Old February 19th, 2018, 09:38   #1
AFNquattro
AFNquattro's Avatar
Default AFN light mods and expectations
Hey there, first time posting so if there are any issiues I'm sorry. I have a 1998 A4 B5 afn quattro which I had tuned. The car "woke up" quite nicely but it wasn't long before I started wanting a bit more from it. So far I've installed a gt1749va turbo and 0.216 injectors from a 5 pot 2,5 TDI. The car has stock exhaust with a cat delete and I'm considering a muffler delete as well. My question is what should I expect power wise and should I start worrying about the clutch. The car has been full serviced since I bought it(belts, oil, filers, clutch, etc...).
Here it is:
AFNquattro is offline   Reply With Quote
Old February 19th, 2018, 10:26   #2
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
4/5 of an equivalently tuned AEL would be a good starting guess...
Old February 19th, 2018, 10:38   #3
Mongler98
supper nice, im jelly
so if you want some decent power, just replace and upgrade the clutch, get it over with, its not that hard of a job really, just lots of things to do and a weekend of time. Upgrade the fork when your in there, i put some extra welds on mine as they tend to bend under better clutches.
sky is the limit after that. Or you can just up the nozzle size and then change the clutch after you did not much power, its not that much you need to blow it. Clutch is cheep , half the cost of my tune lol.
Old February 20th, 2018, 07:37   #4
AFNquattro
AFNquattro's Avatar
Thanks for the responce. I'm not actually going for an all out performance project. The car is my daily and I wanted to make it a bit more enjoyable to drive, not that it isn't at the moment. Maybe I should have cleryfied that my worry is if the clutch will give up after the car is tuned with the new setup. Not that its a problem to upgrade it but if it can handle the power why bother. I have laying around a single mass flywheel from a b4 1z tdi and an upgraded pressure plate.
Old February 20th, 2018, 08:05   #5
Mongler98
light mods will be fine, the best bang for your buck is get more high end with less focus on low end that will kill the clutch, your clutch should be able to handle some light mods, up your fuel with a 2nd stage nozzles, down pipe up the boost a few psi maybe and see how you like it, then get a tune.
my clutch stated to slip once i put on my gt2052 and a set of pp.764's. so id say just go with the next size up on your nozzles than stock with a tune. A better upgrade is all around is a bit into suspension to get a bit stiffer for corners with out going wild and sacrificing on comport. The #1 thing you should do is get a EGT temp probe and gauge and an oil PSI gauge, i recommend Auber digital set, well worth the insurance if you go big on fuel as you want to make sure you dont exceed EGT's. If you spend the money on a turbo, its well worth it for the insurance to make sure it gets enough oil and does not overheat. im glad i did and they can be wired up as they have relay's in them for things like water meth injection or other things.
as for keeping it simple, a 1 stage up on nozzles and a tune would probably be best and you would not need any gauges for that!
once you get more power, you always want more
one suggestion i have for you is to find a local autocross, its more fun than you could ever imagine and you dont need a fast car for it, tires help
Old February 20th, 2018, 09:21   #6
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Your AFN should be mated to a 5 speed 01A like mine. It will work fine with a single mass flywheel, unlike an 01E, which will destroy the synchros with a SMF fairly quickly. I replaced my original clutch with a Valeo OEM replacement SMF kit and while it's OK, I preferred the NVH with the DMF and had I known it at the time would have stayed with the DMF. As it turned out, the original clutch was actually still reusable but the pilot bearing had disintegrated, so I spent several hundred dollars in a complete clutch kit and labour to replace a two dollar part...
If I ever upgrade to a 6-speed 01E, I'll return to a 240mm Sachs SRE DMF kit.
Incidentally my car has stock injectors and turbo, but has a 12mm pump and is remapped, so it should develop about the same power and torque as yours. While the clutch was slipping during winter when it was newer, it's not anymore.
Old February 22nd, 2018, 22:35   #7
adamss24
Fuel Economy: 35-45mpg
Best bang for buck: Bosio race 520 nozzles, 11 mm pump, Bv 43a turbo cartridge in bv43 housings (from the 2.0pd tdi), catalytic converter delete pipe off eBay, stronger clutch and proper map and it will piss all over corrado vr6 ! I had an old a4 FWD, engine code AHH. It comes stock with 90 Bhp, VNT turbo gt1749v just like the AFN, and flash trough obd ecu. With bosio race nozzles and gt1749va turbo it ripped the flywheel to pieces and clutch was slipping big time. I then put a bv43 and it was a bit more sedate but had a much stronger top end. I did not had a chance to tune the engine further as I crashed the car and decided to break it for spares. It was a vicked car to drive !
adamss24 is offline   Reply With Quote
Old February 23rd, 2018, 05:32   #8
Mongler98
Ive crashed my car 4 times, every time resulted in the welder coming out, a trip to the junk yard, and a $50 tow home and it was always ripping tires the next day! or in 2 days, like when i slammed a curb at 45mph at a 30* angle and ripped the lower control arm OFF.
