Old February 9th, 2018, 10:03   #1
highmileage
Default A simple, basic question
After opening valve cover for camshaft change had some oil leakage after reassembly. Installed new gasket and still leaks. Will put on another new one, but wanted to ask if anyone had a tip for a good seal. Thanks in advance.
highmileage is offline   Reply With Quote
Old February 9th, 2018, 10:08   #2
maxmoo
which vehicle
maxmoo is offline   Reply With Quote
Old February 9th, 2018, 10:15   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Replace the valve cover.
oilhammer
www.cardocautomotive.com
Old February 9th, 2018, 10:53   #4
highmileage
Thank you for your responses. The BHW engine. I guess the cover tends to warp over time. But a gasket is so much cheaper............
Old February 9th, 2018, 12:42   #5
Mongler98
RTV on both sides of gasket, oil the cover and the head mating surfaces before you apply. Apply a mile amount and spread it on the gasket, let it air dry for about 15 minutes, now install and tighten finger tight, after 1 hour tighten it down as speck. if that dont work, try and bend the cover back into shape or just add more rtv. dont make a mess, the oil trick keeps it from sticking to the metal surfaces but makes extra room for it to seal.
Old February 9th, 2018, 17:49   #6
highmileage
Thank you.
A simple question for a not so simple answer groovey VW MKIV-A4 TDIs (VE and PD) 15 February 15th, 2016 16:06
Simple Basic question MPg ZeroZero TDI Fuel Economy 15 June 11th, 2012 06:54
basic question GT_Raven TDI 101 2 August 5th, 2007 12:17
Basic Question halon VW MKIV-A4 TDIs (VE and PD) 1 May 15th, 2004 14:24
Basic Question Muskie TDI 101 1 September 30th, 2002 19:21
Page generated in 0.11215 seconds with 10 queries
[Output: 71.48 Kb. compressed to 62.55 Kb. by saving 8.93 Kb. (12.50%)]
