Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old February 22nd, 2018, 15:57   #16
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
-George Bernard Shaw
Old February 22nd, 2018, 16:15   #17
Vince Waldon
Vince Waldon's Avatar
Originally Posted by PD Rig View Post
Go with what works well. Stock...
And... just like that... the two halves of this thread come together as one.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Old February 23rd, 2018, 08:45   #18
SilverGhost
SilverGhost's Avatar
I have the flow and particle size tests for K&N stored around here somewhere. Some truck guys got together and bought time on a flow tester. I think its on my old laptop I'll have to dig out.
Jason
SilverGhost is offline   Reply With Quote
Old February 27th, 2018, 12:19   #19
Mongler98
toss that POS away and go with a Swiss cheese mod on the air box with a MANN filter.
Old February 27th, 2018, 12:23   #20
Midwesthick
TDI(s): 14' Golf
Fuel Economy: 45+
I rock an AFE dry flow filter with the stock setup. No complaints here but I would 100% stay away from an oiled element.
Denver life...Yes I use cannabis..
Midwesthick is offline   Reply With Quote
Old February 27th, 2018, 13:57   #21
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
Originally Posted by 1854sailor View Post
Ironically that photo was taken in Sheboygan. We did a big story about that particular photo as it is a hoot. OH and BTW, the K&N IS a MAF killer.
2015 Golf SE TDI with DSG, 61k.
2005 Passat GLS TDI - RIP, 208k miles. Many good memories and friends made with this car.
leicaman is offline   Reply With Quote
Old March 5th, 2018, 06:17   #22
SilverGhost
HA! Found the air filter test. It was posted over at Diesel Bombers truck forum. Test is an ISO 5011 and uses machine Testand Corp of Rhode Island.
Here is the link
Jason
Old March 8th, 2018, 20:36   #23
[486]
TDI(s): 02 golf ALH
Originally Posted by Nevada_TDI View Post
When a rotating part that spins in excess of 100,000 RPM--sometimes up to 160,000 RPM-- the smallest amount of compressor erosion will create an out-of-balance scenario and cause a catastrophic turbo failure.
ehh, fine dust doesn't affect balance, large chunks do
same reason axial turbine engines can ingest quite a bit of fine dust, it erodes the compressor blades pretty evenly
Ever see an air filter on an aircraft? Some helicopters run oiled cloth filters that only really stop the large bits, but for the most part it's just considered and written off as normal wear.
They don't have cylinder walls and piston rings, however.
[486] is offline   Reply With Quote
Old March 9th, 2018, 06:44   #24
pdq import repair
Fuel Economy: 38.5
K&N filters work very well on boats and snowmobiles, and nowhere else.
pdq import repair is offline   Reply With Quote
Old March 9th, 2018, 09:55   #25
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Fuel Economy: 50mpg on B100
I use one on my turbo 280Z (gasser, no MAF) as it is way beyond stock. They flow well and keep out rocks.
2001 Beetle - EGR delete, 01M-ectomy, Atlas skidplate, vented, Frostheater.
I'm not coasting, I'm shifting slowly.
UFO is offline   Reply With Quote
K&N air filter or go with a stock filter? CALL911 VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 41 December 1st, 2017 13:36
K&N air filter Nomadd06 TDI Fuel Economy 12 April 9th, 2011 19:43
k&n air filter 66 truck VW MKV-A5 Golf/Jettas 17 January 15th, 2010 18:27
FS: AIR FILTER & FUEL FILTER BUGBOY Private TDI Items for Sale/Wanted 0 December 4th, 2003 19:14
Air Flow Wire Clogged -- by K&N AIR FILTER??? tsterkel VW MKIV-A4 TDIs (VE and PD) 15 July 1st, 2003 12:59
Page generated in 0.16898 seconds with 10 queries
[Output: 99.79 Kb. compressed to 85.08 Kb. by saving 14.71 Kb. (14.74%)]
