Old March 2nd, 2018, 17:57   #61
Millennium Falcon
What mounts do you recommend? Ive seen all different kinds used on these engines..
Originally Posted by Hasenwerk View Post
Great looking job - my suggestion is that you find better motor mounts - those rubber ones look rather hard and it will be vibration city for you when done.
2003 Jetta TDI wagon, 5-speed, swap, Sprint520 nozzles 165k
2004 passat 1.8t auto 104k
1949 Willys cj3a ALH tdi swap
Millennium Falcon is offline   Reply With Quote
Old March 2nd, 2018, 22:06   #62
turbobrick240
turbobrick240's Avatar
Wow, awesome project!! A family friend had a CJ3b with the hurricane engine as a tractor/woodlot buggy/snow plow. The thing was unstoppable.
I just read this article about a Willys size diesel Mahindra jeep that will sell over here:
https://jalopnik.com/the-mahindra-ro...-am-1823460351
Old March 3rd, 2018, 23:54   #63
Millennium Falcon
Thanks! Yes the Mahindra jeeps are cool. I would like to see one in person.
Made a little progress... Worked on the oil system. Finished my oil filter relocation plate. Figured out my turbo oil feed hookup, oil pressure gauge, and VW oil pressure sensor. Everything is close on the plate but it all fits. I need to work on the oil filter and cooler mount. I'm still waiting on my hoses and a few more fittings. Also need to order a fuel filter.
Since I have no need for the willys timing mark cover now.... I turned it into a key chain. Willy on one side. VW on the other.
Old March 5th, 2018, 11:17   #64
Hasenwerk
Hasenwerk's Avatar
Originally Posted by Millennium Falcon View Post
What mounts do you recommend? I've seen all different kinds used on these engines..
I've always used Volkswagen Fox / Audi 80 mounts as they are cheap and work well!
http://fastforward.ca/motormounts/ is how I have done the mounts for my Vanagon conversions back in the day - much much simpler than making mounts that bolt to the side of the engine. Chop saw, drill press and welder - that's it!
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
Old March 5th, 2018, 16:13   #65
Millennium Falcon
What are the rubber mounts in the link from? They look more like trans mounts ive seen before? Part number? Thanks!
Old March 5th, 2018, 19:14   #66
Hasenwerk
Hasenwerk's Avatar
Volkswagen part number 893 199 381 B
David Marshall
Old March 5th, 2018, 21:08   #67
Millennium Falcon
Cool! Thank you!
Old March 6th, 2018, 21:35   #68
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
Thanks Zook! I couldnt have done it without your inspiring pictures and info!
Glad I could help,
and give back a little .
1.9ZOOK is offline   Reply With Quote
Old March 6th, 2018, 21:49   #69
Millennium Falcon
Does anyone have any tips on running a v-belt on an ALH? I thought I saw somewhere a guy bolted one on to his stock crank pulley? Are there any older tdi pulleys with a v-groove that would fit the ALH crank?
Old March 7th, 2018, 06:29   #70
Millennium Falcon
Someone told me that the v-belt pulley from a 1.6 will bolt on to the ALH pulley. Can anyone confirm this?
Old March 7th, 2018, 10:49   #71
Hasenwerk
Hasenwerk's Avatar
Crank pulley - yes, same bolt pattern for the pre and post 2000 blocks.
David Marshall
Old March 8th, 2018, 18:40   #72
Millennium Falcon
Thanks for the info Hasen-
Well after about 20 hours of googling and online research I decided on a radiator for my tdi swap. I went with a 1986 Ford bronco II (2.9L) it was the right size and had the in/out on the correct side for my application. I will have to lower my mount about 1” to clear the hood, but my mounts aren’t original anyway so it’s not a big deal. I got this at advanced auto. With the online promo they are running right now it cast me $72 and it was in stock.
Its tight but it fits!
Fitted the rest of the front end temporarily fitted before I paint it. That way I dont have to hack into fresh paint......again! Im trying to figure out how I want route/install my intercooler and piping. I also need to mount my oil cooler/ filter and fuel filter....so much to do!!!! haha!
Skipping the inter cooler is financially temping and im getting tired....but I know that is a big no-no.....
Old March 9th, 2018, 08:59   #73
jmodge
Looking good, hang in there Seth, good progress
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Old March 9th, 2018, 09:47   #74
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Fuel Economy: 50mpg on B100
That is so cool, I love those old Jeeps.
2001 Beetle - EGR delete, 01M-ectomy, Atlas skidplate, vented, Frostheater.
I'm not coasting, I'm shifting slowly.
UFO is offline   Reply With Quote
Old March 11th, 2018, 23:56   #75
Millennium Falcon
Thanks guys! Oil & Fuel system is almost wrapped up. (The fram filter is just for mock up, it was the only one I had on hand) I still need to run my fuel return line and put some straps on the the hoses. Then its on to the coolant system and wiring.
1942 Willys MB rock crawler build rooney77 TDI Conversions 267 April 22nd, 2015 16:06
FS: ALH engine $450, 3rd injector, 2002 ALH ECU, 4-wire ALH glow plug harness 1chrisapple Private TDI Items for Sale/Wanted 12 February 8th, 2015 11:22
1949 Chevy Pickup. Hybrid Electric/Diesel superman22x TDI Conversions 12 January 31st, 2014 14:33
1961 Willys jeep 1.9 Y1 swap SirLoinOfBeef TDI Conversions 9 May 18th, 2013 09:47
TDI in a Willys CJ Todd J. Roach TDI Conversions 5 September 14th, 2009 16:40
Page generated in 0.17598 seconds with 10 queries
[Output: 136.21 Kb. compressed to 114.45 Kb. by saving 21.76 Kb. (15.97%)]
