDI Power Enhancements 2 September 6th, 2012 18:17
eurojet FMIC question grimkiller TDI Power Enhancements 1 January 2nd, 2007 20:44
Page generated in 0.14812 seconds with 10 queries
[Output: 115.46 Kb. compressed to 97.95 Kb. by saving 17.51 Kb. (15.16%)]
