Old February 8th, 2018, 19:17   #1
Gippeto
Default Rear dogbone mount question...
Have been catching up the maintenance/repairs on a Jetta TDI I bought a couple weeks back. Today was fixing coolant leaks and an oil/filter change (this was supposedly only at ~5000Km, but now I know for sure how many Km are on it).
While underneath, I found what I believe to be the source of a "clunk" when switching from drive to reverse (or vise versa).
Initial thinking was that somehow a bolt had come loose and fallen out, so I spent a little bit of time searching google for either the part# or the size for the bolt.
I found this;
https://order.germanparts.ca/product...pe=APPLICATION
Never having crawled under a VW, let alone a Jetta...I simply don't know if I'm missing a bolt...or the mount is actually broken.
Pretty sure someone here can tell me one way or the other what it is I need to pick up so I can fix this...bolt or a mount.
Thanks,
Al
Gippeto is offline   Reply With Quote
Old February 8th, 2018, 20:34   #2
PB_NB
PB_NB's Avatar
This is the one I have in my car (this is not my car). VF Engineering. Pretty stiff product even after 5 years, I am still waiting for it to break in.
It looks like you are missing the longer bolt that connects the mount to the tranny casing.
That must be really sloppy and hard on the downpipe and other parts with all the movement.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old February 8th, 2018, 20:53   #3
Gippeto
Yes, longer bolt is missing. Was mostly wondering if the steel plate was integrated or separate...it's no longer attached to the rest of the mount....likely as a result of the bolt going awal at some point.
Further searching turned up a video where it appears the steel plate IS supposed to be attached to the rest of the mount...looks like I"m shopping for a mount AND bolts.
Not the exact same engine/trans but it's reasonable to suspect they are similar.
https://www.youtube.com/watch?v=oDOZtMSLR9M
Edit:....or maybe not....a bunch of the aftermarket ones have the steel plate separate. I dunno....but better get a bolt in there for asap.
Al
Old February 9th, 2018, 07:38   #4
maxmoo
Make sure the threads are still good in the tranny.
maxmoo is offline   Reply With Quote
Old February 9th, 2018, 12:52   #5
Mongler98
oh man, yea theirs your problem lol. chase the threads with a tap and put some blue locktight on it when fixing it. How did this happen?
Old February 9th, 2018, 17:31   #6
AndyBees
AndyBees's Avatar
If you had the correct bolt and assuming the threads in the transmission are not damaged, it's just a matter of installing and torqueing to spec.
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old February 9th, 2018, 18:26   #7
PB_NB
PB_NB's Avatar
I have a spare transmission in the shed, reason for the spare is because the original casing cracked where the front bolt goes. The factory bolt hole just opened up and the gear oil drained out.
Be careful with those bolts as bad things can happen!
Old February 9th, 2018, 20:57   #8
Gippeto
Was an easy fix (as easy as, well....threading in a bolt )once the proper bolt size was obtained.
Interesting there....web searches had turned up a size of M10 x 75 x 1.25 and M10 x70 with no pitch specified.
Fortunate that I grabbed both coarse AND fine pitches to cover the bases...turned out to be coarse thread.
In the event someone else needs that bolt and comes to this thread searching for a straight answer;
The bolt I used is M10 x 70 x 1.5
Clunk is gone, peace of mind restored and a new mount and bolts are on order.
Al
Installing new Dogbone Mount, quick question? Naimanator Upgrades (non TDI Engine related) 12 September 23rd, 2009 17:07
Poly "dogbone" rear engine mount rosskuhns Private TDI Items for Sale/Wanted 4 July 17th, 2009 10:54
Dogbone mount bushings MOD- hybrid dogbone mount robnitro TDI Power Enhancements 70 October 16th, 2008 14:21
Poly dogbone mount question parkair TDI Power Enhancements 6 November 27th, 2007 11:42
FS: Rear main seal & dogbone mount Chemboy Private TDI Items for Sale/Wanted 0 June 30th, 2007 09:55
Page generated in 0.14553 seconds with 10 queries
[Output: 85.98 Kb. compressed to 74.15 Kb. by saving 11.83 Kb. (13.76%)]
