Old February 15th, 2018, 18:10   #1
Millennium Falcon
Default ALH 1949 willys cj3a
I am planning of putting a VW diesel in the jeep. Im in the early stages but I think it should be a good swap. I started working on the adapter plate. I have the template made, I just need to finish it and bolt it all together check the alignment before I start making chips.. It is physically the same size as the l-head. It has obvious performance gains. I think it will be a good fit. The plan is to make the back of the VW block/crank mimic the L-head. The adapter is pretty simple and once I get the flywheel depth figured out I will start making the crank adapter. If all goes as planned I wil use the stock willys bell,clutch,starter(gear reduction) and stock the t-90 trans.
Here is what its going in.....
(I cant get my IMGUR pictures to post in the correct size. They take up like 10 times the normal size)
2003 Jetta TDI wagon, 5-speed, swap, Sprint520 nozzles 165k
2004 passat 1.8t auto 104k
1949 Willys cj3a ALH tdi swap
Millennium Falcon is offline   Reply With Quote
Old February 15th, 2018, 20:45   #2
Exenos
TDI(s): 02 Golf
you need to resize the picture in imgur once you upload them. Need to click on the pencil thingy. I always just change the largest dimension to 1000px and leave it at that.
Exenos is offline   Reply With Quote
Old February 15th, 2018, 22:30   #3
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
Cool Swap!
1.9ZOOK is offline   Reply With Quote
Old February 16th, 2018, 00:13   #4
Millennium Falcon
Let me try uploaded a picture now with exenos's advice.
I used a dummy shaft and a bearing retainer to help me center the crank to the trans.
https://youtu.be/iYSohDaMOvs
Old February 17th, 2018, 07:40   #5
jimbote
jimbote's Avatar
nice project! i would bolt a dial indicator to the crank and rotate it inside the bell bore to get center ... the rod in the pilot bore might seem like an accurate way to detect center but just a tiny angular error at the crank can equal way over spec at the bell bore
Old February 17th, 2018, 09:26   #6
Millennium Falcon
What is "spec" I am at .0015-.0020 at the bell bore right now.
Old February 17th, 2018, 09:28   #7
jimbote
jimbote's Avatar
what is your measurement method ?
Old February 17th, 2018, 09:29   #8
Millennium Falcon
The hardest part at the moment is clamping the bell to my adapter to get it centered. Im not drilling any holes yet. I may lay the engine on its nose to remove gravity from the equation. An extra set of hands would be helpful.
Old February 17th, 2018, 09:35   #9
Millennium Falcon
I used two different dial indicators. I indicated the crank like you said then the did the same thing with the dial indicator attached to my test rod as well to compare my findings. I got about a extra 1.5 thousands out on the rod... but im still only at like .003-.004 all the way out at the trans. Im happy with that.
Old February 17th, 2018, 09:41   #10
jimbote
jimbote's Avatar
any centering method that does not incorporate rotating the crank in reference to the bell bore has inherent inaccuracies... very simple rig, you can borrow mine for a security deposit
Old February 17th, 2018, 09:42   #11
jimbote
jimbote's Avatar
sounds good
Old February 17th, 2018, 16:28   #12
Millennium Falcon
Do you know what the allowable run out is at the crank/flywheel? The willys manual say .002 Not sure about the VW
sounds good
Old February 17th, 2018, 17:12   #13
jimbote
jimbote's Avatar
your numbers sound fine.... iirc the radial limit is around .007 or .014 total but that's from a guide for centering a v8 bell housing
Old February 17th, 2018, 19:55   #14
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
I shot for 0,and ended up around .005.
It's been going fine for 2000 miles.
Old February 18th, 2018, 11:57   #15
Millennium Falcon
Nice! Any vibrations or issues?
1942 Willys MB rock crawler build rooney77 TDI Conversions 267 April 22nd, 2015 16:06
FS: ALH engine $450, 3rd injector, 2002 ALH ECU, 4-wire ALH glow plug harness 1chrisapple Private TDI Items for Sale/Wanted 12 February 8th, 2015 11:22
1949 Chevy Pickup. Hybrid Electric/Diesel superman22x TDI Conversions 12 January 31st, 2014 14:33
1961 Willys jeep 1.9 Y1 swap SirLoinOfBeef TDI Conversions 9 May 18th, 2013 09:47
TDI in a Willys CJ Todd J. Roach TDI Conversions 5 September 14th, 2009 16:40
Page generated in 0.20528 seconds with 10 queries
[Output: 130.31 Kb. compressed to 108.51 Kb. by saving 21.80 Kb. (16.73%)]
