Old February 20th, 2018, 16:09   #16
Momentslater
Fuel Economy: 43/54mpg
If I can't just replace the cam and lifters what am I looking at doing specifically? What parts do I need to get?
Momentslater is offline   Reply With Quote
Old February 20th, 2018, 20:54   #17
whitedog
Contact franko6. He will let you know what you need.
Old February 21st, 2018, 03:50   #18
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
You need to take the head off. You cannot tell what you need until you do. Quit asking, and take it apart, or part ways with the car. We cannot see inside the engine.
The head may be able to be fixed, it may need to be replaced. You may have a bent rod and/or a cracked piston. You need to take the head off.
oilhammer
www.cardocautomotive.com
Old February 21st, 2018, 08:35   #19
Genesis
Fuel Economy: 53/48/42
Moments, read what Oilhammer said AGAIN AND AGAIN until it compels you to get the wrenches out and remove the head.
If you replace the cam and lifters and do NOT remove the head the odds are VERY HIGH that you have a bent or otherwise compromised valve stem AT LEAST. There is NO WAY to see that without removing the head and then removing the valves. If it happened, and it almost-certainly did, you will be driving down the road at some indeterminate point in the future -- maybe a day from now, maybe a week from now, maybe a year from now -- and the valve in question will break with the mushroom dropping into the cylinder.
WHEN that happens the engine will stop immediately as the valve head won't fit in the space available. It ALSO has a very high probability of gouging the crap out of the piston, head, cylinder wall or all of the above. That has a high probability of at best trashing the rod and piston involved, plus the head, and a decent probability of damaging the bore badly enough that the engine is junk.
Take the head off and send it to Frank06.
Genesis is offline   Reply With Quote
Old February 21st, 2018, 18:12   #20
UhOh
UhOh's Avatar
OP, if you do the work yourself then I'm guessing you're looking at a low of around $750(?) to a high of...
As Oilhammer said, pull the head or get rid of it. SOMEONE is eventually going to have to pull the head. You might find out things are on the lower side of the repair equation BUT still opt to get rid of the car; in this case you'd be able to get more money because the (likely) full extent of the damage will be known. If you don't pull the head then anyone looking to buy the car pretty much has to assume that there's lower end damage and thus would be offering less money less because of this (assumption).
Old February 21st, 2018, 20:42   #21
Momentslater
I'm going to pull the head tomorrow, I'm going to buy the head rebuild kit from idparts if the head looks good and there's no cracks and or bottom end damage. If the head is damaged I'll get a new head and if the bottom end is damaged I'm not sure what I'm going to do with it. I got the car for $800 2 months ago, it had a clogged intake and the original owner wasn't very mechanically inclined. I gathered all its service records (all dealer work). $8000 worth of misc repairs and prevt. matinance over the past 2 years, timing belt/waterpump is 15k km old.
Old February 21st, 2018, 21:25   #22
Genesis
Figure out why the cam fractured. That's a rather odd failure in these engines.
Old February 21st, 2018, 21:49   #23
Momentslater
I can't really seem to think of any reason for the cam to snap, unless a piece of carbon broke off the intake that I missed and something happened in the combustion chamber? I can't think of anything outside of the valve-train to cause this failure.
Old February 21st, 2018, 22:28   #24
UhOh
UhOh's Avatar
This one is going to be worth the price of admission!
Old March 2nd, 2018, 16:02   #25
ToxicDoc
TDI(s): 2001 Jetta
Any update?
ToxicDoc is offline   Reply With Quote
Old March 3rd, 2018, 10:12   #26
wonneber
Maybe we offended him?
Old March 8th, 2018, 10:26   #27
Momentslater
I put a new head in last night and ended up breaking an injector fuel return nipple. Other than that it runs great again. Was never really able to figure out the cause of the failure.
Old March 8th, 2018, 11:30   #28
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Nice work!
Old March 8th, 2018, 23:34   #29
UhOh
UhOh's Avatar
Well, crap, would have been nice to have solved the mystery, but, I suppose, the bottom line is to have a working engine! Good to hear that it's back in operation.
Old March 8th, 2018, 23:40   #30
Momentslater
The 1st and 3rd cam bearings were destroyed, the rest were perfect. Loss of lubrication due to PO use of bad oil clogging oil passages in the head causing failure of the cam bearings? There was metal shavings left behind in cylinder 1 when I pulled the head off, the shavings were copper in colour so I just chalked it up to valve/piston contact and moved on with the repair.
Car died on road! No start, no crank, no codes! FumbleMechanic VW B5 Passat TDIs 73 June 25th, 2016 13:40
05 manual - died - now no start and crank valdemar71 VW MKIV-A4 TDIs (VE and PD) 3 March 7th, 2014 10:20
Car died while driving, now no start? 06 5.9 TDI 101 30 January 30th, 2014 10:29
04 PD died while driving/ crank no start please HELP johnsongti VW MKIV-A4 TDIs (VE and PD) 19 September 9th, 2010 19:54
Died while driving, now no start arsenix TDI 101 2 July 26th, 2009 18:08
Page generated in 0.14874 seconds with 10 queries
[Output: 123.58 Kb. compressed to 102.83 Kb. by saving 20.75 Kb. (16.79%)]
