Old February 17th, 2018, 08:47   #1
Nugget3816
Default Overboosting problems
I've got a 2002 VW beetle with a 1.9, I'm having issues diagnosing a problem. I've changed MAF sensor and VNT actuator, but it still doesn't go passed 4000 RPM. If I disconnect the vacuum to the actuator it'll rev up to over 5000 RPM, it runs fine up until it hits third gear and then it just has no giddy up and go. It takes about 3/4 of a mile to hit 60 mph. I'm pretty much baffled at this point. Any suggestions would be appreciated.
Nugget3816 is offline   Reply With Quote
Old February 17th, 2018, 10:09   #2
PB_NB
PB_NB's Avatar
Hi Nugget, you should really scan the car with VCDS if you have one. Throwing parts at the problem just empties your wallet! If it is overboosting, you will be able to log that and work towards correcting it.
Your other/previous posting on this same topic should be linked to this so you can benefit from the knowledge from the experts on this forum.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old February 17th, 2018, 10:13   #3
Vince Waldon
Vince Waldon's Avatar
Perhaps track down Canadian Grizzlie's "diagnosing limp mode" HOW-TO that's listed in his signature... a clear methodical scientific way to track down causes of over/underboosting.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old February 19th, 2018, 09:47   #4
Nugget3816
Ok, so turbo has been cleaned. Took it out for a test drive, engine light came on after about 2 miles. Put it on the scanner and still having an overboosting problem.
Old February 19th, 2018, 10:18   #5
Nugget3816
Ok, so now I have no engine light coming on. But I did find out my N75 is junk, I was pulling it up on to car ramps and it wouldn't do it. Just alot of black smoke, switched it with the egr solenoid and it climbed right up. Still seems a little sluggish though.
Old February 19th, 2018, 10:24   #6
Mongler98
what is the code?
bad n75 vlave and bad vacuum lines or a bad actuator, this is the only few things that really can cause this issue save for some rarer things but we will cross that bridge when we get to it.
Old February 19th, 2018, 11:10   #7
Nugget3816
It's definitely a bad N75. Now I'm just trying to fine tune the actuator, I can't get it to "open" all the way. It won't quite touch the stop set screw. If it does then it'll only move maybe an 1/8 of an inch.
Old February 19th, 2018, 11:11   #8
Nugget3816
The code was 0234
Old February 19th, 2018, 15:09   #9
Mongler98
replace actuator, and all your lines, then the n75 last as its the most $$$
Old February 19th, 2018, 15:22   #10
Nugget3816
Already replaced actuator, MAF sensor, cleaned turbo and now I just need to replace N75 and hoses
Old February 19th, 2018, 16:03   #11
Mongler98
then it just needs adjusting
Old February 24th, 2018, 13:15   #12
Nugget3816
Ok new problem, the car won't start unless I unplug the EGR valve from the vacuum
Old February 24th, 2018, 16:29   #13
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
That means you have VAC lines criss crossed somewhere
Stella (Mine now): 2005 Shadow Blue Jetta Wagon TDI 09A
Mods: RC1. VCDS HEX-CAN USB (near Toledo, OH)
JDSwan87 is online now   Reply With Quote
Old February 24th, 2018, 19:03   #14
UhOh
UhOh's Avatar
Yup!
Old February 27th, 2018, 17:43   #15
Nugget3816
Took the beetle to a shop, they ran diagnostic on and come to find out the intake is almost completely sooted up and plugged.
Overboosting help Straitiff11 VW MKIII-A3/B4 TDIs 3 September 10th, 2016 13:29
Help - Am I overboosting ace123655 VW MKIV-A4 TDIs (VE and PD) 11 May 15th, 2015 05:31
overboosting vince557 VW MKIII-A3/B4 TDIs 3 May 19th, 2012 22:11
Overboosting? H2O2H TDI 101 26 April 5th, 2010 19:13
Overboosting Mikekits TDI 101 0 August 4th, 2006 15:15
Page generated in 0.16767 seconds with 10 queries
[Output: 119.85 Kb. compressed to 99.40 Kb. by saving 20.45 Kb. (17.06%)]
