Old February 18th, 2018, 12:55   #1
Hansd99
TDI(s): 1998 Jetta
Default Help!! Pump to Cyl. Head & Oil Cooler hose replacement
Hey everyone. Had a hose blow out on me, pump to cyl head & oil cooler hose. PITA to get too, trying to find a write-up for the proper removal/installation of said hose. Hose was able to be pulled out without removing anything near it. The new hose is a different story.
I've checked youtube, google and done a few searches on here to no avail. anything via google/youtube seems to be for a gas engine or the 2.0.
Any help would be greatly appreciated. Trying to juggle 2 different work schedules with 1 car is not going smoothly.
Hansd99 is offline   Reply With Quote
Old February 18th, 2018, 16:19   #2
Mongler98
A: dont use photobucket, im not paying $40 a month just to view images you can upload here or facebook or ANYWHERE and post a picture link
What engine, AHU or ALH
the AHU is not hard to replace any hose, its just a PITA and you can do it, might skin your knuckles though a bit.
Old February 18th, 2018, 20:50   #3
Abacus
That helpful B4 guy
Abacus's Avatar
The '98 Jetta only ever came with the AHU.
I've done a bunch of these and they're a pain without the remote cable clamp pliers. With them they're still a pain but not too bad.
And the OP can upload pics to the forum pictures site and include them in posts.
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Old February 21st, 2018, 23:08   #4
Steve Addy
TDI(s): 97 Mk3
Once you get through this replacement patch etc I'd be interested in knowing what brand hose failed, if you wouldn't mind sharing that.
Steve A
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is online now   Reply With Quote
Old February 22nd, 2018, 06:39   #5
Mongler98
I replaced mine with some copper pipe and some high grade silicone couplers,
Old February 23rd, 2018, 10:42   #6
Steve Addy
TDI(s): 97 Mk3
This is the likely culprit, it's the one that's most vulnerable.
I've never heard of the other hose failing down there although it could.
The replacement is straight forward, just remove the old hose collecting as much coolant as you can, replace the hose and then filter the old coolant and return to the system.
Post up pictures to the forum if there's a different situation going on but really there's not that much to do, but it is not that easy because of the spatial constraints down there.
Steve
ALH oil cooler and vac pump leak, best replacement brand? DieselHuffer TDI 101 3 February 13th, 2016 07:40
WTB Flex Metal hose for the EGR cooler & all 3 EGR Cooler rubber hoses tothemax Private TDI Items for Sale/Wanted 5 July 29th, 2014 08:43
Cyl. Head replacement? GTRAMSAY TDI Power Enhancements 1 September 9th, 2011 08:51
FS: Hose, pump to head & oil cooler, A3 TDI clyde Private TDI Items for Sale/Wanted 6 August 21st, 2009 06:04
Cyl. head replacement NKY longdrive VW MKIII-A3/B4 TDIs 9 November 30th, 2007 05:59
Page generated in 0.13785 seconds with 10 queries
[Output: 75.61 Kb. compressed to 66.31 Kb. by saving 9.30 Kb. (12.30%)]
