Old February 8th, 2018, 14:05   #1
Shonky
Default Maf or something else
Hi, I've just bought a 2005 golf plus 1.9tdi, all was well until it started running rough and smoking.I pulled the plug from the maf sensor and it started running fine again.I fitted a new sensor, plugged it in and it's running rough again. I was thinking maybe it's the wiring but I don't know what the voltage etc should be, or could it be something else, if anyone has any ideas id be grateful.
Shonky is offline   Reply With Quote
Old February 8th, 2018, 14:18   #2
UhOh
UhOh's Avatar
Guessing will eventually get tiresome.
Have it scanned.
BTW - Anything other than a quality MAF (Bosch) is going to be questionable. Because MAFs play a pretty important part in how things operate they're not something to cheap out on.
Old February 8th, 2018, 14:21   #3
Mongler98
what part brand did you get? OEM? ebay? autocrap stores? amazon?
if you unplug it and it runs fine, thats your issue. you probably have a bad unit, RMA that suker and get a quality one and or try and repair/clean the old one? MAF's are simple circuit and when they get dirty they dont work. not sure why you would have much smoke increase with a bad maf? it usually sends into limp mode or just rough ride. you have a tune on it or larger injection? stock?
Old February 8th, 2018, 14:36   #4
Shonky
Scanned it, no codes(except a glow plug earth). Doesn't go into limp mode. Obviously get check light when the sensor is disconnected. Doesn't smoke all the time, just random clouds. Admittedly the new sensor was from Gsf but is behaving exactly the same as the Bosch. Wasn't sure what to do next, thought I'd get some advice before I start throwing money at it. Cheers
Old February 8th, 2018, 14:39   #5
UhOh
UhOh's Avatar
There's different ways in which a MAF can be "bad." 1) Outright failure (I've experienced this- turned the car into a bucking bronco- don't recall there being a code popping up [I run UltraGauges in all my cars]); 2) Degraded- FE and performance will drop (over time; very subtle); 3) Improper readings from a cheap MAF (readings within spec, but output isn't correct for actual conditions).
Could be that the MAF is reporting more air flow than is happening, in which case the ECU is happy about commanding more fuel. More fuel and not enough air = black smoke.
I'd unplug the new MAF and drive for a while. If it behaves (no black smoke) then it's for sure the MAF and or MAF circuit. If it's a cheap MAF then replace it with a quality one, regardless.
Old February 8th, 2018, 15:52   #6
Shonky
Cheers uhoh, when it's unplugged it drives fine, maybe a little thirsty.
Don't pay more for a TDI MAF when a 2.0 L Gas MAF will do and is 5 times cheaper ! Flashman2 VW MKIV-A4 TDIs (VE and PD) 277 August 10th, 2015 23:40
Input Needed. 2002 Jetta TDI overboost and MAF requested < MAF Actual ss04vv VW MKIV-A4 TDIs (VE and PD) 6 January 6th, 2012 10:07
Input Needed. 2002 Jetta TDI overboost and MAF requested < MAF Actual ss04vv OBD Scanners 5 January 6th, 2012 10:03
K&N air filter ruins MAF ?! - P0101 - MAF or VAF CKT Range/Perf BEEnTDI TDI 101 81 August 10th, 2010 15:31
how do i fit my 110 pierburg maf plug to a pd 150 maf cog TDI Power Enhancements 6 September 14th, 2009 06:30
Page generated in 0.16278 seconds with 10 queries
[Output: 74.95 Kb. compressed to 65.47 Kb. by saving 9.47 Kb. (12.64%)]
