Old February 8th, 2018, 17:12   #1
04tdijettasuperturbo
TDI(s): 04 Jetta
Default Boost Problem
My 2004 Volkswagen Jetta TDI is shutting off at like 20mph because it's not getting the right amount boost I think. The previous owner said it would need a waste gate. I mentioned a waste gate actuator and he said it could be it. It's not getting the right amount of vacuum what could it be? In depth details please. And thanks in advance for the help.
04tdijettasuperturbo is offline   Reply With Quote
Old February 9th, 2018, 04:04   #2
JB05
Fuel Economy: 43/41/40
What do you mean by "shutting off"? Is the engine dying or are you experiencing over boosting? If you suspect the turbo actuator you will need a vacuum pump to test it; it should hold vacuum. A proper scan is also required before throwing parts at it. My actuator went out due to internal corrosion, but I was able to install a Garrett actuator along with a VNT software delete. P0299 was the DTC. I also changed the N75 on the firewall since it had sucked in the fragments from the defective actuator.
JB05 is online now   Reply With Quote
Old February 9th, 2018, 06:03   #3
Mongler98
YEAAAA, it shuts off? describe that more, you it restart no issue at all?
So any issues with boost leads to limp mode. you have more than one issue here
g
get a vacuum gauge and test all your lines and the actuator and dont throw parts at it at random.
please scan for codes too
Actual Boost vs Request boost problem makos101 TDI Power Enhancements 14 September 28th, 2011 08:25
boost problem Suharianu TDI 101 0 June 11th, 2009 09:48
boost or boost gauge problem? mk4 golf tdi lover TDI 101 1 May 7th, 2007 20:36
Boost problem gidb36 TDI Power Enhancements 2 August 24th, 2005 11:25
boost problem oldpoopie VW MKIV-A4 TDIs (VE and PD) 2 February 14th, 2005 14:34
Page generated in 0.12500 seconds with 10 queries
[Output: 56.51 Kb. compressed to 51.39 Kb. by saving 5.12 Kb. (9.05%)]
