Old February 26th, 2018, 10:30   #46
ManicMechanic
Nice work.
ManicMechanic is offline   Reply With Quote
Old February 26th, 2018, 22:06   #47
Millennium Falcon
THanks! Engine/Trans is all bolted together and sitting in the frame. No motor mounts yet but getting there. You may want to look away is you get squeamish around firewall cutting. I had to make room for the vacuum pump and water outlet on the back of the head. I will make a nice box that will close it all up, and paint it to match. I hooked up the battery and cranked it over a second or two with the starter to make sure engagement was good. It turned over just fine. I cranked it in gear with the clutch depressed to make sure it would release. So far so good. Now time to fix the firewall, make motor mounts, and plumb everything.
2003 Jetta TDI wagon, 5-speed, swap, Sprint520 nozzles 165k
2004 passat 1.8t auto 104k
1949 Willys cj3a ALH tdi swap
Millennium Falcon is offline   Reply With Quote
Old February 27th, 2018, 06:16   #48
Millennium Falcon
BIG OBSTACLES
1) steering box/oil filter clearance
2) water outlet clearance on the back of the head.
3) Exhaust downpipe
LITTLE ANNOYANCES
1) Motor mounts
2) Box in firewall
4) run coolant lines
5) run fuel lines
6) inner cooler
7) oil cooler
8) wiring
9) Plumb return line to fuel tank
Im sure there will be more these are just the ones that come to mind.....easy peasy right? hhaha!
Old February 27th, 2018, 06:33   #49
jmodge
No small project there, looking good. what are your thoughts on making that box removeable for servicing? Leakage and timing belts come to mind.
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Old February 27th, 2018, 06:45   #50
Millennium Falcon
Yes, My plan is to make a removable panel big enough to put the cam lock in for timing belt service.... this engine needs a timing belt before its put on the road. I will just have to figure out the best way to do it and keep it sealed up well
Old February 28th, 2018, 00:00   #51
Millennium Falcon
I started messing around with making my own relocation plate.... I only have like an 1" of clearance. I may try to move my drivetrain over at least 1/2 or so. Because when the engine rocks i dont want it to hit the plate.
Replacing this
Old February 28th, 2018, 00:04   #52
Millennium Falcon
I still need to add add the turbo line and the oil sensor.
Old February 28th, 2018, 10:46   #53
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
Are you going to tap those holes and use A/N fittings?
If you haven't removed the turbo oil line yet be super careful,they twist and break real easy. I replaced the hard line with a braided one,I twisted the hard line
when trying to remove it.
1.9ZOOK is offline   Reply With Quote
Old February 28th, 2018, 21:02   #54
Millennium Falcon
Yeah I avoid solid turbo feed lines.... I had one blow on me at work one time.
Lost almost all of the oil in a minute. I went to a braided line.
I just ordered another one for this engine. SO much nicer to work with. Yes I am going to be using -8an fittings and hoses on everything. I am just going to run a spin on oil filter and remote oil cooler. I know the filter wont be as good as the stock VW one, but spin ons are cheap. I will just change the filter more often. The plate will still have the port for the turbo banjo bolt and the oil sensor. I am also going to tap it 1/4 npt for the factory oil pressure gauge inside.
Old March 1st, 2018, 09:16   #55
Scatman
Hello everyone, my name is Uli I live in Freiburg Germany.Selber I have a Unimog 411 rebuilt on Tdi. 35 years ago, I also had a Willys I've converted to Mercedes 508 gearbox and 3 liter Ford V6. I can not speak English well, so I use the Google translator. I am very impressed by the Willys conversion and I am looking forward to the performance and of course the consumption. Should the 3-speed transmission remain in the future with your Willys? With us, many Willys were converted to Mercedes diesel with 4-speed gearbox. With the enormous torque of the Tdi, it is certainly possible because even at the front there is still a lot of space to use a 5 or 6-speed gearbox. VG ULI
Scatman is offline   Reply With Quote
Old March 2nd, 2018, 06:36   #56
Millennium Falcon
Ive made some progress over the past few days.... Made my motor mounts and modified my water neck so it exits towards the passenger side. It was pretty much pointing right at the brake pedal. I also shorted it some so it doesnt stick out as far. The engine is now bolted in and supported in the frame! Waiting on shipping of a bunch of fittings and stuff for my oil system.
My biggest concern now is whether or not I will have room for my radiator!!
Old March 2nd, 2018, 10:43   #57
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Nice!
Looks like there is no heater,so I think you can just 180 rubber hose the outlet
to the metal tube that goes to the water pump.
Maybe a stand alone Mojave heater for heat?
Old March 2nd, 2018, 13:45   #58
Hasenwerk
Hasenwerk's Avatar
Great looking job - my suggestion is that you find better motor mounts - those rubber ones look rather hard and it will be vibration city for you when done.
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
Old March 2nd, 2018, 17:38   #59
Millennium Falcon
Im not planning on ever putting a top or heater on this jeep so one less thing to worry about. Yeah these motor mounts are experimental. If/when they suck I will find something better. I used these on my Mercedes diesel and have been happy with them for 4 years. But it wont be a big deal to change them out if they rattle my fillings out haha! What ever mounts I use cannot allow too much movement because my steering shaft is about 1.5" from hitting my oil filter plate.
Old March 2nd, 2018, 17:39   #60
Millennium Falcon
Thanks Zook! I couldnt have done it without your inspiring pictures and info!
Nice!
1942 Willys MB rock crawler build rooney77 TDI Conversions 267 April 22nd, 2015 16:06
FS: ALH engine $450, 3rd injector, 2002 ALH ECU, 4-wire ALH glow plug harness 1chrisapple Private TDI Items for Sale/Wanted 12 February 8th, 2015 11:22
1949 Chevy Pickup. Hybrid Electric/Diesel superman22x TDI Conversions 12 January 31st, 2014 14:33
1961 Willys jeep 1.9 Y1 swap SirLoinOfBeef TDI Conversions 9 May 18th, 2013 09:47
TDI in a Willys CJ Todd J. Roach TDI Conversions 5 September 14th, 2009 16:40
Page generated in 0.16317 seconds with 10 queries
[Output: 130.42 Kb. compressed to 109.28 Kb. by saving 21.14 Kb. (16.21%)]