OP wants a config that wont need a new clutch, so your set up is a bit much! but sounds like a great combo.
Old February 23rd, 2018, 08:35   #9
bhodgkiss
See my signature, my AFN is close to 200 crank hp - but yes a clutch upgrade needed.
Whats the bv43a cartridge mod? Mine runs 1.8bar happily - does this mod allow higher boost again? Or just better spool?
AFN Wagon | Fjord Blue | BV43 | 11mm IP | R520 | PD Lift Pump | Ported head | 3bar MAP | SRE Clutch | FHN G'box | Forge FMIC | PD130 intake | EGR delete | Decat | Custom Remap | Porsche 4-pot 312mm Brakes | KW V1 | Carbon Upper Strut Brace, RS4 Lower | H&R 32mm Front ARB | Whiteline Rear ARB | OZ Ultraleg 18" Satin Black | OEM Xenons | Bucket seats | Battery & washer bottle in boot | 100kg removed |
bhodgkiss is offline   Reply With Quote
Old February 23rd, 2018, 11:30   #10
adamss24
Just better spool ! The bv43a does have a billet compressor with nice trim, extended tip technology and fits plug and play into the bv43 pd 2.0 tdi housings ! It allows 220 British horse power if you have fuel to go with with reasonable EGT !
Old February 23rd, 2018, 11:33   #11
adamss24
After you had Quattro itís hard to go back to FWD no matter how good is the car ! I still have a 1.9 tdi Quattro with a built engine (ported heads, twin valve spring setup, stronger rods, etc.) but the car is not in the best shape...needs tracking, some paintwork- just lost interest ! As you grow old itís just easier to save up and buy a new car with a little bit more power !
Old February 23rd, 2018, 11:59   #12
Mongler98
Originally Posted by adamss24 View Post
British horse power
WHAT?
Horsepower (hp) is a unit of measurement of power (the rate at which work is done). ... Two common definitions being used today are the mechanical horsepower (or imperial horsepower), which is 745.7 watts, and the metric horsepower, which is approximately 735.5 watts.
I guess American horses are stronger than your British horses!
Old February 24th, 2018, 13:16   #13
adamss24
Mongler, i was just being sarchastic... Yankees use wheel horse power and on the continent we use brake horse power... I was hinting at Ben_ as he is british and understands the pun. I am not british though...
Some say the stronger horses are italian, spanish or portuguese... These folks cars havr most Bhp on their dyno's, must be the mediteranean sea breeze!
Old February 25th, 2018, 03:25   #14
AFNquattro
AFNquattro's Avatar
Thank you for all of your responces but a problem has come up. The car is over boosting like its seems nothing is controling the boost. Tried swapping the n75 with a working one my tuner keeps for cases like this but it was still the same. The turbos geometry seems to be working(before installing it was disassembled and cleaned up) but the car spools late and it then bogs because the computer cuts it off. Could something be wrong with the turbo or could it be a vacuum line problem?
Old February 25th, 2018, 07:55   #15
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
It's a 20 year old car - rubber vacuum lines could be hardened and porous. If you have a hand-held vacuum pump, you can disconnect the line between the N75 and turbocharger, apply vacuum and see whether the vacuum holds, ie whether the gauge moves. Repeat from other vacuum lines. Also check for fault codes in the ECU. They will give you a clue of the culprit.
cheap or free mods for afn PilaS TDI Power Enhancements 21 June 29th, 2017 09:41
AFN, What mods too get 200BHP. Dankemp TDI Power Enhancements 34 July 21st, 2013 06:47
Cheap or free power mods on afn engine dubboy2707 TDI Power Enhancements 0 May 18th, 2012 03:09
FS: 2001 TDI Jetta 5spd 250k (140k on Trans) Light rear damage, some light mods, VT slight3r TDI Cars for Sale/Wanted 7 February 1st, 2012 21:00
back up light and 5th brake light mods -- bulbs 03_01_TDI Upgrades (non TDI Engine related) 2 September 27th, 2005 04:17
Page generated in 0.17051 seconds with 10 queries
[Output: 130.19 Kb. compressed to 109.44 Kb. by saving 20.75 Kb. (15.94%)]
