Old February 7th, 2018, 22:22   #1
Roller68
TDI(s): Gold3 tdi
Default VNT 1Z to ahu convert
Hello. i have a Golf 1Z from 1998 and what to convert to vnt.i got a complete ahu vnt engine for getting all the stuff from.can i put AFN software into my GG box in my golf mk3 or do i need a another box?. anyone got box nr to use and exact with software to put in the box.I cant se a complete information about box nr and software version for makeing this work.The hardware change is easy.
Roller68 is offline   Reply With Quote
Old February 8th, 2018, 06:24   #2
Mongler98
i am very confused.
You want to swap turbos into your 1z with a turbo from a AHU and you need new software?
there is so much conflicting information.
first off, AHU is a 1Z, isnt it?2nd off im not aware that the AHU came with a vtn turbo on any cars. 3rd there is no software swap, boost is boost, its all controlled by waste gate and turbo pressure or vacuum control from the n75
what is a gold3 TDI?
why are you changing your turbo? a vtn stock is not an improvement to a K03. its a sideways move with more complexity as your going from boost control to vacuum control. Upgrade your tubro with something better or are you replacing a failing turbo? why do you think its bad in that case?
Old February 8th, 2018, 07:01   #3
Mikkijayne
Mikkijayne's Avatar
TDI(s): Audi S8
Fuel Economy: lol
Do you mean convert 1Z to AFN to use the VNT turbo? Like Mongler said, 1Z=AHU - both wastegate turbo.
Yes, you can do that if you use AFN software and AFN N75 valve. 028906021GG AHU ecu will probably take AFN software, but its easier to just swap to an AFN ecu (like 026906021GH). I have one with immo off and tuning which you can have cheap MSA15 is plug and play with the immo anyway, if you have a matched key and VCDS.
Pecuariam felis
Mikkijayne is offline   Reply With Quote
Old February 8th, 2018, 09:08   #4
shortysclimbin
shortysclimbin's Avatar
Mikkijayne - is the AFN ecu obd port tunable unlike the 1z/AHU which is chip swap?
shortysclimbin is offline   Reply With Quote
Old February 8th, 2018, 09:22   #5
Exenos
TDI(s): 02 Golf
Pretty sure the afn is non flashable. Same ecu as the ahu so its a chip swap.
Exenos is offline   Reply With Quote
Old February 8th, 2018, 09:27   #6
Mongler98
this is why its best to just put in a used or new trubo upgrade for the engine you have, vs messing with a swap unless it gains something better, in this case it does not.
Old February 8th, 2018, 13:31   #7
Mikkijayne
Mikkijayne's Avatar
TDI(s): Audi S8
Fuel Economy: lol
All the 68 and 80 pin AFN ecus are chip swaps like the 1Z and AHU.
There are apparently some 121 pin port tunable versions for the AFN & AVG engines in the run-out B5 and C5 models, but I've never actually found one.
Well it opens up a whole load of more interesting or modern turbos like the BV43, GTB1756VK etc.
Pecuariam felis
Old February 8th, 2018, 16:48   #8
Mongler98
that's what i meant, if you go to all that work for a stock VTN13 or whatever you better just go and upgrade it all together,
FS: VNT conversion for B4/A3 AHU/1Z slow-moe Private TDI Items for Sale/Wanted 15 February 7th, 2018 12:06
FS Ahu/1z TDI "tdtuning" vnt chips cmeitner Private TDI Items for Sale/Wanted 0 January 5th, 2016 06:36
1Z/AHU Valve Cover, Injector Lines, Longitudinal Steel Oil Pan (B5 AHU/1Z/AFN/AHH) G60ING Private TDI Items for Sale/Wanted 0 January 11th, 2013 08:00
ahu / 1z vnt swap, complete setup xcdhracer15 Private TDI Items for Sale/Wanted 9 October 3rd, 2011 13:51
WTB VNT 15 with good turbine, 1Z/AHU injector lines jimfoo Private TDI Items for Sale/Wanted 1 January 13th, 2008 10:18
Page generated in 0.12009 seconds with 10 queries
[Output: 85.30 Kb. compressed to 73.44 Kb. by saving 11.87 Kb. (13.91%)]
