Old February 19th, 2018, 16:03   #16
next time, when it happens, turn it off and back on again as your driving, if it goes good for a few minutes, Limp mode 100%
Old February 24th, 2018, 12:02   #17
Fuel Economy: 33 mpg on the interstate at 65mph with windows up and no a/c going
Good idea Mongler.
But before I try that, I had another thought. Before I changed the timing belt, the motor was running smoothly. Then when I was about to change the timing belt, I noticed that the camshaft was cock-eyed enough that the camshaft locking tool wouldn’t even come close to fitting into the camshaft slot while the crankshaft was dead nuts on TDC and the locking pin was in the injection pump pulley. This is before I removed the old timing belt.
Next I removed the timing belt and cracked loose the cam sprocket to put the camshaft back into the correct TDC position with the cylinder 1 camshaft lobes at 10:00 and 2:00 pointing up and the camshaft locking tool in place and tightened the cam sprocket back down. Now I have true TDC at all three points. Cam, Crank, and IP.
However, I have not moved the IP whatsoever. Am I correct in thinking that since I moved the camshaft without adjusting the IP to match, that my IP is now putting fuel into the cylinders at the incorrect time in relation to the cam timing? And will this cause it to feel like it’s running on three cylinders and is very low on power?
Next question... If this is the case, could I loosen the IP and adjust it by ear just to see if it helps smooth out the idle? And then whenever I get a VCDS cable, I could fine tune it more at that time?
mustangmarty is offline   Reply With Quote
Old February 24th, 2018, 20:22   #18
turbodieseldyke's Avatar
TDI(s): 98 jetta
Fuel Economy: 50
I don't know how much you can ear-tune it. The only time(s) I did that, was after a TB change and the IP was too far off to start the car. I would "ear" it til it started and ran, then immediately Vagcommed it to get it right.
Good luck though.
turbodieseldyke is online now   Reply With Quote
running rough after running super low on fuel soccerhead16 TDI 101 1 December 14th, 2014 17:48
rough running, help! fatkid VW MKIV-A4 TDIs (VE and PD) 18 April 10th, 2014 07:59
Running Rough imGellin TDI 101 5 November 4th, 2010 09:31
Running rough Yunny TDI 101 3 November 3rd, 2010 11:59
Rough Running nicknack2 TDI 101 11 March 17th, 2008 11:52
Page generated in 0.11988 seconds with 10 queries
[Output: 58.85 Kb. compressed to 53.45 Kb. by saving 5.40 Kb. (9.18%)]
