Old February 8th, 2018, 11:08   #1
~TDIguy~
Question What clutch to install??
Hi guys, I'm getting the parts together to do the 5 speed swap in my early 05 TDI and I'm having difficulty deciding what clutch would be the best fit for me.. the car has a stage 2 Malone and EGR delete etc.. Theres a possibility ill do more power upgrades in the future but I'm not planning on anything crazy. What do you guys recommend? I was looking @ the south bend stage 2 daily but the price is a little more than id really like to spend, on the other hand if I'm gonna tear the stock clutch out in 6 months ill gladly put something heavier in right off the bat.. Glad for any suggestions! THanks
~TDIguy~ is offline   Reply With Quote
Old February 8th, 2018, 11:24   #2
nitec
TDI(s): 1.9TDi PD
Fuel Economy: What's fuel economy?
I love my Valeo single mass 228 clutch and flywheel kit - used it on 3 different swaps and had zero issues...clutch was confirmed to hold 215awhp and 300ft lbs...at those numbers it didn't look like it was starting to slip either but we didn't push it to the limits...
some people here will say that's a bad idea because the SMFW will damage your transmission but I've seen no evidence to back that up...my B7 A4 looooves it - the transmission runs great and honestly for the cost you can't go wrong...it works with your stock starter as well...I have zero vibrations from that setup - it's a nice heavy FW
complete kit for $350 - not too shabby
https://www.ecstuning.com/b-valeo-pa.../52285615~val/
nitec is offline   Reply With Quote
Old February 8th, 2018, 11:25   #3
PB_NB
PB_NB's Avatar
I tried a Single Mass G60/VR6 Combo and it slipped when I had a few mods. Then in 2012 I went to a Single Mass South Bend Stage 2 Endurance and it doesn't slip with the latest power upgrades.
I just installed a replacement after 5+ years as the clutch disc broke. South Bend sent me a new kit under warranty! Totally unexpected and very happy with their support!
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old February 8th, 2018, 11:57   #4
UhOh
UhOh's Avatar
http://www.cascadegerman.com/product...c-stage-2-smf/
If you don't need that much holding power then the Stage 1 (I have this clutch in my car and it's great).
Not recommended to go with a lighter flywheel.
Old February 8th, 2018, 14:23   #5
Mongler98
stage2.5 SBC enduroance clutch is awesome and about the same feel to it but is about the biggest clutch you can go with that is easily street driven on hills. i have no complaints about mine.
Old February 9th, 2018, 06:16   #6
~TDIguy~
That valeo clutch seems decent for the money.. Good to know the G60/Vr6 is a little light. Can the same starter be used with the south bend stage 2?
Old February 9th, 2018, 06:50   #7
Mongler98
i dropped my AHU mk3 from stock flywheel to a 11lb and it was not that difficult to drive. I had to relearn how to go on hills but took me 1 week. only thing i noticed was a 100rpm drop in idle speed, i love that sound, and that i can actually stall the engine out now while starting in 1st but not even close to a gas engine.
Old February 9th, 2018, 09:19   #8
UhOh
UhOh's Avatar
Verify holding power of a clutch and be sure that it's going to be capable for the power that you're expecting to achieve. I'd recommend talking to (supporting) vendors. I'm currently looking at a newly installed clutch that I'm not sure whether it's going to hold up over the long run: clutch has been known to hold under similar mods for many people, but some say newer ones aren't as robust: had I not been looking for a soft clutch for my wife I'd have installed the same DC Stage 1 clutch and never had another bit of worry. BTW - A DC Stage 1 clutch is on par with the SB Stage 2 (but it's a bit less expensive).
Old February 9th, 2018, 09:58   #9
PB_NB
PB_NB's Avatar
My Southbend kit uses the same starter.
post-clutch install, won't start.. ground wire? clutch sensor? AnnaTDI VW MKIV-A4 TDIs (VE and PD) 1 September 22nd, 2014 23:10
Clutch Install Help!! RikAmirnov Ontario 31 April 27th, 2014 21:33
Clutch install kenmaira VW MKIV-A4 TDIs (VE and PD) 4 January 12th, 2011 14:06
clutch install is there anything i need to know cog TDI Power Enhancements 23 February 19th, 2009 20:12
Need Clutch Install How To! neva_dinova VW MKIV-A4 TDIs (VE and PD) 2 December 9th, 2005 09:49
Page generated in 0.10664 seconds with 10 queries
[Output: 91.05 Kb. compressed to 77.91 Kb. by saving 13.14 Kb. (14.43%)]
