Old February 18th, 2018, 12:12   #1
Inhabor
Default 1971 vw bus tdi conversion
Hi guys. It took me a while but I finally found the correct forum. I'm in the process of installing a 1.9 ALH in my 1971 vw bus. Does anybody here done this before? Is there any tdi gurus in Florida? This is a new field for me and I would like to learn as much as I can about tdi. I kind of need help with the wire harness now. I'm still wating on my transmission to be built but I would like to have the harness ready for when the tranny gets here. Also, how do I post pictures here? The donor car is a 2002 jetta.
Inhabor is offline   Reply With Quote
Old February 19th, 2018, 05:54   #2
vwztips
vwztips's Avatar
Hey is this a TDI from 2000: A Space Odyssey? Haha, I assume it is an ALH instead of a HAL. If you are new to this and needing direction or a ready to use harness, reach out to Hasenwerk on this site. He knows harnesses inside and out and can build you one.
vwztips is online now   Reply With Quote
Old February 19th, 2018, 15:20   #3
Inhabor
Thanks,l think I have dyslexia. Lol
Old February 19th, 2018, 16:48   #4
markd89
My thread (linked below) has lots of info. Unfortunately the pictures are broken. There is also another thread on thesamba.com of someone else who has done a bus.
Biggest question is the transaxle. This is a big cost and something to decide on properly the first time. I have a regeared 091 and a Kennedy plate. A better way IMO is an upside down longitudinal TDI transaxle. There was also a guy who installed a the stock TDI trans and engine by welding it all into his bus, mid-engine. This turned out surprisingly well.
If you go 091, figure out how to not have the head water outlet smack into your fuel tank. Options other have done include changing the fuel tank shape or making a custom flange.
For intercooler: After trying almost everything, I went dual Air-to-water. This works. A better solution is a huge under-bus air-to-air intercooler. That has been done with success in a Vanagon. All of the other ideas I have seen, which mostly involve an A2A intercooler in the engine way, with and without fans, with and without ducts had disappointing results.
Other general advice: Read a lot of other projects. Look for people who have done ANY watercooled engine into a baywindow for general info on cooling, etc. as it applies to your scenario. Look at the Vanagon TDI group on yahoo for TDI into VW Van info. This stuff applies to your scenario too, minus the cooling.
Good luck and post lots of pictures!
Mark
1978 VW Bus 1Z TDI Build thread: http://forums.tdiclub.com/showthread.php?t=308793
markd89 is offline   Reply With Quote
Old February 19th, 2018, 19:27   #5
Inhabor
Mark
I have been doing research and reading everyting I find for a year now. The radiator is alredy installed under the bus. The new 002 LST and proper gears for the tdi should be done next week. It is expensive $3400. I want to do it wright the first time. Thanks for your hep.
Old February 20th, 2018, 03:38   #6
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Cool project, post some pics!
Yeah you will for sure not want the stock gearing from a 1600 Bus. The ALH in stock form is literally about twice the HP, and I would bet thrice the TQ.
I had a '71 Westy, drove it all over the place. Great vehicle. Stuck to 65 MPH, never any faster, and it did that OK. Was reliable and had a lot of fun in it! It had about the same get up and go as my diesel Vanagon... so, not much. A TDI would be an excellent upgrade!
oilhammer
www.cardocautomotive.com
Old February 20th, 2018, 06:49   #7
jimbote
jimbote's Avatar
it's from a 2001
Old February 22nd, 2018, 19:50   #8
leecat
Hi Inhabor; I'm as far away from Florida as you can get, but I installed a 1.9 AHU into my 1969 Westfalia and love it. My swap was different in that I used the Jetta 1.9 manual transaxle as well as the engine, so might not be the same thing as you're considering - sounds like you are using a stock-ish transmission. Feel free to drop me a line if you'd like and I would sure try to help in any way!
leecat is offline   Reply With Quote
Old February 23rd, 2018, 04:42   #9
Inhabor
Thanks, I will.
Old February 23rd, 2018, 06:32   #10
AndyBees
AndyBees's Avatar
Inhabor, do you know what the 4th gear and Ring & Pinion Ratios will be in your tranny?
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old February 23rd, 2018, 16:03   #11
Inhabor
4.57 ring and pinionand .82 4th gear.
Old February 27th, 2018, 05:56   #12
Inhabor
What did you used for fuel pump?
Old February 27th, 2018, 06:17   #13
AndyBees
AndyBees's Avatar
Other than the location of the fuel tank, most everything in your swap will be similar to my 84.
The Injection Pump does all the pumping without any assistance. A lift pump has not been necessary.
Old February 28th, 2018, 08:18   #14
markd89
FYI: I had a .70 and switched to a .77. I kinda wish I kept the .70. I'm also running much larger tires 16" 215 75 R16, You could still have sufficient power, drop RPMs and get more MPG with taller gears..
Old February 28th, 2018, 08:18   #15
markd89
Yours is one of the most creative I've seen. How many miles on the swap now? Any issues?
Mark
VW Bus or Vanagon TDI conversion parts... Brad01mc Private TDI Items for Sale/Wanted 2 October 12th, 2009 17:25
VW Bus or Vanagon TDI conversion parts... Brad01mc TDI Conversions 7 October 11th, 2009 16:49
1968 VW Bus TDI Conversion BioBus TDI Conversions 1 July 6th, 2006 11:33
1971 Turbo Diesel VW Van/Bus BHarrison Other TDI/Diesel Picture Gallery 4 March 7th, 2006 10:29
T3 Bus TDI-conversion site CFriedriszik VW MKIV-A4 TDIs (VE and PD) 0 December 21st, 2000 08:38
Page generated in 0.17389 seconds with 10 queries
[Output: 131.02 Kb. compressed to 109.46 Kb. by saving 21.56 Kb. (16.45%)]
