Old February 8th, 2018, 21:23   #1
DaiJ
TDI(s): 2.0l
Question Drumming noise at 58-62mph
Seem to get a drumming noise at the front of the car at 69ish, bearings check out ok, told itís an engine induction noise..any comment?
DaiJ is offline   Reply With Quote
Old February 8th, 2018, 21:37   #2
whitedog
The problem starts when the drumming stops.
I don't recall ever hearing a noise on this site associated with drumming. Induction noise? That's an uh, interesting idea. The problem is that you are asking for a noise diagnosis on the internet. Is it possible for you to record it and post online someplace for others to hear?
Old February 9th, 2018, 05:42   #3
jettawreck
jettawreck's Avatar
Usually tires.
2004 Cadillac SLS (wife's)
Old February 9th, 2018, 06:59   #4
Mongler98
Check list for you in order of likelihood and then in cheapness of fix
Balanced tires, you lost a balancing or something
CVaxle is unbalancing itself and means a rebuild or replace
Wheel bearing,
there could be hundreds or reasons why you get a unusual road sound. Please dont describe things like sounds with words we are not familiar with aka no comparison. use youtube or something please.
Now you need to give us MUSH more information.
Does it go away immediately when you so much as even tough the brakes but continue the same speed? does it change if you steer left or right? does it change when you accelerate hard? ONLY at 69mph and no other speed, 65-75mph only? can you feel the sound vibrations in the steering wheel or break pedal? is it metallic?
try and describe it with what does and does not happen vs random words that it might sound like
Old February 9th, 2018, 06:59   #5
whitedog
Originally Posted by jettawreck View Post
Usually tires.
Is it engine speed or road speed?
Old February 9th, 2018, 09:12   #6
UhOh
UhOh's Avatar
Loose splash shield (or wings)?
How were the bearing proclaimed to be OK?
As others have asked, engine speed or ground speed?
Drumming noise up front golfclub TDI 101 5 January 31st, 2016 21:38
58 plate golf 1.9tdi 105 bhp grating noise. burton876 TDI 101 0 February 23rd, 2015 23:42
Drumming noise while holding down the clutch srmichi TDI 101 6 October 4th, 2009 22:33
Drumming noise while holding down the clutch srmichi VW MKIV-A4 TDIs (VE and PD) 1 October 4th, 2009 06:51
How to get 62mph-100km/h in 2nd gear? TorqueRules Upgrades (non TDI Engine related) 10 July 4th, 2008 08:42
Page generated in 0.17111 seconds with 11 queries
[Output: 74.24 Kb. compressed to 64.98 Kb. by saving 9.26 Kb. (12.48%)]
