Old February 13th, 2018, 07:02   #1
tsspencer2887
Default Computer MPG vs Hand Calc after the fix
This may be an old topic but I didn't find anything about it. If so, please refer me to that thread and delete this one.
I had the fix on my 2011 Sportwagen 6MT a few weeks ago but I haven't been the one to refill the tank yet. Others in my family have taken it on some long road trips but they don't know how to reset the computer. Prior to the fix, the computer showed ~1-1.5 MPG higher than hand calc. My Dad drove the car on a trip a week ago and swears that I'll be lucky to get 40 MPG now. However I took it on a short trip (~150 miles) and the computer's MPG had me averaging ~48-49 MPG.
I'll know how far off the computer is the next time I fill up but I don't know when my next long range trip will be. Is there any reason that the computer should be further off now than it was before? Just wondering if anyone has noticed a difference.
tsspencer2887 is offline   Reply With Quote
Old February 13th, 2018, 08:27   #2
jbright
I have recorded both computer averages and hand calculated averages per tank since buying my 2009 new. After the fix (in October), the computer is off 2 to 4 mpg (higher than hand calculated) vs .5 to 1.5 before. This is all based on routine mixed driving in Indianapolis. It will be interesting to do a long highway trip and see the numbers then.
2009 Jetta TDI, black, tan interior with black dash, DSG, 16" Wheels, Build date 11/08. 'Fixed' 10/18.
47.8 mpg best tank, all interstate @ 70 mph ----- 162,000 miles on odometer.
2004 Toyota Solara SLE V6 (wife's), 1979 Diesel Rabbit (RIP), 1981 VW Diesel Pickup (RIP), 1986 Jetta gasser (gone).
jbright is offline   Reply With Quote
Old February 13th, 2018, 08:33   #3
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
I’m a different TDI model & generation, but the MFD on mine typical shows 2 to 2.5 mpg (roughly 4%) higher than actual, and I record every tank on Fuelly. I haven’t tried correcting with VCDS because it’s not that important to me honestly.
Blue_Hen_TDI is offline   Reply With Quote
Old February 13th, 2018, 09:43   #4
Lightflyer1
Lightflyer1's Avatar
It is possible but only you will know when checked. If you are near Austin I have VCDS and we can reset it so it shows near actual once you find the setting you need. Who really cares what the computer says if it is wrong? Take some trips and find the number and get it reset so its closer. All highway vs all city will show different results as well in my experience.
2015 Beetle TDI.
Old February 13th, 2018, 14:44   #5
Smashed Ixnay
Only had a 2010 Jetta TDI and it was 0.5-1mpg off without the fix. My new 2015 Passat TDI with the fix is 2-4mpg off from what I've noticed, but I haven't had a true full fill up. Right now I have 2 more days of driving and I'll have to fill up. Assuming nothing happens between now and then, I'll be able to give a real answer.
Smashed Ixnay is offline   Reply With Quote
Old February 13th, 2018, 15:21   #6
Lightflyer1
This shouldn't be based on one tank but several at least. (redacted) Read that wrong.
2015 Beetle TDI.
Old February 14th, 2018, 06:07   #7
tsspencer2887
Thanks for the input. All of my day to day driving involves rush hour traffic in DFW (aka "the metromess"). So I typically average 36-37 MPGs (hand-calc). However, we have a trip coming up to Florida next month and are deciding between taking my Jetta or my mother's far more comfortable yet much less fuel economic ML350.
Old February 15th, 2018, 08:50   #8
Q5TDI
TDI(s): Q5
How does the computer calculate the mpg and mileage left before an empty tank?
When I would fill up my 2014Q5 TDI pre-fix, the computer would often tell me I could go 650 miles before the tank went empty. I would be lucky to go just over 600 miles in most cases, and in several cases, I could only go 500-525 miles.
Still, by hand calculation, my TDI consistently got 29-31 mpg, which is what the computer would tell me for the overall mpg since I bought the car. I drive about 50/50 highway and around town.
I would never base mpg of the instantaneous mpg number, which can fluctuate between 5 mpg and over 200 mpg, depending on if the car is going uphill, downhill, accelerating, etc.
Q5TDI is offline   Reply With Quote
Old February 15th, 2018, 10:55   #9
forrest resto`s
I never got 48 49 mpg's on my 2011 jetta 6mt..before the fix and surely not after.. on a road trip i may get 43 if I'm lucky...hand calc.
forrest resto`s is offline   Reply With Quote
Old February 15th, 2018, 14:23   #10
tsspencer2887
Actually, the best I've ever gotten in this car was 52 MPG (hand calc).
Old February 15th, 2018, 17:02   #11
Smashed Ixnay
I just filled up and I ended up with 823.6 miles this tank. Odometer said 51.7mpg but hand calculated I got 48.5, which is in line with the 2-4 mpg difference I usually get. I did drive a lot slower and kept most of my speed at 70 mph and there was a few days I would do 65 on the way home just because I didn’t have to pick my daughters up and wasn’t in a rush.
I ended up driving about 8 miles once I hit 0 just bc I wanted to fill up at the same place. I know this car has an 18 1/2 gallon tank and usually the max I am able to put in there is 17 gallons so I wasn’t worried about driving a little once I hit zero.
Old February 22nd, 2018, 06:03   #12
tsspencer2887
Filled up last night and the computer overestimated ~2 mpg. At least 75% of the tank was rush hour traffic. I ended up getting about the same as I averaged in the same traffic prior to the fix.
Old February 22nd, 2018, 12:31   #13
toneman
TDI(s): 2011 JSW
I appreciate your comparative fuelly accounts - thank you. My 2011 JSW manual nets me ~31mpg in mostly city driving (yeah, I know) though it's been down almost 2 since I've left my roof racks on. No fix yet, part of the waffling undecided.
toneman is offline   Reply With Quote
Old February 22nd, 2018, 13:24   #14
Quincy
Is there a way to get the trip computer to run an average from reset to reset like every other vehicle I've ever had? My MPG is always started upon starting the car. It will continue the same trip if the car is stopped and started within a certain amount of time. I have always run the averages from fuel fill to fuel fill so I would know how inaccurate the computer is.
Quincy is offline   Reply With Quote
Old February 22nd, 2018, 14:06   #15
Blue_Hen_TDI
When you reset your trip odometer it resets the “mpg since refuel” readout.
Question re: computer range calc Heston84 TDI Fuel Economy 3 August 9th, 2015 15:57
MFI MPG trip calc? how does it work? RomanL TDI Fuel Economy 10 November 10th, 2011 05:06
MFA vs. manual calc (MPG) traubenberg TDI Fuel Economy 17 February 3rd, 2010 09:44
speed/mpg calc TDICube VW MKV-A5 Golf/Jettas 7 August 4th, 2009 19:04
Sudden Increase in MPG/Calc'd/MFD ATLSilverTDI TDI Fuel Economy 10 September 23rd, 2008 14:55
Page generated in 0.17892 seconds with 10 queries
[Output: 129.18 Kb. compressed to 107.78 Kb. by saving 21.40 Kb. (16.57%)]
