Old February 24th, 2018, 22:31   #31
Steve Addy
TDI(s): 97 Mk3
Originally Posted by Abacus View Post
The center will just press out.
Iíve had one fail on me at around 80k and seen 2 others fail under 100k. It was new but had the smaller bearings and not the larger one. If theyíre all thatís available I recommend changing them with the timing belt. I have changed the ones with the 17mm center due to them feeling dry but have never had one actually fail.
Steve, I may have a spare I can drop in the mail. Iíll have to check my stash.
That would be great Mark but don't go to a lot of effort. I'm sure at some point I will stumble upon a tensioner pulley with a 17mm insert.
Originally Posted by ToddA1 View Post
Hmmmmm..... Iím curious what the 17mm one will log. Makes me want to look at one and see if it can be relubed.
At around $5 each, for the Uro, youíll log 200k before you reach the cost of the Mustang part.
-Todd
Todd, that's one manufacturer I don't trust at all for just about everything they sell. I think I have a flange somewhere by URO and I'm not excited about using it.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Old February 25th, 2018, 06:03   #32
Abacus
That helpful B4 guy
Abacus's Avatar
Lol, figures you tried.
-Todd
Hey, you know me, I just had to see what would happen.
'97 B4: 453,000 miles Malone 3, K03/04 Hybrid Turbo, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate,
BUG*PWR 2013 Award Winner
Timing belt replaced 2 weeks ago...now the alternator belt snapped degree_tdi VW MKV-A5 Golf/Jettas 17 November 30th, 2011 10:09
Gurgly-bearing noise after serpentine belt popped now no charging of batt 85_305 TDI 101 32 February 23rd, 2011 11:49
Alternator Belt or Timing Belt Cracks? AndrewAugust VW MKIV-A4 TDIs (VE and PD) 4 November 19th, 2009 05:49
06 jetta serpentine belt/alternator belt diagram TDICube VW MKV-A5 Golf/Jettas 2 August 8th, 2009 14:25
Timing Belt Popped on Client alphaseinor TDI 101 14 February 21st, 2008 14:46
Page generated in 0.10723 seconds with 10 queries
[Output: 57.40 Kb. compressed to 53.12 Kb. by saving 4.29 Kb. (7.47%)]
