Old February 18th, 2018, 15:34   #1
bmwilson55
Default Fuel Line Alternative?
Hi all. 2003 1.9L TDI ALH. Thinking I need to replace the fuel lines that run between the filter and the Injection Pump. I looked up the part number (1J0130307R) and this thing sells for 90+ bucks new. Lord have mercy. It is 2 pieces about 12-16 inches long. Anyone use just basic diesel fuel line instead of this piece? Will order it if it does something special over standard fuel line. Thanks, Bryan
bmwilson55 is offline   Reply With Quote
Old February 18th, 2018, 15:39   #2
AndyBees
AndyBees's Avatar
The NEW Beetle of that era uses all black rubber (no clear hose on the In side).
I see no reason as to why you couldn't use anything as long as it fit and could handle diesel fuel/bio-diesel.
I have a "plain jane" fuel hose from the filter to the IP on the ALH in my Vanagon ... works great!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old February 18th, 2018, 18:15   #3
eddieleephd
Fuel Economy: 45-51.9
I recommend using some shielding if you go with generic fuel line to prevent it from rubbing too much.
I did that on my last MK4 and it worked perfectly.
The shaped hoses are crazy expensive!
I also look at rockauto to see if I can get a good price for things first.
Fuel lines is cheap though and you could replace it for $10 with shield.
2003 Jetta Wagon Alh w/5spd swap, 11mm IP, VNT17, Malone stage4 tune, BMW Cyclonic CCV filter, 2" lift
eddieleephd is offline   Reply With Quote
Old February 18th, 2018, 18:17   #4
drucifer
Check out this thread about clear teflon pfa tubing from McMaster Carr.
http://forums.tdiclub.com/showthread.php?t=374547
drucifer is offline   Reply With Quote
Old February 18th, 2018, 21:34   #5
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
Any fuel line works without problems. Get the braided ones, will be just fine.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old February 19th, 2018, 19:24   #6
VincenzaV
VincenzaV's Avatar
Fuel Economy: Better than a tank, worse than a cyclist.
I use NAPA Greenshield, diesel rated. Generic unformed hose.
VincenzaV is offline   Reply With Quote
Old March 8th, 2018, 06:15   #7
VIPNiSS
TDI(s): MK4
I am looking at using the same. How is it holding up for you so far? Did you do the fuel lines close to the coolant reservoir to coolant tank?
VIPNiSS is offline   Reply With Quote
Old March 9th, 2018, 19:01   #8
VincenzaV
VincenzaV's Avatar
I'll check it tomorrow, but from last time I remember looking at it for a fuel filter change <6mo ago, great!!!
Yes, I did the coolant overflow area lines. I really wanted to stay stock molded line because they look so great, but the insane prices made me say HECK NO!!!!
Old March 13th, 2018, 21:38   #9
xjfish
TDI(s): 01 Golf
I recently purchased USED lines off ebay for the time being. About $35 IIRC. My car originally had all regular black molded fuel lines. (Auto Golf) They look o.k. for now... The manual trans looking lines with clear section look like they will fit just fine, will confirm soon. Just an option.
xjfish is offline   Reply With Quote
fuel line: pre-formed or just good fuel line replacement bob141 TDI 101 6 February 9th, 2016 12:42
Oil feed line, cheap aftermarket alternative? jyhuh28 TDI 101 17 May 9th, 2014 19:21
Fuel line options? 5/16" HP fuel line work? 3baudios VW MKIV-A4 TDIs (VE and PD) 7 December 2nd, 2013 19:07
Suitable fix or alternative to the fuel line clips maclaveau TDI 101 1 September 24th, 2009 09:19
The Alternative Alternative Fuel dilt1 TDI News/Tech 63 December 11th, 2003 07:57
Page generated in 0.14363 seconds with 10 queries
[Output: 89.48 Kb. compressed to 76.31 Kb. by saving 13.17 Kb. (14.71%)]
