Old February 9th, 2018, 06:55   #1
dkline87
Default Just picked up a one owner ALH
Hey yall,
Recently picked up a mint 2001 Golf TDI GLS, 4 door, 5 speed. It was a one owner car, with only 78,000 miles. This is my third diesel VW, the first was a 1980 rabbit (1.5 IDI), and then a 2005 Jetta PD.
The car has been maintained very well, but I'll be going through it and fixing some small cosmetics (window seals and hatch struts to name a couple).
Theres also a growing list of mods that I'll also be adding with time.
Probably another Rocketchip tune and nozzles to start.
Tips on anything to look out for as these cars age are welcome!
dkline87 is offline   Reply With Quote
Old February 9th, 2018, 06:56   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
All the fluids, check tires for date codes, and of course the belt.
Nice find!
I would also recommend dropping the front fender liners, removing the foam blocks, and cleaning and rustproofing the whole area underneath there.
oilhammer
www.cardocautomotive.com
Old February 9th, 2018, 09:14   #3
UhOh
UhOh's Avatar
Have you scanned it?
Nice find!
Old February 9th, 2018, 10:05   #4
maxmoo
Nice find!
^ Excellent advice.....I'd also check the intake for build up, the turbo for proper function and be sure to check for oil accumilation in the lower intercooler hose.
I find these cars with low miles were usualy driven by people on short trips and have probably never seen a good italian tune-up.
I'd also get it undercoated by someone like "Krown rustproofing".
Nice find!
maxmoo is offline   Reply With Quote
Old February 9th, 2018, 11:28   #5
dkline87
Nice find!
Thanks! The price was right too! Good call on tires, I'm sure they at least 10 years old. This car was serviced by a reputable VW shop, so I have records of all the fluid/filter changes throughout the years. I may flush trans fluid just as an extra measure.
Nice find!
Waiting to borrow a friends VAG COM. Not expecting anything crazy, the car drives nice and has plenty of power, but you never know.
Nice find!
Thanks! I have records of the EGR valve assembly being cleaned at about 70k miles, but I will definitely check the intercooler. I've read that these can trap plenty of blow-by.
Old February 9th, 2018, 12:32   #6
KLXD
Since the important stuff has been mentioned all I can say is polish or replace the headlights!
They can make an otherwise beautiful car look like an old POS.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
KLXD is online now   Reply With Quote
Old February 9th, 2018, 12:39   #7
UhOh
UhOh's Avatar
Oh yeah, pop the lower IC hose and make sure there's not a pool of oil lurking.
If you've got good power then it's likely the intake isn't badly clogged.
Regarding fluid changes, don't forget to change the transmission fluid (Pennzoil Syncromesh is highly recommended).
I'd look to fudge the maintenance intervals so they fall on to a nice even 10k odometer boundary. It's a handy way to know when the next maintenance interval is. I do this with all my cars. My car's sitting at 168k miles; I know that next service is 170k miles (at least an oil change).
Old February 9th, 2018, 12:39   #8
Mongler98
as stated before, other than normal fluids on all fluids* including brake fluid, timing belt. unless you have a mechanics repair order from the owner with the milage on it, replace the belt ASAP, its not the miles, its the years, its old enough and not a difficult job.
Old February 15th, 2018, 13:41   #9
FanofAllDiesels
FanofAllDiesels's Avatar
Wow, that really looks like a clean 2001. I notice that you are in MD. I'm up in Westminster, and have VCDS, if you are near by and would like a scan.
I have the same car, just a different color :-)
Jeff
2001 Golf - TDI Heater, RC 2/3+, Sprint 520's, H Pixel Cluster, Cat FF, 20th AE GTI seats, e-codes w/fog and leveling motors, Homelink
2003 Ford Excursion - Eddie Bauer (6.0L PowerStroke)
2007 Jeep Grand Cherokee CRD (3.0L MB Diesel)
96 John Deere 455 (3 cylinder Yanmar)
FanofAllDiesels is offline   Reply With Quote
Old February 15th, 2018, 14:41   #10
Nevada_TDI
Will you give us a hint as what you paid for it?
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old February 16th, 2018, 11:52   #11
UhOh
UhOh's Avatar
Jeff
Is that a GREEN Golf you have there? Green Golfs are the best! Never run across you before!
Old February 16th, 2018, 13:07   #12
ssaric1.9TDI
ssaric1.9TDI's Avatar
Fuel Economy: 40's
White Jetta's are better LOL
OP, that's a nice find you'll have a lot of happy happy miles ahead of you.
ssaric1.9TDI is offline   Reply With Quote
Old February 16th, 2018, 14:25   #13
UhOh
UhOh's Avatar
Well, this one I sure suffered a bit of drooling over:
http://forums.tdiclub.com/showthread.php?t=483453
If it has been up in my neck of the woods I probably wouldn't have passed.
Old February 16th, 2018, 18:37   #14
narongc73
Those are turds. Use to own one. Chip it.
narongc73 is offline   Reply With Quote
Old February 19th, 2018, 11:42   #15
dkline87
Jeff
I may take you up on that, thanks!
It cost about $3500
Definitely!
I just picked up an '03 manual ALH GLS wagon with 930,000km (578,000 miles) on it. maxmoo VW MKIV-A4 TDIs (VE and PD) 2 January 16th, 2018 15:55
Check out what I just picked up! 06 TDI 43k Original MILES 1 owner! tonestar VW MKV-A5 Golf/Jettas 4 August 12th, 2016 08:37
Proud owner of an alh.. questions and what now Humpty VW MKIV-A4 TDIs (VE and PD) 14 April 12th, 2016 13:47
New ALH TDI Owner!!! 1972SS454 VW MKIV-A4 TDIs (VE and PD) 4 March 8th, 2013 20:18
Picked up an ALH Manual (2003) with 83,000 miles smendick TDI 101 11 October 18th, 2011 21:54
Page generated in 0.18158 seconds with 10 queries
[Output: 132.34 Kb. compressed to 110.72 Kb. by saving 21.62 Kb. (16.34%)]
