Old February 11th, 2018, 09:45   #1
Lex4TDI4Life
Lex4TDI4Life's Avatar
Default Backup Camera on MKIV Golf - Wiring Routing Options?
I recently installed a Pioneer MVH-2300NEX headunit (https://www.crutchfield.com/p_130230...tp=72453&avf=Y) in my 2001 Golf TDI. So far, I love it. It has an input for an optional backup camera. I have gotten used to the camera in my 2016 R and figured I would try to hook one up on the TDI. (Yes, yes, turn your head, don't be lazy, yadayadayada). I am scratching my head, however, over how I would want to route the signal and power cables into the cabin. My first instinct is to mount the camera right above the license plate and under the bumper lip that overhangs it. I might be able to take advantage of the ingress made by the plate light wiring.
Has anybody mounted a backup camera on a MKIV golf (or Jetta Wagon) and come up with decent solutions for getting the wires into the cabin?
TIA,
Lex
2001 Golf TDI 5 spd
RC2, Bosch T4-764 injectors, OMI, SBC Stg 2 Clutch, Koni FSDs, TT LCA Bushings, The Mystery Bar, Dieselgeek Panzer Plate, Elephant Hose, DG Race Pipe, Autometer Cobalt Boost Gauge, Boostvalve,Fumoto Valve, Mufflerectomy, Scangauge II
Lex4TDI4Life is offline   Reply With Quote
Old February 11th, 2018, 17:04   #2
Judson
TDI(s): 2001 Jetta
Well I did this on a jetta and ran the wires through one of the license plate lights. Worked well.
How to route it from there in a Golf I have no idea.
The location (meaning above the license plate) works well though.
If you really want to go crazy, do what I did, and buy an Alpine license plate holder:
https://www.crutchfield.com/p_500KTX....html?tp=71428
2001 Jetta TDI, converted to manual, black leather/red stiching, PP520s, rc4, franko6 cam, 11mm pump, VNT 17, PD150 intake, EGR/cooler delete, 2.5" Buzzken exhaust, PD150 clutch/flywheel, DRW six-speed, Eurojet intercooler, 3bar MAP, FIS Cluster, Cupra bushings, Koni Reds/stock springs, Alpine iLX-207, foglights, Indiglo boost gauge, Longbeach wheels, Euro wood steering wheel, lift pump, Gentex autodim/homelink mirror.
Judson is offline   Reply With Quote
Old February 12th, 2018, 07:04   #3
cuppie
Simple. Do like I did with the Passat, and get a camera that fits the car.
This camera replaces a license plate lamp, making it a bolt-on affair.
Cable routing: If you cut the RCA connector off of the camera, the wire will easily feed thru the harness tube (from gate to body.) Simply solder a new plug on.
Depending on the length of cable that comes with the camera, you might need to get an RCA extension cable (or, a simple cable + RCA F-F connector (was necessary on the big-a$$ B5.5 wagon; might be okay on a Golf.)
cuppie is offline   Reply With Quote
Old February 12th, 2018, 10:44   #4
Judson
TDI(s): 2001 Jetta
Wow! Never saw that before. Pretty cool!
Old February 12th, 2018, 12:17   #5
SilverGhost
SilverGhost's Avatar
How about this camera? LINK
Jason
SilverGhost is offline   Reply With Quote
Old February 12th, 2018, 12:43   #6
Lex4TDI4Life
Jason
Clever design! Looks like it pops in to replace the stock license plate light. I picked up https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. Obviously it will require a little more work and attachment to the bumper, but it apparently has a great image, including at night.
2001 Golf TDI 5 spd
Old February 12th, 2018, 15:02   #7
cuppie
Oh, it's awesome. Looks 100% factory, and the (similar) one that I got (honestly, the camera itself is probably identical) actually has pretty good picture quality, even at night.
Old February 13th, 2018, 18:26   #8
VincenzaV
VincenzaV's Avatar
Fuel Economy: Better than a tank, worse than a cyclist.
Love that light mount/camera/license plate light hybrid!
Good to hear image quality if gtg. I just mounted my wagon camera inside the rear hatch glass. At top of the center rearmost headliner trim. That way the camera lens won't get dirty/scratched. But, carrying cargo can bump it out of alignment...
Silverghost, is the Golf light/camera different size than Jettas?
VincenzaV is offline   Reply With Quote
Old February 14th, 2018, 08:27   #9
SilverGhost
Yeah, I believe they screw into the metal trunk lid on a Jetta, but snap into the plastic bumper in a Golf. Have to double check but I think that's right.
Jason
Old February 15th, 2018, 07:33   #10
graeme86
Fuel Economy: Worst ever 40.9 l/100km
I have just installed the factory Scirocco camera on my R32.
Need to cut a hole in middle of bumper between the number plate lights to mount it.
There are a whole bunch of adapter cables available from VW to hook everything up.
To get a coaxial plug on the camera requires the Japanese market version (easy to put an RCA plug on this version as well)
The Euro market versions have a "data" type cable with separate RGB connections.
Number plate light camera would certainly be an easier install!
Scirocco camera comes with a long harness that I ran through a 40mm grommet.
There are two plugs on each side of the rear panel under the bumper (top ones are used for sunroof drain hoses)
OEM+ Mods here:
http://www.users.on.net/~graeme86/
graeme86 is offline   Reply With Quote
Old February 16th, 2018, 06:37   #11
Lightflyer1
Lightflyer1's Avatar
I have that same/similar setup to install on my Beetle soon.
2015 Beetle TDI.
Old February 24th, 2018, 07:13   #12
Lex4TDI4Life
Jason
I assume you had to remove the rear bumper to get the wiring through, right? Or is there a magical way to avoid this?
2001 Golf TDI 5 spd
Old February 26th, 2018, 11:26   #13
SilverGhost
Well, I actually got a free little cube shaped camera and screwed it in right above the lic plate. But I removed the bumper - by far the easiest way to run the wires. Both tail light come out because there are screws under them that hold the bumper.
Unless you are Gumby, then no magical way to avoid this. I suppose you could take a lic lamp out, drop a string down. Also find where the wiring goes into the body and drop a string there. Then use the string to pull the camera wiring. This way you pull the harness out the bottom, then pull is back up to the grommet into the car. Just make sure the slack loop doesn't get caught up between the lic plate lamp and the grommet.
Not an easy task, but doable.
Jason
Anybody have a backup camera installed in a MK6 Golf? McGuillicuddy Ontario 0 October 31st, 2016 13:04
Backup camera HELP! wispassat VW Passat Family (NMS and B7) TDIs (2012+) 23 September 24th, 2015 08:09
Backup camera DouginNC VW Beetle 2012+ 29 June 27th, 2015 11:11
Adding the backup camera to my '13 Golf Liberated Upgrades (non TDI Engine related) 3 February 9th, 2014 13:01
Vw oem Golf cabriolet backup camera New williamgd2 Private TDI Items for Sale/Wanted 2 September 14th, 2012 08:21
Page generated in 0.14515 seconds with 10 queries
[Output: 122.53 Kb. compressed to 103.54 Kb. by saving 18.99 Kb. (15.50%)]
